Results 1 to 19 of 19
Thread: Oratex
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    306
    Oratex
    looking for advice the last 3 cubs i covered in stewarts thinking about oratex on my next cub
    is it a good idea for a working cub
    nanook's Avatar
    Aug 2002
    northern alaska
    1,632
    I'm planning on using it on a working cub, would like to attend a workshop and play with the stuff first though.
    CubCubCub's Avatar
    Mar 2009
    Ozzy in Japan
    54
    Hi Skysigns. I'm no expert on the matter and this is just an observation so take it for what it's worth. A Super Cub came in for a 100 hrly the other day. This Cub was recently recovered in Oratex (it was covered in cotton.....was getting tired!). I am not sure about the figures but speaking with a mechanic that was involved with the recover, he said the empty weigh decreased with Oratex so that's good. However, watching the back end of the aircraft when it is on the ground at idle, my impression is that the entire back end flex's (twist's) allot more than other Cubs covered with either Polyester of Cotton. I think the Oratex is more flexible than the regular coverings. Whether this will translate into structural fatigue later on remains to be seen. Perhaps others have had more experience with this? Apart from that, a friend of mine said it seems fairly puncture resistant and if it gets a dent (stretched), just grab the iron and warm it up again and you are good to go. Anyway, just my 2 cents worth!
    Likes Mander liked this post
    3,207
    I just finished covering my landing gear with Oratex. It is definitely different to work with than Stits or Stewarts, but following the directions closely gave a decent result. It certainly is nice that once it's on and shrunk it's done! I think, however I could do a nicer looking job with Stits or Stewarts, the only other systems I've used.
    Speedo's Avatar
    Jul 2002
    AK
    1,690
    Quote Originally Posted by CubCubCub View Post
    Wait, are you suggesting that other coverings actually stiffen the airframe?
    Speedo
    nanook's Avatar
    Aug 2002
    northern alaska
    1,632
    Watching the tail shake on a cub, would not be a valid assessment tool for the fabric! The big prop/180hp., especially so.
    Likes C-FIJK, mike mcs repair liked this post
    Eddie Foy's Avatar
    Dec 2014
    3,155
    The words are flexes and twists. If that is the case, it's not the coverings fault.
    3,207
    The tail might resonate more or less with lighter or heavier fabric? Maybe??
    Marty57's Avatar
    Jan 2005
    Nipomo, Ca
    1,366
    Just a quick question or observation; but is Oratex now certified? If it's on a working, certified Cub than wouldn't it need to be certified?
    Marty57
    N367PS
    www.marty2plus2.com
    3,207
    Marty, I thought it had fairly recently received STC approval, but I can't seem to find a reference now. Somebody here will know for sure -
    Thanks Prosaria thanked for this post
    Dec 2012
    Portersville, PA
    53
    http://www.betteraircraftfabric.com/news.html
    CubCubCub's Avatar
    Mar 2009
    Ozzy in Japan
    54
    Quote Originally Posted by Speedo View Post
    Like I said, it's just an observation so take it for what it's worth. I tend to think it could. IMHO, structure's flex more prior to being covered than after they are done. I think if you cover something with a heavier weight material, it would naturally be more rigid. My feeling is that the Oratex is a more flexible covering. The Cub I commented about had it's structure checked over prior to recovering with Oratex and all appeared to be fine.
    CubCubCub's Avatar
    Mar 2009
    Ozzy in Japan
    54
    Quote Originally Posted by nanook View Post
    I know that, there could be lots of reasons. This Cub is a 150.
    CubCubCub's Avatar
    Mar 2009
    Ozzy in Japan
    54
    Correct me if I am wrong, but generally speaking, isn't one of the reasons that an older aircraft that was originally designed to be covered with cotton, needs to have approval (STC) prior to being recovered with a 'modern' covering, is because the resulting rigidity of the structure changes due to the difference's in strength/flexibility of the 'modern' covering?
    18,226
    Is there a comprehensive list?
    FAA STC Approval!
    Latest STCs include PIPERS, some AERONCAS and STINSONS. Don't forget our STCs for all Maules and Huskys!! We also have Field Approvals for Cessna 120/140s!
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    530
    I don't think a stretched fabric covering provides enough tension to be considered semi monocoque.
    I think coverings require STCs because there's a big concern for fabric failure when your lifting surface is made of fabric.
    CubCubCub's Avatar
    Mar 2009
    Ozzy in Japan
    54
    Quote Originally Posted by CamTom12 View Post
    That seems like a fair concern. It would definitely be a problem if the fabric fails in flight!
    Aug 2014
    Kenai, Alaska
    166
    Vermont
    200
    When RC modelers switched from water shrink paper to heat shrink polyester, there was a noticeable decrease in stiffness as there was no tautening nitrate applied. How tautening are the modern liquids? I would think the big difference would be when we stopped using nitrate on ceconite. I wouldn't think there would be much difference between two heat shrink polyesters if there's no liquid tautening these days.
    P.S. When shrinking, use a calibrated thermometer. Old steam irons need to be cranked just above the synthetics range, slightly into cottons. It's not like you're going to let the iron sit there motionless. Now you've got tension.
    What's a go-around?
    Thanks pfjay52 thanked for this post
  1. Oratex fabric covering
    By copter86 in forum Member to Member
    Last Post: 05-10-2017, 06:52 AM
  2. 1st Annual Oratex Covering Seminar
    By Roger Peterson in forum Cafe Supercub
    Last Post: 07-24-2016, 11:23 AM
  3. Oratex Fabric
    By Roger Peterson in forum Experimental Cubs
    Last Post: 12-25-2015, 07:29 PM
  4. Oratex UL 6000 Fabric Covering
    By Crash in forum Tips and Tricks
    Last Post: 05-14-2015, 10:28 AM
