marty for filling the weave isnt the mixture the other way around??? better add this is from post 23. went to stewarts system website and opened up the manual and its always in japanese or something, never been able to get it to work.
Hmmm, not sure why the download won't work. You should be able to download it from here:
http://www.stewartsystems.aero/support.aspx
The link is about three items down the downloads on that page.
In any case, I posted the reference from the manual below.
Marty
Sealing the Weave
Before EkoFill (E620) can be applied, the weave of the fabric must be sealed
with EkoBond (E610 or E610L). (To simulate the look of cotton fabric on the
inside of the aircraft use EkoBond Linen (E610L) to seal the weave.) In the past
EkoFill was used to seal the weave of the fabric, but we have found that using
EkoBond is both easier and provides better adhesion. It is acceptable to seal the
weave with two brush coats of EkoFill (E620) brushed into damp fabric as was
done in previous procedure manuals. However the following method is
recommended: Prior to applying EkoBond to seal the weave, the fabric should
first be cleaned. Dust should be removed with a vacuum or compressed air.
Next the fabric should be cleaned with EkoClean (E670) diluted at a 15:1 ratio
applied with a spray bottle and a sponge. The fabric should then be rinsed with
clean water. Allow the fabric to dry completely. The fabric is now ready for
EkoBond application.
Dilute the EkoBond with distilled water at a ratio of 3 parts EkoBond to 1 part
water by weight. Apply EkoBond to the fabric with a foam brush, being careful
not to miss any area. Only one coat is necessary, but may be brushed in
multiple directions to ensure complete application. Do not wipe off excess, but
allow to dry. If the foam brush begins to shed small pieces of foam, use a new
one. Is is not necessary to apply EkoBond over areas that have been glued with
EkoBond. Once EkoBond is applied, allow it to completely dry for approximately
30 minutes to 1 hour. It will be susceptible to dust and dirt because EkoBond will
remain somewhat tacky even when dry.* Once the fabric is sealed with EkoBond
and dry, EkoFill should be applied as soon as practical to prevent dirt and dust
build up. It is acceptable to store parts for a long period of time once EkoFill has
been fully applied, but care should be taken to keep it clean and dry. If the parts
are to be stored it is advised to not sand the final coat of EkoFill until ready for
topcoat. When ready for topcoat, wipe with a rag lightly dampened with Isopropyl
alcohol prior to sanding. If the cleanliness of the surface is still in doubt, you may
add an additional coat of EkoFill (E620) or EkoPrime, (E75XX) prior to top
coating.
*EkoBond will remain tacky indefinitely. It is possible that in areas where airframe
structure is close to the backside of the fabric but not touching, if the fabric is
pushed in to make contact with the structure it may adhere to it, which may be
considered a cosmetic flaw. If this is a concern, it may be prevented by applying
a small area of EkoFill into the weave of the fabric first in the area where it might
make contact so that no Ekobond is exposed on the backside of the fabric.
