Results 1 to 14 of 14
Thread: Marking wires
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    362
    Marking wires
    Does anyone have a good technic for marking wires? Iíve been doing more and more electrical work lately. All Iíve come up with so far is writing on heat shrink which is tedious.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    2,331
    Eddie Foy
    "Put out my hand and touched the face of God"
    Jan 2008
    Arlington, WA
    362
    Has anyone tried the Dymo Rhino with 1/4” tubing?
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    2,331
    I used this one on my re-wire. Works great!
    http://www.ksun.com/label-printer/bee3-ez/
    Eddie Foy
    Oct 2017
    1
    I make a spreadsheet in Excel with all of my wire numbers in a REALLY small font, bolded, and print it out. I cut the wire number I want, slide it into clear heat shrink (1/8" clear think), slide that on the wire and heat away. I use this on wires down to 22ga. I haven't tried smaller wire as I haven't had a need for it.
    Turns out perfect every time is quick and is waaaaaaay cheaper than one of those fancy heat-shrink-label-printers with the expensive printable heat shrink labels.
    Mark
    8,637
    Has anyone tried the Dymo Rhino with 1/4Ē tubing?
    That's what I have. Works good
    Jan 2008
    Arlington, WA
    362
    Just ordered one!
    Aug 2003
    1,250
    Just did a bunch of wires down to 18 gauge tefzel using ~$15 P-Touch labelmaker, with flexible tape and small font, covered with clear shrink tube. In the past I've used the Electrician's number tabs in little tear-off book, but with the P-Touch, you can include a text descriptor, not just a number.
    One other hint which is helpful, is to label not only both ends, but every couple feet in the middle. Helps future troubleshooting. The factory, and some large avionics shops have a machine which will apply number every foot or whatever it is that Mil-spec calls for.
    Thanks. cubscout
    Likes Charlie Longley, Brmoore liked this post
    Jan 2008
    Arlington, WA
    362
    Quote Originally Posted by cubscout View Post
    Thanks. cubscout
    AC 43.13 says wire should be marked every 15" max. Key word is "should".
    Thanks cubscout thanked for this post
    1,579
    Does anyone have a good technic for marking wires? I’ve been doing more and more electrical work lately. All I’ve come up with so far is writing on heat shrink which is tedious.
    Yep.
    Send me a list and I'll send you the marked wire. lol
    Thanks Charlie Longley thanked for this post
    Sep 2004
    Illinois & Wisconsin
    522
    I use an ultra fine sharpie.
    1,579
    Wow! You can write smaller than I can, lol.
    Sep 2004
    522
    Honestly, it is remarkably easy to do with an ultra fine sharpie. Try it; it works.
    1,579
    Most of the wiring I work with is 22, 20, 18ga, etc. So I went and bought the machine to mark them directly. It stamps the numbers onto single and single shielded wires. I only use sleeves on 2+ multi conductor. But I go through more wire in a month than most will in a lifetime.
  1. fuel stick marking
    By N5126H in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 03-25-2008, 02:52 PM
  2. Marking a PA-18 ASI
    By murph in forum Tips and Tricks
    Last Post: 05-21-2003, 07:27 PM
