Results 1 to 20 of 20
Thread: Garmin GDL50
    4,089
    Garmin GDL50
    Garmin has replaced their GDL39-3D with the new GDL50 for about the same price. For those who look for bairgains you can find GDL39-3Ds at dealers for under $600 right now.
    http://newsroom.garmin.com/press-rel...ather-receiver
    Garmin also released the GDL51 Sirius XM receiver and the GDL52 combination ADS-B and Sirius XM unit ($1150.00) so now our tablets running Garmin Pilot have even more capability.
    http://www.aircraftspruce.com/catalog/avpages/gdl52.php
    Likes Chesney liked this post
    Meanwhile,...
    4,830
    Wish they had done that sooner, less clutter. I have an Xmas antenna on the dash and a GDL39-3D mounted back in the battery compartment on my Super Cub and love not seeing the fickel finger of fate (Garmin antenna) sticking up on the dash. Works well using the WiFi connection and am wondering if the 50 would work the same back there... humm
    Oct 2013
    23
    Was thinking of ordering a GDL 39 to go with my 660. What are the advantages of the 3D?,or now maybe I should look into the GDL 50. Did Garmin add new technology to the 50 or just appearance. Thanks in advance. Chuck
    4,089
    The "3D" adds ADAHRS (air data and altitude/heading reference system) to the ADS-B functions. If you use your Garmin for synthetic vision the difference between the GDL39 and the 39-3D is night and day. In Garmin Pilot it also provides a digital HSI if you prefer that view of a horizon reference to the synthetic vision view.
    From my light reading it looks like the GDL50 is the same as a 39-3D in a new housing and perhaps has better battery life. My 3D is hard wired so I have no reason to replace what I have based on what I've read.
    The bigger change is to the 50R over the 39R. My G3X has a 39R (remote version of the GDL39) for ADS-B in functions but it doesn't have ADAHRS. Not a big deal since the G3X has a magnetometer for the ADAHRS and that info is translated to my iPad but the 50R has it's own ADAHRS would provide a redundant/independent backup to my iDevices using Bluetooth. Is that important? Probably not, but we're all suckers for marketing and just because it may not be important doesn't mean I don't want it.
    For you lower-48 guys I'd think the GDL52 would be the hot setup. ADS-B, TIS-B, FIS-B, WAAS GPS, ADAHRS, and XM weather all from a little box that's pretty affordable. If I upgrade my 39R it'll be tempted to use the GDL52(R).
    FdxLou's Avatar
    Apr 2004
    1,722
    The bigger change is to the 50R over the 39R. My G3X has a 39R (same as the GDL39) for ADS-B in functions but it doesn't have ADAHRS. Not a big deal since the G3X has a magnetometer for the ADAHRS and that info is translated to my iPad but the 50R has it's own ADAHRS would provide a redundant/independent backup to my iDevices using Bluetooth. Is that important? Probably not, but we're all suckers for marketing and just because it may not be important doesn't mean I don't want it.
    For you lower-48 guys I'd think the GDL52 would be the hot setup. ADS-B, TIS-B, FIS-B, WAAS GPS, ADAHRS, and XM weather all from a little box that's pretty affordable. If I upgrade my 39R it'll be tempted to use the GDL52.
    Stewart, I think it’s “attitude “ not “altitude “.
    Lou
    4,089
    It's early. My internal spell checker is asleep!
    Likes FdxLou liked this post
    spinner2's Avatar
    Montana
    1,696
    Interesting that they’ve decided to replace the 39 3D. The synthetic vision didn’t work that well in my experience. Not nearly as well as the 6 pack panel page. The last software update helped quite a bit but it still has a hard time holding the horizon, in my experience. Maybe this new model fixes a problem that software updates couldn’t?
    Meanwhile,...
    4,830
    Quote Originally Posted by spinner2 View Post
    Only problem I have had is it sometimes the screen gets jumpy but then I cut back on it's coffee intake and it settles right down.
    2,352
    I'm leaning toward
    the GDL-82 ADS-B out gizmo.
    I wouldn't mind seeing
    some installation reports on it if anyone's gotten one yet.
    Likes lowerchena liked this post
    Sep 2017
    3
    Sorry to revive an old post...
    I have a GDL39 3D and a Garmin 796 for my '51 PA18 currently being rebuilt. These portables were hand me downs so I'd like to make use of them. I'd like to put the GDL in the back battery compartment as you describe above, but I was thinking about getting a wiring harness to run up to the 796. I didn't notice a WiFi connection option, I thought it was bluetooth only.
    Also, how's the reception for the GDL in the back there? I'm assuming you don't have it sticking outside or anything wacky like that.
    Lastly, what's an "Xmas Antennae"?
    Thanks!
    Meanwhile,...
    4,830
    Quote Originally Posted by Lotro View Post
    Thanks!
    XM antenna, I hate autocorrect...
    i have no no complaints with the unit mounted back behind the battery in my cub, it works good but it does work better when on the dash of my 180.
    Scouter's Avatar
    Nov 2003
    Exeter Maine
    1,825
    I just bought a GDL 82 for out, GDL50 for in. The 50 is dirt simple to Bluetooth with the 660, targets came right up, and the synthetic vision is great. The 82 is more of a handful for a do it yourself. You have to program the info into it, N. number and other info. You have to build a cable , and not screw up the pin placement. You have to use a usb to a square USB adapter cable. There are big letters from Garmin that says don't screw Up The pin out placement or it will eat itself. In the end I opted to let my IA mess with the setup. I plan to install it myself, Going to try the short factory antenna garmin says maybe it will work if not will mount a blade antenna
    ,My advice is the 82 is not a do it yourself project. For the most part.
    jim
    Thanks Poor Joe thanked for this post
    Likes pfm liked this post
    4,089
    The stand up antenna is for ADS-B. GPS antenna is internal. ADHRS shouldn't be affected by the location. I've never used the 39-3D anywhere but on my glare shield in the 180. Worst case if it isn't picking up ADS-B in back would be to separate the antenna and add a 6' extension cord and place the antenna in the skylight. There's nothing wrong with a GDL39-3D even with it being discontinued. You should consider wiring it for ship's power, especially with a remote installation.
    Pages 3-7 thru 3-9 in the manual discuss accessory antenna options.
    Meanwhile,...
    4,830
    When using it in from the turtle deck and I have the synthetic vision turned on (796) the display twitches a little bit and when on the dash it doesn’t making me think either the gps signal reception is degraded or perhaps the WiFi back to my 796 could maybe be better in the Cub but you don’t see any degradation on the Wx screens.
    Regardless of how you get it, it’s a great back up for weather to XM when on like today on a bumpy ass skud run and my XM connection (I deffinately prefer XM Weather and tunes) went Tango Uniform but I still had the ADSB Wx and my I-phone plugged into the intercom aux for tunes to give me the confidence to go up and over the bumps while keeping me entertained.
    Nov 2004
    Fairbanks
    869
    Anyone have problems charging the GDL50? Garmin asked me to take the unit back to the dealer. Awesome kit, just hoping a quick question might avoid a trip to the dealer and shipping it back and replacing it and....
    OldCuby's Avatar
    Nov 2004
    Harpers Ferry, WV
    539
    Quote Originally Posted by mghallen View Post
    I charge mine using a usb cable, but it takes awhile. Power light stays red until it's blank and fully charged. Runs a long time on internal power in my j3 bluetoothed to my Aera 660.
    I have the two hardwired together using Garmin cable in my super cub and plugged into ships power which keeps both fully charged.
    Jim
    Sent from my SM-T827R4 using SuperCub.Org mobile app
    Jim Newton
    Nov 2004
    Fairbanks
    869
    It is an awesome tool, mine just will not charge.
    I am am moving into the 2010s....next I will use headsets and maybe even those fancy ones that make black noise.
    2,352
    I just bought a GDL 82 for out........The 82 is more of a handful for a do it yourself. You have to program the info into it, N. number and other info. You have to build a cable , and not screw up the pin placement. You have to use a usb to a square USB adapter cable. There are big letters from Garmin that says don't screw Up The pin out placement or it will eat itself. In the end I opted to let my IA mess with the setup. I plan to install it myself, Going to try the short factory antenna garmin says maybe it will work if not will mount a blade antenna. My advice is the 82 is not a do it yourself project. For the most part.
    Thanks for the feedback.
    The local shop installed a GDL82 a few months ago,
    I was disappointed to see that a special antenna-to-GDL cable had to be made up,
    plus a special pigtail to hook onto a laptop for programming.
    All of that is inclining me more and more toward a uavionix "Tail Beacon",
    if and when they get the STC, TSO, or whatever approval it needs for installation on a factory airplane.
    It appears to be much more of a "plug and play" installation,
    and for about the same price as the GDL82.
    OldCuby's Avatar
    Nov 2004
    Harpers Ferry, WV
    539
    I too will likely purchase the uavionx tail beacon but will wait for the faa 500 dollar incentive fee!
    Jim Newton
    Nov 2004
    Fairbanks
    869
    A follow up. Spoke with Garmin Tech support. Asked me to ship in my unit(I did)and I already have the replacement unit. As warranty and customer service goes, Garmin did well. They tech helped me troubleshoot the issue and then when after reasonable try offered to replace the unit.
    GDL50 is still a nice unit with good support.
    Likes mike mcs repair, OldCuby liked this post
  1. Did you Know/Garmin 396 tip
    By Fortysix12 in forum Tips and Tricks
    Last Post: 10-01-2010, 11:19 PM
  2. New Garmin 696
    By fadec in forum Products, Purchases, Reviews & Prices
    Last Post: 03-06-2009, 09:37 PM
  3. Garmin 396 vs 496??
    By mvivion in forum The Art and Science of Flying
    Last Post: 09-13-2006, 05:17 PM
