Results 1 to 16 of 16
Thread: Oil Cooler By-pass
    Feb 2009
    67.8N,115.1W CYCO Canada
    721
    Oil Cooler By-pass
    Has anyone in the experimental crowd installed a by-pass valve to divert oil around (rather than through) the oil cooler? Seems like it might help in cold conditions to be able to control the oil temperature from the cockpit. Maybe quicker warm-ups too.
    Anchorage, AK.
    2,806
    That’s what your Vernatherm or viscosity valve does.
    Likes DENNY liked this post
    1,159
    Bill Rusk has a valve with control cable on his if I remember right, but I am into the red wine tonight so might be someone else.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,356
    A Vernatherm does in fact cause the oil to bypass the cooler. A viscosity valve does nothing in that regard until the oil pressure hits about 100 psi., and then only the oil that's being "dumped" (a small %) is bypassing the cooler. If you were to bypass the cooler with a valve, I think you'd want to use a blending-type valve (in reverse) so there is no hard "off" position.
    -- For faster warm-up I bring mine up to 12-1300 RPM, pull on carb. heat and then peak the mixture. This way I have warm air going through the sump and the mixture is correct so its not fouling plugs.
    Thanks chsJay thanked for this post
    n40ff's Avatar
    Oct 2009
    WV
    751
    Why not a sliding shutter over the oil cooler, inlet or exit?
    Feb 2009
    721
    Well, here's my thoughts, for what they're worth:
    The Vernatherm seems to be there more to protect the oil-cooler from the excessive pressure caused by cold oil. It's not precise enough to control the oil temperature. Covering the oil cooler with duct tape is a guessing game, and obviously can't be adjusted in-flight. A controllable shutter over the cooler gets mechanically complicated. But a valve with a by-pass line would allow precise oil-temperature control from the cockpit. I don't think it would hurt anything to have 100-percent by-pass for warm-up - after all, in very cold weather I've been covering 100-percent of the cooler with duct-tape.
    Anchorage, AK.
    2,806
    My interpretation isn’t that the Vernatherm doesn’t work but rather the cooler works too well. Controlling airflow through the cooler solves the problem for lots of guys. Duct tape is the popular choice. Van’s and Dan’s have been selling adjustable cooler doors for years. They provide adjustability from the panel. My new plane has butterfly valves in the cooler outlet ducts. I wouldn’t want a flow valve in my oil lines but if it interests you? Go for it.
    Bill Rusk's Avatar
    4,756
    NunavutPA12
    Here is how I did it. Part numbers etc. It is all here.
    You have to scroll just a little to where it starts.....
    http://www.supercub.org/forum/showth...l=1#post686807
    I love it!!!
    Hope this helps
    Very Blessed.
    Thanks NunavutPA-12 thanked for this post
    Anchorage, AK.
    2,806
    Consider the climate in which you operate and the potential for a congealed oil cooler. I like the idea that my coolers are flowing warm oil but with restricted cooling better than metering a small amount of oil through a cooler that's got excessive cooling potential. I'd be concerned about the cooler being congealed when I opened that valve and the ability for oil to free it up while in flight in sub-zero temps.
    Likes CamTom12 liked this post
    cruiser's Avatar
    South Glens Falls, NY
    1,277
    Van’s supplier for the shutter stopped making them, just before I decided to buy one, never fails. So there is an opportunity for some young entrepreneur.
    8,411
    Peter, I think he's talking to you
    Likes Poor Joe liked this post
    Anchorage, AK.
    2,806
    Anyone know if Dan's Aircraft still sells his version? That's the one I've seen used.
    Here's another option. https://antisplataero.com/products/o...er-air-shutter
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,356
    Good point.
    cruiser's Avatar
    1,277
    That looks remarkably identical to the Van’s
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    1,111
    I’m sure he’s not, he said “young”.
    Transmitted from my FlightPhone
    May 2017
    5
    Oil Cooler By-pass
    Quote Originally Posted by NunavutPA-12 View Post
    Larry Vetterman has installed one on the cub he built.
  1. Replies: 8
    Last Post: 06-18-2012, 04:34 PM
  2. Just too funny not to pass along.....
    By HydroCub in forum Lighter than Air - Flying Humor
    Last Post: 11-13-2009, 09:13 AM
  3. Told to pass it on...
    By aktango58 in forum Member to Member
    Last Post: 11-11-2009, 11:29 AM
