Results 1 to 12 of 12
Thread: trim indicator stuck
    Jul 2016
    Eagle River, AK
    63
    Good Morning,
    My pa-18 trim indicator is stuck all the way forward. Started peaking into it in the field and wanted a little more info before I tried to repair. I have found a few posts discussing removing the trim handle and cover however nothing discussing the trim indicator that moves forward and back indicating where the trim is set. Also my trim handle is cracked and needs to be replaced. Currently it has a cotter pin securing it on.
    1,089
    VJ
    You most likely broke the cable to the indicator and the spring is pulling it forward. Look at the inspection covers at the tail and you will see the small wire running up and over the pulley. If it broke at the pulley you can fix it from the back. I should be out at Birchwood today working on my plane. Hanger next to front door of airframes stop buy if you are out.
    check PM
    Likes WanaBNACub liked this post
    Dec 2015
    145
    Thanks cubpilot2 thanked for this post
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,274
    I agree with the broken trim indicator wire. Usually its a solid stainless wire and it breaks where it makes the 90 over the front of the H.stab. I recently had it happen, and replaced that segment with a piece of 1/16 braided-coated cable.
    Jul 2016
    Eagle River, AK
    63
    supercub1999 what specific part is it or will all of those ford handles work?
    8,562
    I use berkley coated SS braided fishing leader
    16,544
    Old trim cable works great.
    Jul 2016
    Eagle River, AK
    63
    It was the trim indicator wire. I have one now and just need to fix. No metal belly/cleanout pan so should be fun!
    1,089
    You could try a butt splice with solder or very small heat shrink tube and pull it from the back.
    8,562
    Quote Originally Posted by vj88 View Post
    use a long piece of wood or metal to get it where you need
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    222
    Hi all. I was putting the side panel on the Cub that's now owned by a friend and I lost the little indicator. (red arrow that points up)
    Where would I purchase another? I did look at Univar site but it didn't jump out at me.
    Cheers.
    Likes 62E liked this post
    Jul 2013
    Haywards Heath, UK
    48
    On our SuperCub the indicator is more of a dome and is attached to the indicator bar (held by spring at front end and indicator cable at the back).
    Your indicator (red arrow) might have been a "modification". Univair have the bar/indicator listed here:
    http://www.univair.com/piper/piper-j...zer-indicator/
    Kind regards
    Stew
  1. Trim Indicator Routing
    By Paul Heinrich in forum Cafe Supercub
    Last Post: 03-01-2015, 05:23 PM
  2. Stuck Horizonal Stabilizer Trim
    By scscuba1 in forum Super Cub Sick Bay
    Last Post: 11-29-2012, 03:32 PM
  3. Trim Indicator
    By cubnut93 in forum Tips and Tricks
    Last Post: 03-25-2012, 10:57 PM
  4. Elevator trim stuck - grease hardened like asphalt
    By Speedo in forum Super Cub Sick Bay
    Last Post: 03-27-2007, 09:14 AM
