I'm Back in a Spam Can!!
Pitch system on 180 uses a trimming stabilizer. The 182 uses a trim tab on the elevator. Thus a different pitch control on the autopilot.
It's alive!! No smoke!
Garmin was very helpful. Turns out I did not have the latest installation document. MapMX from GTX 335 to G5 and GTR 225.
Panel wiring is all in. 90% done and 90% to go. The panel lit up with no smoke!
Old story but maybe worth repeating. I replaced my old stock interior with Selkirk panels. The installation was a huge pain. Once it was done I really didn't care for the appearance. I ripped it out and replaced it with Plane Plastics, which looks much more like stock plastic panels. MUCH easier to install. Like Selkirk the parts require painting. No big deal. After lots of testing I used standard Krylon since it worked better than anything else I tried, including the Krylon paint for plastics. I was happy enough with that until I took a ride with a friend who had the best looking interior I'd ever seen in a Skywagon. It didn't take long to decide to do the same. It still turns heads. https://youtu.be/zo06DxOIJy8
Thats a great idea !!! I need to replace th headliner in mine and have been dreading it. Now I'm not dreading it.!!
Engine is hung with new baffles. Ain't it purty!
Airforms baffles? No shroud on #5 or just not installed yet? I like the shield on #6. Most of us have to fab our own.
Get 'er done. You're gonna have some fun.
Originally Posted by robertc
I guess this means we won't see you on the flyin circuit this year.
I hope to be ready for Oshkosh, New Holstein. Engine will be finished next week.
Wait! I thought you were going to make the fly in season last year. Maybe I missed you. Maybe I was confused on the year.
Robert
Well. since the year and flyin schedule are toast....you are correct.
I plan to hire a team of Santa's elves to finish it.
MVP-50
All sensors connected and operating.
My 180 has a scoop/duct on the lower cowl/ right side. It is made of fiberglass. I don't see it in the parts photos. The open end points downwind.
1. Is it an add-on?
2. What is it's purpose?
It looks like there was a flange riveted on at some point. Right side? Maybe a negative pressure outlet for the cabin heat box to pull heat out during the warm months? I can’t think of anything else that would use an outlet like that.
It has a hose flange on the inside. There was no hose attached to it. I removed it to strip and paint the cowl.
Eddie, since you are painting the cowl anyway just make a flush patch using flush rivets, a little filler to smooth over any imperfections and paint it. You will like it better than an inoperative scoop.
Started Engine for the first time yesterday. W & B 1 March. Flying by 3 March. Been almost a year and over 1000 hours!
Here is the list:
Over 1100 hours and 12 months. One way to learn an airplane.
N4090H
• Removed all of the avionics and engine instrumentation
• Interior removed
• Battery moved to firewall with Atlee Dodge STC
• Removed windshield for dash pad replacement.
• Windshield reinstalled
• General cleanup and removal of dead wiring and antennas.
• New ABI spring and Baby Bushwheel tailwheel
• Remove stab trim jackscrews. Replace with new McFarlane units
• New Trim chains fore and aft
• New dash pad
• New Ack E-04 ELT
• 29 inch Bushwheels
• Engine fresh overhaul
• New McCauley prop and governor
• New stainless prop spinner
• New Throttle cable and rod end
• New Prop Cable and rod end
• New fuel drain cable
• New carb heat cable
• Removed vacuum pump and associated plumbing
• Engine overhauled with new nickel cylinders
• Overhauled Bendix Magnetos.
• New engine isolators and bolts.
• New air filter element
• Fabricated new instrument panels from .080 aluminum
• Removed all avionics and instrumentation except A/S, Altimeter, VVI, & T/C
• Installed Garmin 225 VHF
• Installed Garmin 335 Transponder with ADS-B out
• Installed new ACK E-04 ELT
• Totally rewired AC with all new wiring
• New pitot tube heater
• Replaced all pitot/static tubing
• Installed twin Garmin G-5s with GMU11 magnetometer
• New strut fairings.
• Replaced white tail light with LED unit.
• Installed Electronics International MVP-50 Engine Analyzer.
• Installed backup electric oil pressure gauge.
• Re bushed rudder bellcranks.
• Re bushed both control wheel yokes.
• Removed engine mount, media blasted, and powder coated. Reinstalled with new bolts.
• Overhauled brake master cylinders with new hoses.
• New ABI wheels and brake calipers.
• Removed both main gears legs, media blasted, painted, and reinstalled with new bolts.
• New main gear brake lines.
• All new scat tubing for cabin air and carb heat
• New hoses from gascolator to carb.
• New lines from primer to engine.
• New stainless primer lines from manifold to cylinders.
• New SkyTec starter
• Service access panel for jackscrews installed
• Access panels for bellcranks installed on both sides per STC
• Service letter for empennage cracking inspection completed. No cracking found.
• Door stewards installed.
• BAS Shoulder Harness and seat belts for Pilot and Co-Pilot Installed.
• Installed fuselage V-brace.
• Replaced all wiring on aircraft.
• Replaced all pitot/static tubing and fittings.
