Page 1 of 3 123 LastLast
Results 1 to 40 of 100
Thread: Ferrying a Super Cub to Bolivia
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    Looking for ideas/advice on putting ferry tanks in a Cub.
    Planning to go the Caribbean route with the longest required leg being just under 700sm. The plane is an experimental 180 hp Super Cub with stock tanks, (no headers) a cargo pod and 35s. Shipping the 35s and pod is not really an option. I figured that to have climb fuel and 2 hour reserve I'll need around 90 gals usable to make 700 miles.
    nanook's Avatar
    Aug 2002
    northern alaska
    1,611
    With that setup, the dry land route would be preferable.
    Thanks vj88 thanked for this post
    Likes Superdan00 liked this post
    Sep 2006
    corvallis,or
    382
    Put the 35's in the cargo pod and run 6:00 -6". Or put the 35's in the back seat.
    Likes Jon Delamarter liked this post
    1,347
    1. Get a old 90 gal spray tank with pump and strap it on the belly. (YOU LOOSE THE POD)
    2. Keep pod and put fuel bladder in pod and back seat with pump. (spend money)
    3 9 Bushwheel bags in pod/back seat refuel at piss stops.
    Likes akwing liked this post
    Bellingen, NSW, Australia
    722
    Quote Originally Posted by DJ View Post
    Your only realistic option is a 60 gallon Turtlepac on the back seat, but even then this is a stretch and that would be heavy and behind your CG. With that Cub's cruise speed the effects of any unexpected headwind could be disastrous. I think this is an unwise undertaking. Your margins are narrow.
    https://www.turtlepac.com
    Thanks Eddy Lewis thanked for this post
    Likes skipster, PA-12 on Baumanns liked this post
    Meanwhile,...
    4,687
    Take the wings off and put it in a shipping container.
    8,193
    Planning to go the Caribbean route with the longest required leg being just under 700sm. The plane is an experimental 180 hp Super Cub with stock tanks, (no headers) a cargo pod and 35s... I figured that to have climb fuel and 2 hour reserve I'll need around 90 gals usable to make 700 miles.
    Just thinking out loud. This is what I would plan on doing. But then I wouldn't even think of that distance over water without floats under the plane or two engines and lots of fuel.
    700 miles between possible landing locations.
    A carburetor 180 Lyc at 75% burns roughly 10 gph. Yes you can pull the throttle back for less fuel burn with the accompanying loss of speed.
    What is the cruise speed of this Cub, 80-85 mph? Let's call it 70 mph to account for unplanned head winds. It doesn't take much of a head wind to drop a Cub's ground speed a lot.
    700 miles @ 70 mph = 10 hours plus 2 hours reserve = 12 hours X 10 gph = 120 gallons.
    120 - 36 = 84 gallons extra. 84 gallons = 11.2 cubic feet. Or 504 extra pounds of fuel.
    You need a 11.2 cubic foot tank in the back seat area. Build it so that the front of the tank is against the back of the front seat. Pay attention to the CG location expecting an over weight situation. The Cub will handle the weight as long as the CG is within reason. A custom built aluminum tank for this purpose is common for long distance ferry flights.
    Your tolerance may be different than mine. Having been in situations where there was nowhere to go for more gas, with unexpected headwinds, flying for nearly an hour with the gauges on E, I consider the above a minimum. If you have an accurate fuel flow meter on board you may be able to tighten the requirements a bit.
    Thanks Bassackwards, Airhutch, pfm thanked for this post
    Likes FdxLou, C-FIJK liked this post
    behindpropellers's Avatar
    NE Ohio
    6,610
    I would do the above, plus give yourself a 4-7 day window an pick a time when you have a nice tailwind.
    8,193
    Also educate yourself on the "trade winds" in the Caribbean. In some locations you will have a tail wind at a particular altitude and a head wind at another altitude. Needless to say there is more to this flight than just gasoline.
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    I appreciate the ideas....I've done the route southbound twice and northbound twice (in faster airplanes) and the winds weren't too bad either time. The land route through Columbia has even longer required legs.
    35s don't fit in the pod or in the back seat. The 60 gal turtle pac bladder was the original plan. Have looked at a 60 gal Sorensen tank but the owner wants $2K without plumbing or pumps (and I loose my pod like Denny said).
    With the Caribbean route the longest overwater distance between islands is pretty short (less than 70 miles) as long as I follow the island chain.
    I have an accurate fuel flow meter. I should know later this week what cruise speeds I can get with the 35s. I'm hoping for 83 mph indicated at 9.5K and 9 gph which will give me 100 true, minus a 10 mph headwind is 90 true. I will go higher than 9.5K if possible. 17 gals of reserve and 5 gals for the climb gives me 680 miles safe range on 90 usable. My longest leg would be 670 in Brazil.
    The big question is how to get the fuel in the plane.
    Does anyone have a big ferry tank or bladder (or two smaller ones?)
    9,462
    thinking out loud.. not simple..
    how much fuel do 35's hold? how would you transfer it in flight?
    wasn't there a mini dirt bike decades ago with fuel in the tires?? I can picture it, just can't remember the name of it... even seen one for sale up here...
    1,347
    Most of the 180 cubs tend to be pretty fast even with 35's. Depending on the prop you should be able to do 90 with a 8 gal/hr fuel burn. To get the fuel to the tanks put a T in the line with a one way valve and a 12 v fuel pump. As tank gets low add until full, don't forget to turn pump off, repeat until home. A good fuel flow is the key. Do you usually carry a raft and PLB?
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    This one has an incidence of 7 degrees, a Catto 86/38 and TK1s. I'm afraid its slower than most. Getting the fuel burn down to 8 or less would really help the range. Will have life vests, a PLB, Delorme Inreach, Laser Flare and Spot, still working on borrowing a raft. I figured I would T into the left tank and use it primarily. That way I could keep the right tank full for the reserve.
    tcraft128's Avatar
    May 2006
    St. Marys GA
    771
    I have a metal cruise prop in the classified section that gave me a honest 110mph on 180hp. It uses the same bolts as the Catto and my plane is setup the same as Dans with the exception of 31s.
    Turning money into noise since 1996
    Our Build here
    Likes barrow pilot, Steve Pierce liked this post
    9,972
    I’m curious why not ship the Bushwheel’s? Is there a Customs tax or? Seems you’d increase speed and thus save gas enough to pay for shipping.
    Or not.
    if you didn’t have the pod to deal with I’d suggest finding a Soenson belly tank.
    Otherwise, it seems like a ferry tank behind the pilot seat is your only option.
    9,462
    ok maybe not hard.... to me...
    the one hour of thought solution to carrying fuel in the 35” tires….
    dual transfer collar on face of rim, with inflatable seals
    one hole under one track of transfer collar in rim with tube and weight on it so it always lays at bottom of tire(this might be exterior/interior transfer from tire to transfer ring, think like valve stem)
    other hole/track in transfer collar to air valve stem, to pressurize tire to push fuel, and inflate tire to proper pressure after fuel transfer…
    other parts,
    small air pump(s?) pressure gauge & switch
    valve(s)?
    fuel line to gas tank
    that cures the getting it out of tire….
    getting the gas In the tire probably need kick stand under axel while you fill tire with fuel… (how?? gas cap is what??)
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    Yes the taxes would be $1000-1500, plus shipping, and I wouldn't see them for 6 months plus unless they went air freight ($$$$)
    9,462
    can you make a new bolt on front wing attach fittings on wing like others have, to set different incidence angles... think 'extra vertical holes'
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    I think it would require re-rigging everything and refitting windshield etc. The aileron cable runs above tubes in the top deck. I guess I can't picture an easy change.
    9,462
    cable would be below tubes then....
    making fairing would be easy...
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,558
    Mike, you're thinking of a Rokon. It was also 2 wheel drive.
    9,462
    actually,
    getting fuel into the tires would be easy... it would already be plumbed to transfer FROM tire to TANK... so you would just fill tank, transfer to tires, then refill tanks...
    Oct 2017
    San Antonio, Texas
    24
    actually,
    Beginner's question here. You're talking about using the aircraft-mounted tires as holding tanks for gasoline to be transferred in flight? I must be misunderstanding this - tires and gasoline don't mix and gas dissolves tires, not to mention hot brakes and vapors. What am I missing?
    Likes FdxLou liked this post
    Apr 2015
    Platinum
    209
    What about....thinking about a radar dome on the E3 Sentry....something like a roof mount car luggage carrier? Cept...it would look like an oblong drop tank mounted above the fuselage....Structure is there...wing attach fittings.. streamline tubing to create the tank support structure... plumb into one of the fuel level sight gauges and install a little ball valve...
    Likes mike mcs repair, Jonnyo liked this post
    9,462
    Quote Originally Posted by Jaywalker View Post
    same company that makes the bushwheels make rubber fuel bags, so they probably know how/what....
    9,462
    Quote Originally Posted by Mark_Moyle View Post
    thats a heck of a good idea.... have to get randy at carbon concepts on it.... http://www.carbonconceptsak.com
    Mar 2016
    Reno, NV
    49
    Any strips or landing sites you could land on and fill from jugs carried in the back seat? maybe amphibs are in order?
    9,462
    Cessna's got rubber fuel tank bladders.....
    Oct 2017
    San Antonio, Texas
    24
    Same company doesn't necessarily mean same rubber compound in both tires and fuel bladders.
    https://www.tirerack.com/tires/tiret...jsp?techid=262 They're pretty clear that gasoline damages tires.
    Little_Cub's Avatar
    Feb 2011
    Palmer, Alaska
    268
    do you need 35's down there? can you load enough fuel and stow the 35's?
    hows the oil burn in that machine?
    would sure have an alternate (possibly mechanical) pump in place.. just cause.
    super-cruse prop
    wait for the winds!
    fill the belly
    thats a knee knocker!
    9,462
    it would be pretty easy to fab one of those up using aluminum & rivets, put the seams out on the sides, some pro seal.... do the bottom mount with angle aluminum cross ways? rivet that to floor first and pro seal before doing sides....
    Tim's Avatar
    Petersburgh, NY
    3,418
    Get Dan to fly it down there, let him worry about it
    Likes tcraft128, Steve Pierce liked this post
    9,211
    This guy can (has) do it
    https://youtu.be/pFTf9fmxdic
    Thanks Oz. thanked for this post
    Likes tcraft128, Ruffair, Oz. liked this post
    Oct 2009
    Wanaka,NZ
    316
    Quote Originally Posted by nanook View Post
    The aircraft does not know it's over water.
    Mar 2016
    Reno, NV
    49
ID:	33469Would this work from Trinidad?
    Georgetown and Boa Vista airports are ports of entry, miles are approx. (Google Earth).
    TTPP> SYGO 300NM
    SYGO>SBBV 280NM
    SBBV>SBEG 355NM
    SBEG>SWHT 320NM Carry 20 gallons from Manaus to Humaita and land there to pour it in, or buy car gas.
    SWHT>SBPV 90NM
    SBPV>SBVH 327NM
    SBVH>SLVR 345NM
    nanook's Avatar
    Aug 2002
    northern alaska
    1,611
    Quote Originally Posted by ron View Post
    hundreds of pounds over gross, glide ratio of a rock with 35"s and pod, only 90 miles of open water to cross.
    what could possibly go wrong?
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    Looking into the cruise prop idea. Got one 30 gallon tank in the backseat area and there is still lots of room for more. 60 gals back there would make me happy.
    Speedo's Avatar
    Jul 2002
    AK
    1,680
    For a trip of that distance, it seems like a cruise prop is essential. Is Brian Sutton’s constant speed prop an option? It sure makes long trips go faster, and would help with the efficiency.
    I guess the problem would be finding someone who wants it when you get to your destination .
    Speedo
    L18C-95's Avatar
    May 2011
    London, UK
    404
    Interesting dilemma - a Super Cub I fly was ferried across the Atlantic, I can see it been done with a belly tank, but not sure how you stay within CofG envelope with a large ferry tank in the rear.
    DJ's Avatar
    Jan 2009
    Bolivia
    138
    I thought I would give an update on this ferry project.
    I tested two cruise props and the results were interesting.
    I didn't have OAT so the True airspeed calculations are approximate but conditions were similar.
    When testing the 76/60 prop I had 120 pounds of extra weight in the rear baggage.
    The airplane is a bit draggy with 7 degrees incidence, 35s, TK1s, dual shock T3, safety cables, and a belly pod.
    Catto 86/38
    Redline 2700 rpm - 103 mph (about half throttle?)
    Static ~ 2350 (can't hold it, brakes slip, tires slip or tail comes up)
    Cruise @ 6500 ft and 7.7 gph - 84 indicated ~ 93 mph TAS (2500 rpm)
    Sensenich 76EMS - 54 pitch
    Full throttle at 1500 ft - 2750+ (115 mph)
    Static 2520+
    Cruise @ 6500 ft and 7.6 gph - 88 indicated ~ 97 mph TAS (2450 rpm)
    Sensenich 76EMM - 60 pitch
    Full throttle @ 1500 ft 2650 rpm ~ 117 mph
    Static ~ 2350 rpm
    Cruise @ 6500 ft and 7.7 gph - 88 indicated ~ 97 TAS (2400 rpm)
    I matched up the EGTs to the same temp each time on cylinder #1 at 7.7 gph to give the most apples to apples comparison.
    I really liked the way the 54 pitch performed. A 56 might be a little better in cruise?
    The 60 would be a great break-in prop but otherwise didn't seem very useful on a draggy Cub.
    The difference between the Catto and the 54 seemed about the same as the difference between the 54 and the 60 in takeoff and climb. The 60 really suffered with two people and full fuel.
    I'm thinking I'll stick with the Catto and not bother buying a cruise prop and paying import duty on it.
    We have two 29 gal tanks that will be installed in the rear seat area and baggage area totaling 58 gal. My empty CG with 6 qts. oil is 11.1 so the CG works out fine.
    Usable Fuel ~ 90
    Longest Legs - 650 sm (Brasil)
    Climb Fuel Allowance - 5 gals
    Reserve Fuel - 20 gals
    Cruise 95 MPH TAS @ 6500 ft (I'll go higher if weather permits)
    Cruise fuel burn 8 gph
    This basically gives me 8+ hours at 95 mph (8 x 95) = 760 miles
    With a 15 mph headwind (8 x 80 mph) = 640 miles + 10 miles covered during the climb = 650 miles
    More than 15 mph headwind I relax in a hotel and wait for a better day
    Likes Gordon Misch, pfm, pzinck liked this post
  1. Replies: 8
    Last Post: 07-14-2015, 02:06 AM
  2. Replies: 1
    Last Post: 06-15-2015, 11:43 PM
  3. Super Cruiser Elevator/stick/system/ is super Cub type
    Last Post: 01-14-2012, 10:07 AM
  4. Off airport in Bolivia PA14-220?
    By DJ in forum Cafe Supercub
    Last Post: 02-08-2009, 08:38 PM
