Page 2 of 2 FirstFirst 12
Results 41 to 53 of 53
Thread: Drastic measures needed to loose weight!
  1. #41
    Oct 2009
    Wanaka,NZ
    298
    IF I was ever to change props, I would go to the lighter weight Whirlwind ground adjustable for the one reason that I could fine tune the blade angle to suit me. The 2 or 3 pounds extra weight would be worth the convenience. The CG shift would be the most important. The inability to change the blade angle at will would always leave me wondering if I bought the correct sized prop.
    Unfortunately Pete we have to also compare cost effectiveness
    Just finished building a back country cub
  2. #42
    cgoldy's Avatar
    Apr 2009
    Mountain Creek NSW Australia
    305
    Don't forget the 2Lbs? for the crush plate
    So Glen I read that as the whirlwind does not have a crush plate? (I think maybe that is a stupid question)
    Back Country O-375 wide body extended wing cub
  3. #43
    cgoldy's Avatar
    Apr 2009
    305
    Quote Originally Posted by tedwaltman1 View Post
    Ok, Thank you for your interest in my carbon fiber floorboards. A few hours of assembling text and links to all the pertinent resources I have an 8 page PDF. I'm happy to create a new thread, but the first post would be pretty darn long! If SJ or folks want a new thread I'll create it. In the meantime, here is a link to the PDF (first draft--feedback, input, questions all appreciated). My email is at the end of the PDF, or PM me here.
    https://eaerofab.com/docs/SuperCubFloorBoardsV2.pdf
    Just ordered the carbon fibre Ted. Please don't tell Her-indoors how much that stuff is!
  4. #44
    cgoldy's Avatar
    Apr 2009
    305
    Colin
    EarthX battery = 10 (depending on location i.e. long cables if in rear of acft could be 15 pounds) mount it on firewall
    Sump 7 pounds
    Bill,
    The Specs say that they are only good for 150 Deg. And not to mount inside the cabin. Surely they will overheat on the firewall????
    Colin
  5. #45
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    388
    Quote Originally Posted by cgoldy View Post
    Bill,
    Colin
    Mine is mounted inside the cabin on the firewall. Been fine for a year and a half!
  6. #46
    7,243
    Bill,
    Colin
    Quote Originally Posted by CamTom12 View Post
    This raises the question as to why they are not to be mounted inside the cabin? Is this just a lawyer thing or is there a valid reason? I certainly wouldn't want one causing a fire between my knees.
  7. #47
    Bill Rusk's Avatar
    4,712
    Colin
    Hmmm.....Its been on the lower left firewall for three years and I've not had a lick of trouble. I have not put a temp gauge there but I doubt it gets that hot at that location. Lots of airflow through there. When I open the cowl door I don't burn my hands and it does not feel all that hot. I have the Sutton exhaust so there is no exhaust pipe or muffler back there, it is all up front. If you had an Atlee system I guess that could make a difference. Battery cables tend to be big and heavy so putting the battery on the firewall makes the cable run short and it also helps in the winter, when preheating the engine the battery gets warmed up as well and that helps.
    Hope this helps
    Very Blessed.
  8. #48
    cgoldy's Avatar
    Apr 2009
    305
    Thanks again all for your help. I have lost considerable weight already (from my hip pocket)
    Have ordered:
    Whirlwind prop GA200
    Eathx battery
    Lightweight sump (ECI)
    Lightweight flywheel without pulley (Sky Dynamics)
    Plane Power gear driven alternator to replace front mounted
    Carbon fibre materials and tools (plan to make new floor boards, seat bases and backs, nose bowl)
    Darren from Aerosport is an amazing font of knowledge and unbelievably helpful. Bruce from backcountry also very helpful re: props and ideas.
    Goal is to loose 100 to 120 pounds. Already lost 28 by removing cargo pod and Alaskan gear steps. Lights, tanks and pumps to come out next.
    Goldy
  9. #49
    Oct 2009
    Wanaka,NZ
    298
    So Colin I guess your ultimate aim is to fly the Tasman to NZ?
  10. #50
    Oct 2013
    Eagle River
    45
    If you’re worried about it, why not buy the one that is intended for use in the cabin?
    https://earthxbatteries.com/shop/etx900-vnt
  11. #51
    cgoldy's Avatar
    Apr 2009
    305
    Quote Originally Posted by ron View Post
    Soon Ron! Mum won't let me go until I am 60!
  12. #52
    7,243
    Quote Originally Posted by Prosaria View Post
    That does not answer the "WHY?". The ETX900 is non vented. If the battery doesn't need venting it can be used inside the cabin. I'm more concerned of whether or not a fire hazard is the reason. There is a good article on these batteries in the December issue of Kitplanes. http://www.kitplanes.com/issues/34_1...s_21972-1.html If there were a fire hazard reason I wouldn't want it anywhere in the airplane. The article indicates that the EarthX batteries are safe.
  13. #53
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,274
    Have ordered:
    Eathx battery
    Goldy
    There's always liposuction.......
  1. Best Way to Loose Weight?
    By scottperry in forum Cafe Supercub
    Last Post: 01-30-2008, 09:42 PM
  2. Loose Screws
    By RON NORMARK in forum Super Cub Sick Bay
    Last Post: 06-01-2006, 12:15 AM
