Dave Calkins
Anchorage, Alaska
Am hesitant to point anything out with the "climate change" around here lately. Been at this over 30 years so I learned a thing or 20 along the way, yet some people have made a stink about me pointing out the obvious, but here goes....
The setscrew that holds the topcap of the master cylinder might be buggered so get new ones in hand.
Consider the condition of the flexible lines from the master cylinders.
It is possible to "reload" the rod and piston assembly with seals and never remove the cylinder itself, but theres likely some grit and sludge in the bottom of the cylinders to remove and you can "buff"/hone the cylinders more accurately ith them on the bench if necessary.
Theyre dead simple and kindof neat how they work. NOT rocket science at all.
....just trying to help.
