Page 1 of 2 12 LastLast
Results 1 to 40 of 57
Thread: Tips for Keeping Passenger Warm...Without Roasting in the Front Seat?
    WindOnHisNose's Avatar
    Corcoran MN
    3,713
    I have the Atlee rear heat mod, and it works well but doesn't keep Julie warm enough in the back seat. Airleaks are dealt with using green Frog masking tape (no residue), but it really is uncomfortably cold back there sometimes. We are getting Santa's Super Cub ready for his annual flights, and I would like to make this better for her.
    We have tried sleeping bags, but they are too bulky. Blankets are difficult to arrange around the passenger.
    Ideas/tips?
    Randy
    Anchorage, AK.
    2,520
    Teach her to fly and you sit in back?
    Jun 2016
    2
    Solution: Purchase a Carbon Cub FX3.
    Check out the new blog!
    Meanwhile,...
    4,367
    Come back to Oklahoma and swipe Eaton’s extension/diffuser for the main heater outlet, it will keep your feet from roasting while sending more heat back to your favorite Elf.
    Likes SteveE, WindOnHisNose liked this post
    504
    I mentioned this before somewhere...install a curtain behind and under the rear seat floor to ceiling and side to side. Can be fabric compatible with the plane and tied in like a baggage covering. Cover the open area in the rear of the fuselage near the tail spring if it's been left uncovered. Put flexible fabric with a slit over the elevator trim slots in the fuselage. Cold comes from behind.
    Also make sure any holes around the landing gear and boot cowl are covered. Install weather-strip around the door and upper window. Close any holes at the forward wing root fairing leading into the wing. Heat leaks out there from the rear of the cockpit.
    Electric 12V vests and other garments for motorcycle or snowmachine riding are available and do work. https://www.revzilla.com/heated-motorcycle-gear
    gntw's Avatar
    Mar 2005
    Ft. St. John BC Can.
    95
    Heated seat
    Come back to Oklahoma and swipe Eaton’s extension/diffuser for the main heater outlet, it will keep you from roasting while sending more heat back to your favorite Elf.
    I made a heated seat with control panel out of 2 gm heating elements and rear heat hose control box. Works good in my cub. Flown at -30f
    Likes WindOnHisNose liked this post
    8,050
    Likes phdigger123, WindOnHisNose liked this post
    Nov 2012
    Lake Lanier, GA
    773
    I really like Milwaukee M12 heated jackets. Made for construction work the carbon fiber tech in it makes it work better than anything I have experienced. My wife wears it and I don't roast.
    Likes Vlad, WindOnHisNose liked this post
    8,562
    make a VENT that will DRAW airflow to back seat.... sealing things up is not always useful...
    Anchorage, AK.
    2,520
    Kim is cold when it isn't cold, let alone when it is. Her trick is to put warmer packs in her boots and gloves. Never a problem once she does that. It's a cheaper/easier fix than revising your airplane.
    If she's cold and you're roasting it should be simple enough to divert some of your hot air to the back. A temporary scat like in Glenn's picture works well if your heater-defroster box has an outlet for it.
    8,142
    This is a great solution, and very simple. There are many ways to collect the heat into the scat hose depending on what you have up front.
    For heating the pilot, a small hole in the top of the scat will allow some warm air to escape and keep you warm.
    A heated pair of pants and vest sold for motorcycle riding might be a quick and easy solution, also can be used for snowmachines, biking and lots of other uses.
    Another solution would be to bring me the cub, get a PA-12 with a wide back seat, sit with her and keep her warm through body contact...
    One positive of a heated suit would be her ability to control temperature to suit her.
    8,142
    Likes okmike, WindOnHisNose liked this post
    1,089
    My wife just received some Baffin extreme cold weather boots for her birthday, we have not flown in them yet but she said they are the warmest boots she has ever tried on. The hard part is proper dress for cold weather flying, means shedding layers if you go inside. If you are doing lots of stops and going inside, people tend not to dress warm enough. Smartwool base layer bottom and top Followed by warmest pants she can find. Layer the top, wool sweater, wool vest, with Down hooded coat and scarf. Mittens with hand/feet warmer. She can remove as needed at stops. My heat system is kind of different. Rear seat heat system is dedicated to defrost only. The normal front/defrost is fed to scat tube for rear seat. I am usually warm/hot if anything and I wear bunny boots in winter so feet are always warm. Having the extended scat tube shown above is nice because you can stick it in your jacket or to any cold spot.
    akskibum's Avatar
    Dec 2011
    Anchorage Fairbanks
    33
    Down filled bib overalls and bunny boots.
    8,050
    How much you want to spend Randy? A warm wife is a happy wife, most times
    5,680
    I got really cold on a winter trip to Yakima - I found that, once in, a piece of cardboard and a lambs wool fleece between my legs and the side panels/door worked wonders.
    The back seat of a tandem can get deadly cold. A special heater plenum is the plan, but I would do the lambs wool trick back there too.
    Here in SoCal we rarely even hook up the heaters. It is against the local code to fly with the door closed.
    9,369
    Randy,
    If you haven’t already, block off the area just behind the aft stick, under the seat. Temporary, put a piece of solid fabric/Naugahyde, slide the top under the seat bottom cushion to keep in place, then tape the bottom and sides off to block off any air coming under the seat. You’d be surprised how much cold air flows forward from the tail, and enters the cockpit through that gap under the back seat.
    Likes Farmboy, Dave Calkins, WindOnHisNose liked this post
    2,639
    Now Bob, somewhere I have pics of snow on the ground in La Mesa - -
    504
    The fix...have the pilot ride in the rear of a Cub on a brisk winter day. Note their attention to detail regarding frozen breath and which way it flows. Have them feel about for leaks and become quite motivated to fix same. Holding a hot cup of steaming tea in hand can show the cold flow too.
    Also there's a serious note here. Carbon monoxide from exhaust is quite capable of entering the tail and moving forward with the cold air. Put a detector near the back seat and another visible from the front.
    Dec 2016
    61
    The backseaters that hang out with me would more than likely mistake that for a relief tube.....on purpose while taxing back to the hangar leaving you with the fresh scent of piss-potpourri shortly after the next start up
    8,142
    Lyn always used the engine cover as a blanket, it helped.
    Keeping warm is a combination of stopping cold air from cycling in, and retaining the heat you have. One very important piece is to keep the head warm- may I suggest Sea Otter: Sea Fur Sewing in Sitka will fix her up.
    Meanwhile,...
    4,367
    Mike you’re onto a good point, I had Pierce put snap vents in the D windows to help exhaust hot air in the summer which they do really well with both front vents and the boot cowl vent open but in the winter I still use them turned aft (open) with the heater on as necessary and the boot cowl vent open a tad they help pull warm air to the back.
    behindpropellers's Avatar
    NE Ohio
    6,561
    Quote Originally Posted by WindOnHisNose View Post
    Ideas/tips?
    Randy
    Sell your pa-18 and buy a PA-12. You can hire a pilot to fly you around in the winter while you keep her warm....
    Otherwise.... I have found the heated seat kits made for a car to work excellent.
    Thanks SteveE thanked for this post
    504
    When I flew two Airedales in my -18A they took to deep breathing in the cold. I finally put those snap vents in the rear windows to clear the dog breath and steam and it did help. They liked the idea plus sitting on the engine cover over a flat A-model floor.
    Anchorage, AK.
    2,520
    It works in a Skywagon, too. Soros makes cabin air outlet vents to allow airflow. It works to allow cool or warm air into a small cabin. Kinda like opening an upstairs window to help the wood stove heat a cold cabin when you first get there. Airflow works. Crash used to tell guys to add a high vent in their engine covers to allow their combustion heaters to have airflow. Same same.
    http://www.planeplastics.com/accesso...nhancement-kit
    Likes mike mcs repair, WindOnHisNose liked this post
    2,639
    That can move heat (convective transfer), but it surely also discards some of the heat energy that was supplied by the source. The net heat gain in the enclosure is necessarily reduced.
    Anchorage, AK.
    2,520
    You aren't baking a cake!
    If there's no outflow you can't introduce inflow very well. It may not be intuitive but heat up a -30* cabin for 25 years or so and you learn a few tricks. Allowing the cold air to exit is one of them.
    Thanks reliableflyer thanked for this post
    2,639
    That permits some quick transport of heat to upstairs in a cold-soaked building, but steady-state, the net heat flow into the enclosure is reduced and the downstairs is colder.
    Sorry Stewart, but no neophyte here. I heated my leaky old two-story home exclusively with wood for quite a few years. 20+ cords per year. Once I got the infiltration reduced in the rehab process, I used a LOT less wood. Like half. And it was a LOT more comfortable as well, both upstairs and down.
    Anchorage, AK.
    2,520
    Because you relied on radiant heat from the mass of the structure. Different conditions than a Cub cabin.
    Likes OLDCROWE, WindOnHisNose liked this post
    2,639
    Nope. Heat in minus heat out equals heat gained. Now, in a drafty Cub cabin, I agree that doesn't really apply. There, it becomes a matter of directing the heat in toward specifically where it's most wanted, cuz it ain't gonna accumulate!
    Meanwhile,...
    4,367
    Gordon, what we’re talking about in the cub (and mine seals up really well...once again thanks Steve!) is getting heat to the back passenger before the I’m done, time to make gravy button pops out on the pilot! Or are you figuring the pilot as a major part of the thermal mass to warm the passenger. Also with the heat on and the boot cowl vent a little open and the pop vents exhausting it really helps keep warm the pilots upper body as well, especially as I said before with a diverter or extender on the main heater outlet so you don’t have to put foil over your feet like a thanksgiving turkey.
    8,142
    Just saw this: https://www.facebook.com/photo.php?f...type=3&theater
    Sorry, I can not transfer the picture, but it would be very warm!
    8,050
    You can't " push " heat, remove the colder denser air and the heat will follow. Many in upstate NY lived it in old farm houses and froze. Add a few cold air returns from the remote rooms and every room had heat
    Thanks Delta Cub thanked for this post
    Likes SJ, WindOnHisNose liked this post
    40m's Avatar
    Dec 2013
    Shoreham, VT
    261
    I was thinking that might be a little small for some of Glenn friends then I remember we're talking about cold.
    From Genesis: "And God promised men that good and obedient wives would be
    found in all corners of the earth."
    Then he made the earth round... and He laughed and laughed and laughed!
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,274
    Heating a building involves warming/recirculating a relatively static mass of air. In the case of a Cub you are constantly importing fresh air (albeit hot) and I would think some form of exhaust would be required for best effect.
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    876
    Air leaks _into_ the cabin must be addressed. If you want to have an cold air exit/return, send it out the back.
ID:	33926Click image for larger version.
    Plastic diverter/valve has been replaced with aluminum. (Plastic good when open, deformed from heat when closed)
    Heater Hose replaced with Scat tube, runs under seat to outlet facing rear-seater. Photos are pre-underseat-battery install, but still has room with battery installed.
ID:	33929Click image for larger version.
    Thanks WindOnHisNose thanked for this post
    8,050
    You have wa.......y too much free time on your hands
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    13,425
    It's an expensive heater, but....
    http://cubcrafters.com/c/2017/12/car...eating-system/
    Farmboy's Avatar
    Jan 2016
    Glens Falls, NY
    876
    Actually, It's all about getting the wife into the airplane. Less whining from the backseat than from the house.
    8,050
    Does it really have heat at zero F ? 164% increase from a Carbon Cub at 2100RPM is still a cold airplane. Joe has trouble formulating words the first couple minutes after flying for an hour along side the rest of us.
    Likes 40m, WindOnHisNose liked this post
  1. Keeping the Battery Warm
    By NunavutPA-12 in forum Cafe Supercub
    Last Post: 03-26-2013, 11:49 PM
  2. keeping feet warm and dry
    By 3454terryg in forum Ski Flying Forum
    Last Post: 12-27-2012, 03:30 PM
  3. empty passenger seat available
    By Patrol Guy in forum Cafe Supercub
    Last Post: 05-13-2008, 03:18 PM
  4. Keeping your engine warm?
    By augerin in forum Cafe Supercub
    Last Post: 01-10-2006, 02:26 PM
