Page 1 of 3 123 LastLast
Results 1 to 40 of 100
Thread: Observations on Stewarts System
    Oct 2013
    24
    Just spent the last week getting my first experience with the Stewarts System by covering the horizontal stabilizers on my Javron cub. To spread out the costs and stage the delivery of materials, they sent me all supplies needed to cover the tail surfaces with manuals and detailed instructions.
    From what I can tell from research, the fabric cement Ekobond is neoprene based, very similar to contact cement. Pretty impressive that you can formulate an aqueous solution of a hydrocarbon polymer that is easy to apply with no odors at all. My big learning so far is that the initial bonding of the fabric to a painted tube structure is obviously critical, but requires a thicker coating of Ekobond to the stucture, sufficient drying time, and an iron heated to at least 250 F. Iíve used the blanket method and covered the bottom first. The instructions have you wrap the fabric around the outer perimeter structure and rub the fabric with your hands to get the initial stick, then follow up with the iron to liquify the glue underneath and allow it to permeate into the fabric. You should see the glue discolor the white fabric. This is where I am finding out that if you donít have a sufficient first coat of glue or not a hot enough iron, this will cause problems when you then apply a brush coat of Ekobond on top of the fabric followed by a paper towel wipe to remove excess and fill he fabric weave. Iíve had several frustrating moments that at this point the fabric loses adhesion underneath and lifts off the structure. I then get into a messy fix by applying the iron to the glue soaked fabric when itís wet to try and get it to stick.
    Sorry for the long post but has anyone else had the same experience with Ekobond?
    Iíve attached a picture of this initial glue joint.
    6,013
    I have had zero problems with adhesion by assembling wet. Not absolutely sure the heat improves the bond, although I use heat to smooth the pinked edges. You can probably figure out what is in the glue by comparing it to 3M-30N.
    I love the Ekofil, and am not at all sure about my ability with top coats. I should get some experience in 2018.
    These expensive coatings have a short shelf life - Ekofil seems to have the longest, but don't let it settle or you will be stirring forever.
    jimboflying's Avatar
    May 2005
    452
    Just finished covering a set of wings with the Stewart system. I would not put an iron to wet glued fabric. I would just wait for the glue to set on any areas that have lifted. Pressure to the fabric will cause the glue to stick like contact cement. An iron applied to the area helps the adhesion.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,286
    When I teach a covering class, I show a little different method than in the picture. Before saturating the fabric with Ekobond like in your picture, I instruct to run the iron along the edge to set the fabric and than cut the fabric so it will wrap around the inside of the tube. Like Jim said, only iron after the glue has completely set up or it will not stick properly. I also teach to apply the first layer of glue on the frame below the inside tangent point of the fabric. This way, you can cut the fabric so it will attach inside the frame well below the tangent point. The fabric winds up to be about 270 degrees around the tube and is cut just above the fabric inside the frame. Use the iron than to secure the fabric inside the tube before you apply the second coat to saturate the fabric to the tube. Use the paper towel like you mentioned. The strength of the joint is not where it attaches to the tube. The "certified joint" is the 1" overlap of the fabric from the second side around the tube. On a 1/2" tube this is tangent point to tangent point. On a 3/8" tube, the 1" point is past the tangent point to establish the 1" overlap. After the second side is glued and shrunk around the corners, a final application of glue out to the tape line is applied and wiped with the blue paper towel. Hope this makes sense; sometimes it's difficult to follow without seeing it done.
    Marty
    N367PS
    www.marty2plus2.com
    Likes Rick-CAS, dcstrng, TurboBeaver liked this post
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    505
    Sounds like the glue is not quite dry yet, or maybe you don't have enough glue initially applied. I often will do two coats on the frame for just that reason. The temperature in your shop makes a big difference as to how the glue will dry, make sure you're warm enough. Cut those tails off the excess material before your final wipe, will make it easier. If you do get some minor lifting on the inside of the tangent no worries, let it all dry and nail it down with the iron.
    Oct 2013
    24
    Thanks everyone for your suggestions and advice. Much appreciated. Marty, I will try your suggstion on the elevators. I ended up not trying to iron down the wet glue and let it dry to the touch, then hit it with the iron. I finally got one of my stabilizers done. Used the modified Staggering knot at 2.5 inch spacing. Looking at the big parts like wings and fuselage with much trepidation, but itís one step at a time, one skill at a time to build an airplane, and lots of coffee!
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,286
    Quote Originally Posted by wdoubleday View Post
    Thanks everyone for your suggestions and advice. Much appreciated. Marty, I will try your suggstion on the elevators. I ended up not trying to iron down the wet glue and let it dry to the touch, then hit it with the iron. I finally got one of my stabilizers done. Used the modified Staggering knot at 2.5 inch spacing. Looking at the big parts like wings and fuselage with much trepidation, but it’s one step at a time, one skill at a time to build an airplane, and lots of coffee!
    Best way to cover with Stewarts is to do two pieces at a time. Apply the glue to one and move on to the next. After glue is applied to second piece the first is dry and ready to apply the fabric. Fabric is always applied after the glue is dry. If you find an area where you didn't apply enough glue, apply more and move back to the second piece you are covering. The back and forth process ensures that you give the glue time to dry before applying heat to any glue joint.
    Marty
    N367PS
    www.marty2plus2.com
    Likes Gordon Misch liked this post
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    I really like the Stewart System and use it all the time. After a while it will all make sense as to what step to take when and your speed will pick up. Kinda sounds like your rushing the glue, also if your tacking the fabric down on metal you may need to turn the iron up . Remember that your not trying to get the fabric to stick all around the tube at first just a 1/8"-1/4" line that shows thru and the fabric is stuck.
    Most important if you don't have the DVD's buy them before you do anything else. You'll save the cost in wasted materials, time and frustration. Also you'll get a much better job. Watch the one that applies to where you are.
    Thanks silet thanked for this post
    Rob's Avatar
    Nov 2002
    AZ06
    665
    They key to good looking fabric is the same as flying IFR. The farther ahead you are thinking the better. I routinely have 2 or even 3 irons running, and one is always a monokote style iron that heats all the way up the tip and on the topside of the shoe. That iron gets the inside of the tubes rickety split.
    On pieces like the tail feathers I tack it down all the way around the outside of the tube (just a pass) and then take a compass or dividers to scribe an even line around the fabric that's running long. A quick slide of the shears and you now have an even line cut all the way around the inside of the frame. I too run it a 270 around the tube. Don't get it under the first panel or it will show. Don't make squirrelly cuts thinking the next piece (or a tape) will hide that, because it will still show under those, unless you are using bondo for paint. After you have it trimmed, Iron the piece down all the way around, including everything inside the tubes.
    A couple more pieces, and I think you will find Stewarts to be the easiest thing out there. At least maybe short of Oratex. Also, I agree with the post above, tacking pieces down the tube acts as a heat sink and routinely takes more oomph than you'd think
    Take care, Rob
    Likes 8GCBC liked this post
    Oct 2013
    24
    OK this covering system is starting to make sense. I made sure to brush on a sufficient coat of Ekobond and let it dry for 20 min before I stick on the fabric. Also jacked up the heat a bit on my irons. When I welded up the stabs and elevators, i did not do them together to ensure alignment of the ribs, so a couple are off-set a bit and one not parallel. I compensated with the tapes that cover the rib stitching so at least the tapes are aligned. Thanks again for your help. This is great website.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    Very nice looking job. Now the ekcofill , the brush coats should go on thin and worked into the fabric. Not trying to build up the layers at this point, just trying to work into the fabric.
    nd
    2,756
    i thought the new manual says the whole piece must be brushed with ecobond? before the ekofill?
    Aug 2012
    In the woods
    505
    Careful of those dark lines on the edges of your tapes. If it's not all wiped through the fabric it will show through the top coats
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    Didnt see that in my stuff. Hope not did three airplanes with ekofill straight on the fabric. I'll look it up tonight. Thanks, Tom
    nd
    2,756
    i should probably change that word from (must to (should)? a watered down ekobond.
    Hardtailjohn's Avatar
    Marion, MT
    593
    When I became involved with this system in the mid 90's ( I wound up being part owner) the procedure was to seal the weave with diluted Ekobond. When Stewarts finished the STC process, they went to just brushing Ekofill into the weave. The current owner of the system has gone back to diluted Ekobond as a weave filler, yet retained the option to use Ekofill. So you're both right...it can be done either way.
    John
    nd
    2,756
    and the reason is???
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    Just read the new manual, so I'm OK but would also like to know the reason, thanks Tempdoug I hadn't seen the new manual. I have the whole set of tail feathers and controls covered ready to prime and will hold off until this is cleared up.
    Feb 2010
    Idaho
    212
    The manual says the first coat of Ekofill is to be applied to damp fabric so it will penetrate down into the weave and then the subsequent coats adhere. Apparently for some people, it is hard to define "damp", and they applied the first coat to dry fabric, it didn't penetrate into the weave and the coats of Ekofill and Ekoprime and the top coat would separate from the fabric. It is easy to define diluted Ekobond. I still apply the Ekofill to damp fabric and have been getting good results. With the diluted Exobond, my understanding is that if you happen to iron the fabric with the diluted Ecobond applied and you pass the iron over an underlying structure, it may attach. I don't know if that is a real problem, but according to my wife, I never change anything anyway.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    I may just stick with the Ekofill , it's working very good for me. Also I've been shooting top coats right on the Ekofill without the ekoprime. What's you feelings on that. I like the system but am concerned that I put out first rate work.
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,286
    You will be fine. The change was in response to concerns from builders in Alaska. They has some problems that turned out to be related to colder than optimal shop temperatures. The ekobond step eliminates the first fill of the weave and gives a better surface for the Ekofill to stick to. As long as fabric is damp, Ekobond will work just fine on bare fabric. The Washcoat of Ekobond to fill the weave eliminates a couple steps. Ekofill with a foam brush is still acceptable. If you are doing a certified aircraft and using the STC, it would be advisable to follow the current manual to keep the FAA happy.
    Marty
    N367PS
    www.marty2plus2.com
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,286
    The Ekoprime on top of Ekofiull is only needed with some colors for contrast and ease of color saturation. I had some difficulty with metallic yellow over ekofill. Getting to color saturation took additional fog coats before I was ready to shoot the semi and than the wet coat. By shooting a coat of white ekoprime first over the ekofill I was able to get to color saturation with less of the yellow for a lighter weight overall paint covering. Another example was on my fuselage. I shot white ekoprime than Ivory top coat. It was tough to see where I had enough top coat as there wasn't a good contrast. With ivory, a light coat of charcoal gray ekoprime would give better contrast. The last seminar I did we shot Ivory right over ekofill and we had good contrast, fast color saturation with fog coats, and good coverage. Whatever colors you shoot, practice on a test frame first to make sure you have everything down first. Make a 24" x 24" wood frame and staple the fabric to the wood. Do the three shrinks followed by all applicable finish steps. See how your color covers the ekofill to decide if you need a coat of ekoprime before the top coat.
    Marty
    N367PS
    www.marty2plus2.com
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,286
    It does say that, you are correct. The mixture is 3parts ekobond to 1 part distilled water. Easy to apply.
    Marty
    N367PS
    www.marty2plus2.com
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    Good to know stuff, thanks. The white under yellow and red have been a standard practice in the other systems. Without it a friend of mine had to shoot 9 coats of Cub Yellow and there was still a little shading.
    I'll give it a try on the tail feathers this week and see how it works. I guess it can't hurt.
    Tim's Avatar
    Petersburgh, NY
    3,403
    Never mind tail feathers, get Matt going ��
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    664
    I'm done with Matt's , finished his fabric before Christmas, I hate waiting on other people to get things done though.
    Jan 2018
    Pittstown, NJ
    34
    As I understand it, the original formulations when the product was called Blue River weren't that good. The product has evolved to what we know as Stewart Systems but what has changed along the way to make it a better covering system?
    Can anyone here vouch for a plane they've personally covered or saw through the covering process and which has many years on it that is still looking great with no covering system issues?
    I'm about to make a decision for a set of Citabria 7ECA wings. The plane was done with Poly Fiber and Aerothane but the water based Stewart product would make life here at home a lot easier and I can eventually top coat the fuselage and tail with the Stewart product when I have time.
    First hand experiences would be appreciated and thank you!
    Bart
    Hope this isn't a thread hijacking.
    Likes Frank Blaesbjerg liked this post
    6,013
    Gordon Misch did a nice job on his PA-12. I think his has been done for a decade. He is a participant here.
    My experience is small repairs. We had a 7ECA here. I am not going to tell you who repaired it, even though it is now dead and the statute of limitations is up - but the heavy coat of catalyzed auto enamel was seriously cracking along all ribs and around all rib "stitches".
    New tapes were applied with Stewarts glue after quickly roughing up the surface. Not going to spend time on a dirtbag!
    Ironed the pinked edges when dry, then three brush coats of Ekofill, then outside storage for six months. Survived, although ugly. Finally a cosmetic coat of sort of matching old expired white butyrate. Back outside for another year.
    Absolutely no problem with it, even though down and dirty. Sold to a guy who thought he could fly the thing. Crashed on takeoff. Wing patches were all that was left. Still good.
    Thanks Frank Blaesbjerg thanked for this post
    Jan 2018
    Pittstown, NJ
    34
    Thanks for the feedback Bob, really appreciate it. I thought we were good to go and was about to order materials until I ran the idea past my IA. His experiences some time ago were bad enough that he suggested I not use it. It was also long enough ago that the product today is probably/hopefully very different so I'm still interested in it for my 7ECA.
    Would love to hear whatever else is out there in the way of pros or cons from people that have done the work or who personally know how it is after years have passed. Thanks!
    Marion, MT
    593
    Quote Originally Posted by Bart23Sept View Post
    As I understand it, the original formulations when the product was called Blue River weren't that good. The product has evolved to what we know as Stewart Systems but what has changed along the way to make it a better covering system? There are no products that were in the Blue River system that are still in this system. The only part that is remotely related is the Ecofill, which is based on the old Eonex system (if you've been around long enough to remember that one). Blue River's glue was a disaster, the pre-preg fabric was a disaster, the topcoat was a disaster....none of that is in this system.
    Can anyone here vouch for a plane they've personally covered or saw through the covering process and which has many years on it that is still looking great with no covering system issues? I've been using it since the mid 90's. Covered a few, and they're all fine. In fact, they look great. I think there are a few that are members here that have used it with great results.
    I'm about to make a decision for a set of Citabria 7ECA wings. The plane was done with Poly Fiber and Aerothane but the water based Stewart product would make life here at home a lot easier and I can eventually top coat the fuselage and tail with the Stewart product when I have time. I have a friend that did his Stinson wings in the living room and his wife didn't mind at all. haha
    Bart
    John
    Jan 2018
    Pittstown, NJ
    34
    Thank you very much John, all good info.
    Nov 2002
    Fargo
    543
    Covered a cub with Stewart's around 2013? And then recovered it with ceconite and dope before I let it out of my shop. Tail feathers turned out great and the fuselage was so so looking but people pay me to do fabric work so off it came and into the garbage it went. I've covered lots of planes and parts and will only use Polyfiber or Ceconite and dope both are simple to use and well proven, you can mess them up just like anything but it seems like the people having problems are using Stewart's 3/4 of the time. Now you do have solvents to deal with in polyfiber but you can protect your self and if you think the isocyanide is stewarts catalyst is any less deadly then aerothane think again still need protection.
    Thanks hangarmonkey thanked for this post
    Likes jnorris liked this post
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,286
    History of Stewart Systems goes back to Aircraft Finishing System; purchased by the Stewart brothers in the late 90's. Blue River was a completely different company and not at all related to Stewart System. The confusion is in the use of water; the only component used in both systems. Blue River was a water based painting system and Stewart System is a water born system. Water is the carrier agent in Stewart Systems. Hope that clears up the common question about the two companies.
    Marty
    N367PS
    www.marty2plus2.com
    6,013
    I personally lean toward "Fargo"s assessment, but mostly because the cayalyzed finish coats and my personality do not mix. I cannot follow a recipe. I hate to strain paint. I get really good results with dope.
    But boy - for a quick patch, I am sold. They might have me if they get butyrate certified as a top coat. It seems to stick!
    Fargo - ever fool with Super Cub 83679? Its Fargo owner was a fed.
    Apr 2009
    AK
    71
    I love Stewartís and have used it with great results on a number of projects, but was disappointed to find that apparently the EkoPrime is sensitive to fuel. I covered a fuselage and shot EkoPoly right over the EkoFill, with good results, and then tried EkoPrime over the EkoFill in the interest of saving some paint, as previously stated in this thread. After the plane was assembled and flying, we had a fuel tank leak, and all areas on the wing that got fuel on the inside bubbled the paint and primer(EkoPrimed tank cover with no EkoFill did the same). But fuselage was unaffected where the fuel ran down both inside and out. Have since had another wing with a Stewartís repair using EkoPrime bubble/wrinkle as well after a fuel leak. Anyone else experienced this? The ekopoly seems totally fuel proof when spilling gas on top, but if itís over EkoPrime, it canít handle it from the inside. Iíll be using Stewartís in the future, but will leave the EkoPrime out...
    Nov 2002
    Fargo
    543
    Never worked on Les's airplane he dose his own work, is 83679 the white/ blue stripe and square off wings?
    Nov 2002
    Fargo
    543
    Overall I like the theory of Stewart's and getting away from VOC's but getting consistent professional results seems harder with it as it's way less forgiving than polyfiber/dope. I like their glue, had trouble with the ekofill when I sprayed it got run's and if you lessened the fluid control to stop the run's it would hit the fabric dry and have a sandpaper like feeling just no happy medium. The ecofill sands nice so after talking with Jason when he worked there I settled on shooting it dry and sanding it smooth as it was easier than sanding runs out, but the problem only appeared after I applied the yellow ekopoly. The sandpaper did not reach into the pinked edges of the tapes and after the yellow was on there was perfect 2" gritty lines runing down the sides of the fuselage. Never had problems painting ecopoly sprayed very similar to aerothane and that is where most seem to have trouble, had a little more orange peel than I like but I didn't want to deviate from the direction.
    Did I just get a bad batch of ecofill? Don't know but it seems that most 1st timers that are using the system paint things flat and one side at a time so you don't get runs and I goes on fine as did my tail feathers but if you are doing this for a living you don't have time to paint one side at a time plus It looks better painted all at once handing or in a rotator. Is it the lack of solvents that give it bite into the brushed coat? What ever happened to the blisters that were appearing a few years down the road if it got wet or in high humidity? Stewart's is finiky about the spray gun you use, now do you have a compressor that has the CFM's that the finish line HVLP they recommend needs, got to have real clean air so now you need filter system, all stuff you need for any system but polyfiber can be sprayed with about anything short of a garden hose and get descent results. My friend Lynn uses a turbine HVLP for everything from polyspray to aerothane and he's winning lindys with his planes, don't know how Stewart's works with turbine systems but it wasn't recommended to me at the time I used it.
    Nov 2002
    Fargo
    543
    Anybody know of a full time shop that uses Stewarts as their system of choice? Day in and day out.
    Jan 2018
    Pittstown, NJ
    34
    Quote Originally Posted by PA-22/20-160 View Post
    good question. i was referred to Central Arkansas Aircraft Repair. AFAIK they're not a Stewart-only shop but I was told after thirty years of refinishing airplanes they've tried everything. Haven't called yet but probably will this week unless you beat me to it and can report back.
    Jan 2018
    Pittstown, NJ
    34
    Thanks for the feedback. The impression I'm getting is that if you really follow the directions and maybe even use tweaks that people familiar with the system are willing to offer then you've got a good chance of getting great results. If you wing it then all bets are off. I have to admit, when it turns out just right it's pretty damn nice!
  1. Stewarts system fabric course
    By knucles in forum Cafe Supercub
    Last Post: 02-23-2015, 11:49 PM
  2. Stewarts system fabric course
    Last Post: 11-19-2014, 12:39 AM
  3. stewarts system - in the freezer
    By cgoldy in forum Experimental Cubs
    Last Post: 12-19-2010, 12:18 AM
  4. Stewarts Fabric System
    By J5Ron in forum In The News
    Last Post: 07-15-2009, 12:02 PM
