The key is to put your butt as far to the aft end of the door frame as possible. Put both feet in. Then do a pull up from the overhead X brace. Nothing to it when you use the right technique.
That's how I do it. I still say an 18 is easier to board (front seat) than a 12.
I agree Bill, I'm 70 yrs old, been doing it your way for many decades, and it works well for me and always has. Still have to show a youngster how to do it once in a while. I don't even think about it, just slide in and go.The key is to put your butt as far to the aft end of the door frame as possible. Put both feet in. Then do a pull up from the overhead X brace. Nothing to it when you use the right technique.
and if your back is in the shape mine is on cold days you have to grab your pant leg to help your left leg bend so it will go in.The key is to put your butt as far to the aft end of the door frame as possible. Put both feet in. Then do a pull up from the overhead X brace. Nothing to it when you use the right technique.
What about getting out? Anybody use the Kyle Franklin method?
That's where you fall out of a moving cub pretending to be drunk and then duck right before the tail groundloups over the top of you. Possibly the most stylish egressWhich is??
If a kilt would correct the damage from multiple compression fractures and a non-existent L5-S1 disc believe me I'd wear one every day.A great reason to wear a kilt- no restriction in the inseam!
S2D would be the guy to videotape for YouTube...He makes it look easy.
Must come from being a bronc rider
