T3 and a Matco tailwheel. I've never seen a tailwheel tilt like this. The T3 angle is pretty close to identical as a Pawnee spring, but the T3 is an inch or two longer. The airframe is on shop gear but it's shorter than real gear and taller gear will make the tailwheel tilt worse. FWIW, the Matco head-fork angle is identical to a 3200. I've never focused on a 3200 when turned 90* but I sure don't recall anything like this. Any ideas?
