Did I mention the Beaver was on straight floats? It always seems safer to pull it when behind the prop, but I'm sure folks have messed up there as well...
It sounds like a few guys need to sort out their alternator and battery problems!
I would rather prop a 3 blade 6 cylinder Continental than a 2 blade
A 3 blade Continental always has a blade at the right location at firing.
A 2 blade does not. And you have to find the cylinder that fires where yu can throw the prop.
R985's are childs play to hand prop. Big heavy props and low compression and big magnetos that dont need impulse couplings.
The guy holding his hand up missing all the fingers...you say you used to hand prop what!!!
.....I hear a wood composite doesn’t have the mass or momentum to be hand propped. Don’t know. Just hearsay..... .
