jimboflying
Is it ekoprime or topcoat?
It is ecoprime which was diluted with water 10%.
That wing looks very nice; you have the EkoPoly application down. As far as shooting urethane over Ekoflii; why dosen't the customer want Ekopoly over the Ekofill? I gather the wing you are shooting now is also exp? Urethane over Ekofill isn't in the STC because those finishes were not tested together so not legal on a certified bird. A catalyzed urethane should work fine but when you start mixing different types of paint with different thinners (solvents vs distilled water) you definitely cross over into the experimental zone. Depending on the urethane, adhesion is somewhat of an unknown. Ekopoly and Ekofill are designed to be fully compatible so I would recommend to the customer to stick with the same system. If they want a clear coat that is available in Ekopoly. From the perspective of your warranty on the urethane top coat, if the urethane isn't comparable and issues crop up in a year or two what happens?I shot this wing with ekofill and Stewart's top coat right on the ekofill. The wing I'm doing now, the customer want urethane top coat and I'm thinking of shooting right on the ekofill. Marty 57 would you comment on this idea, thanks.
Bob,The reason for the ekoprime is to make it easier to shoot yellow. If your top coat is white, you probably do not need primer. I have never had adhesion problems over Ekofill.
I was about to say that EkoPoly is Urethane so what's the problem but I notice that the description of the paint has changed on their web site, it no longer refers to it as Urethane although the name still indicates it's a polyurethane paint and likely is. They seem to purposely avoid the term polyurethane calling it instead a 'high performance topcoat', never noticed this before. I've got some older Stewart's products from 10 years ago or so and it's clearly advertised as a Polyurethane Top Coat.
What do you know Marty?
Both Ekopoly and Ekocrylic top coats are waterborn catalyzed polyurethanes. Ekocrylic is for metal only as it is a harder more brittle top coat and less flexible. Ekopoly is designed for the flexibility needed on fabric and is suitable for both metal and fabric. Both top coats can be color sanded and buffed; Ekocrylic being a bit easier due to it's greater hardness. Both top coats hold up over time to the same standards as tested for the STC's. So, short answer is both top coats are polyurethanes. I guess the confusion is that calling a paint "urethane" is common to solvent based paints as well as waterborn paints. One thing to remember is that Ekopoly and Ekocrylic is not water based; water is the carrier agent for the solids and replaces solvents with mineral water. When most users refer to urethane they are using it in a generic way and referring to solvent based paints. I suspect when a customer refers to urethane they are likely meaning solvent based vs waterborn. Sorry about the confusion on the web site. If you have the newest manual (Rev.#3); section 11 page 2 specifies the top coats as polyurethanes. Long answer here but hope this helps understand the product better.Urethane over Ekofill isn't in the STC
Back to original question of the post, I suspect the runs were caused by either the primer being too thin or the gun slowed down for some reason. I've had that happen when I'm not paying attention and pause with my forward motion because the hose is hung up or something is in my way and I have to reach; slowing down my progress.
Marty
Yes, that will work, though lacquer thinner will work well do. I use more of the lacquer thinner because it is cheaper by the 5 gallon pail. If what you have going on there is only in the last year or two I would say you had no fabric install issues. If only two or three years old, I would be more concerned. Those kind of issues you have are not uncommon at 10yrs.The fabric and Polytone is about 10 years old. The cracking is only right next to the trailing side of the leading edge tube of the horizontal stabilizer. Would MEK be the correct solvent?
What top coat are you using? It sounds like not enough catalyst in what ever process you are using. I'm into my third project with Stewart's and have had a few minor problems, if that is what you are using. I like it and can spray right next to my hangar furnace and not worry about blowing up.Sprayed the infamous Yellow top coat. Side one went fine but side two is still tacky after two days. Ideas?View attachment 34429View attachment 34430
