pfjay52
Port Lincoln, South Australia
i am building an Experimental Javron Cub 'Downunder'. i have a nice, almost zero time Lycoming A1A IO-360 that i have sitting on the engine mounts now. i want to install a Whirlwind Aviation 80" 210 Constant Speed prop, and i'm having issues with the governor fitting. my only option is the accessory mount on the back of the engine and i have just under 6" clearance between the firewall and the back of the engine. that is enough to install the 'Jihostroj' governor that Whirlwind sell. But i didn't take into account the drive adaptor (Lycoming #75153) that attaches the governor to the back of the engine, which in itself is about 2" deep. that rules out using a governor over 4" in length. in the parts manual it shows a gear drive that looks like it will mount the governor direct onto the case without the adapter (Lycoming #LW12914)
anyone here have any thoughts on this? i see MT make an electric governor/prop control, i wonder if anyone has any experience with these? are there any other ways of driving the governor, or other proven options.
thanks in advance.
cheers,
Phil
thanks in advance.
cheers,
Phil
