Farmboy
MEMBER
Middlebury, VT
Okay, so I got some ends to make up airfoil covers for the bungees, and while they looked small, I compared them to a loose strut and they fit.
Then I was out at the hangar and took a photo of the actual units on the -11, and it appears that mine is different.
The loose -18 strut seems to have a shorter lower cross tube, so the bungees would stack on top of each other, and the upper cross tube is longer, allowing the bungees to lay flat.
My -11 strut seems to have the same size cross tube upper and lower, making an airfoil cover not be able to fit over the lower cross tube.
Is this typical? It works obviously, but the parts breakdown and such do not seem to reflect this?
On the PA-11:
Loose strut for an -18:
Help?
Transmitted from my FlightPhone
On the PA-11:
Help?
