Page 1 of 2 12 LastLast
Results 1 to 40 of 57
Thread: Wing recover
    jimboflying's Avatar
    May 2005
    468
    Wing recover
    What items are normally checked or replaced when doing a wing recover?
    9,657
    normally??
    or what I do?
    1. all steel parts removed sent for blasting, inspection, powder coating
    2. all hardware removed is replaced
    3. wing measured & trammed
    4. ribs replaced as needed
    5. hanger blocks replaced or repaired as needed
    6. new leading edge from Univair blanks since it's already removed(and is less time/$$ then cleaning and bondoing old junk..
    7. maybe replace trailing edge if bad shape...
    8. maybe prime leading and trailing edge to help prevent corrosion..
    9. hang and align flaps and ailerons with wing in proper twisted position
    10. replace tip wood bow
    11. replace lighting wires
    12. add Atlee Hurricane tie downs if not already installed
    13. extend top leading edge back 14"~ if wanted..
    thats the pre fabric 2 minute thoughts...
    17,923
    Here is a list in Google Drive that my daughter and I came up with. https://docs.google.com/document/d/1...t?usp=drivesdk
    Thanks tedwaltman1, flybynite, mike mcs repair, txpacer, Wag2+2 thanked for this post
    Likes Hardtailjohn, WanaBNACub liked this post
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    normally??
    or what I do?
    Mike can you still get the leading edge extension approved? I was led to believe that they wouldn't allow it anymore without engineering. (This has been several years ago now).
    My 180 cub has it and I sure like it!
    Ed
    AK
    3,875
    I think Mike's enjoying the freedom of the experimental category. I know I am!
    Before.
    Thanks jimboflying, flylowslow thanked for this post
    Likes Hardtailjohn, skukum12, WanaBNACub liked this post
    AK
    3,875
    After.
    Likes Hardtailjohn, flylowslow, WanaBNACub liked this post
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,053
    If you can get the leading edge extension approved, do it! It's worth it's weight in platinum!
    "Always looking up"
    9,343
    Quote Originally Posted by skukum12 View Post
    Why?
    Thanks 62E thanked for this post
    8,844
    After.
    Super nice!
    Likes WanaBNACub liked this post
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,053
    Why?
    No scalloping. It creates a uniform airfoil all along the wing.
    "Always looking up"
    Likes DENNY, mike mcs repair liked this post
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,053
    "Always looking up"
    Likes mike mcs repair, 180Marty liked this post
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    I had a friend that did one of the leading edge extensions years ago. Prior to the work he had done some slow flight competition alongside a buddy of his and they were about at the same speeds.
    After the change he could stay in the air when his buddy was stalled out. This was prior to using VGs.
    He said that it made a big improvement in flight characteristics. Both had stock round tip wings.
    I did several mods to mine plus VGs at the same time so it was hard to say what helped the most but lift was better. The changes caused the tail to not be as effective as it used to be. I then added the VGs to the stabilizer which helped.
    Another side benefit is that when the Ravens use my cub to have lunch on they don't poke holes through the fabric anymore....
    Stewart: I think that I am about ready to go the Exp. Route myself.
    Ed
    AK
    3,875
    I like it for sweeping wings. The area where metal is added is where snow gets crusty and stubborn. It's the place where the ribs are the most vulnerable to damage from a broom. It's also the place on the plane where I have the most leverage and the least control of my broom. I appreciate the added reinforcement.
    Here's a good old thread that discussed wing covering. It's worth the read.
    http://www.supercub.org/forum/showth...pson-Wing-Help
    Thanks cubpilot2 thanked for this post
    Likes skukum12 liked this post
    AK
    3,875
    Lots of exp Cub stuff happens that doesn't surface here. I know of guys who've tried bands of pre-shrunk fabric between ribs and other guys who mimicked that using 3-4" carbon fiber strips to bridge between ribs. From what I heard neither proved worth the effort. I believe 8856Charlie has customers who've used carbon sheet to extend the leading edges like the aluminum in the picture. I wonder how that's worked? It seems like lots of guys favor minimizing the fabric scallop.
    3,092
    Well, looks like I managed to delete my own post by accident. There was a long thread on this topic in 2009. It referenced this article from NACA.
    Also, this more recent article re whale flippers is interesting, though I don't know if it applies to the scallops on Cub wings.
    In any case, properly conducted tests would be informative. "One good test is worth a thousand expert opinions"
    AK
    3,875
    Memories of the whale flipper champ at Birchwood. That brings a smile. That's a very different discussion than scallops between ribs.
    http://www.supercub.org/forum/showth...nd-howz-it-fly
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    I had forgotten that old thread and especially the part about the fabric not shrinking equally.
    I checked the polyfiber manual which was last revised a year after the posting and they basically said the same thing about the scollops in the fabric. They suggested the medium weight if you don't want to see them and advised that using the heavy weight fabric with the blanket method would produce scollops.
    Their recommendation was that if you wanted to use the heavy wt. then to consider an envelope which would run the fabric cord wise.
    I have a set of wings that are ready to cover and I think that I'm going to do a bit of sewing.... (Well maybe the wife will)
    I never liked seeing the seams in the wing fabric but.... Oh well. Piper did some of the worst ones. Ive seen as many as 5 splices on one wing; with some only a couple feet apart, and running cockeyed. Piper didn't waste any fabric.
    Ed
    AkPA/18's Avatar
    Big Lake Ak
    621
    Watched your cub come out of the north pothole Lake Hood last Friday. Hands down one of the best performing cubs on floats I have seen. Great job Ed!
    Mark
    http://thrustline.com/
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    Quote Originally Posted by AkPA/18 View Post
    Mark
    Its because of the thrust line kit a guy sold me....
    Ed
    May 2005
    468
    I am getting PA12 wings with flaps ready for recover. When I removed the leading edges for replacement I found these loose metal parts underneath. They were only attached by tape. Are they supposed to be there?
    When I removed the stock tank I compared the offset of the DCA part that is to the rear of the tank, I noticed that is was quite a bit smaller. It is on this offset that the tank and antichaffe strip sits. Do I have the wrong part? It is also longer than the original part. Any help with these issues would be helpful.
    17,923
    That reinforcement under the leading edge was used under 3003 aluminum outboard 3/4 skins. When Piper went to 2024-T3 skins on the Tri-Pacer and Super Cub they eleminated the reinforcement.
    I would call Dakota Cub on the false spar. Might be for their tank installation. Talk to Brian.
    May 2005
    468
    Steve,
    Thanks for the followup. If I have new Univair leading edges would I leave those reinforcements out?
    Jim
    17,923
    Quote Originally Posted by jimboflying View Post
    Steve,
    Jim
    I would and do, thy use .020" 2024-T3 like the later Pipers.
    May 2005
    468
    The aileron hangers had an external reinforcement on the outside of the trailing edge as well as the internal side. The flap hangers which were added at a later time to add flaps did not have the external reinforcements. Do they also need external reinforcements? This is on an experimental PA12.
    17,923
    The Super Cub has a reinforcement on the inside of the inboard flap hinge, that is all. Do you have the Northland Drawing CD. Lots of good information there.
    9,657
    you need the external reinforcement with the Day and Night flap STC... the INTERNAL ones are not required/superseded(Aileron also) I throw them away, they are REPLACED by that external one, per the AD on -12 Aileron hangers...
    http://www.univair.com/content/PIP_SB0107.pdf
    May 2005
    468
    Mike,
    Thanks for the help as usual. Where would I get the external ones for the flaps?
    9,657
    Mike,
    same as aileron ones... Univair
    9,657
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    Update: So I did just that... Using the heavy weight fabric we sewed the three strips together and using the old methods of attachments at the trailing edge. The difference in scalloping between the blanket method and this was amazing!
    The photos below is of a cub covered with the heavy fabric in the blanket method (glued span size to the leading edge.) The scallops are 5/8 or more between ribs depending on the rib spacing.
    With the "envelope type" method on the wing that I just finished in silver, the scallops are 3/32 to 1/8 inch deep as measured with a strait edge over the cap strip reinforcing tapes.
    The Red wing is my 180 cub with the 12 inch L.E. extension.
    I am no aeronautical engineer but IMO when you allow the vertical cross section of the airfoil to be reduced this way; that there has to be some difference in the lift component.
    I would bet that if you did one wing with the blanket method and the other in the envelope; that it would be wing heavy as hell.
    Ed
    9,657
    no...
    It all has to do with the order of which direction you shrink it.....
    Apr 2012
    King Salmon, AK
    64
    The end shape during flight is totally different anyway, as the fabric balloons up instead of being stretched down. The tighter fabric may end up shaped more like the ribs than the other one.
    8,372
    no...
    Correct, place the iron on the ribs first to shrink the fabric span wise. This will pull the span wise fibers up to the level of the ribs. Then shrink between the ribs. If you shrink between the ribs before the fabric is pulled up to the rib caps it WILL always have a belly in it.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    That is what I always thought.
    Keep in mind that this is the "heavy weight fabric; and medium does not react the same. I was involved in all of the wings in the photos and they were all ironed using the same basic technique.
    The Polyfiber manual even corroborates what I experienced. They say that you Will get the scallops with the heavy fabric! I just never thought that it could be to that extent, and that it is preventable.
    I have aireal photos of the Blue cub and the wing fabric does not balloon up. The shape is still there.
    The airplane is also a good performer and flies nice.
    In the old thread mentioned above the guy built a 2 x 2 frame of pvc pipe as it is flexible enough to show the stresses; and covered it with the heavy fabric.
    When shrunk the frame distorted nearly an inch in one direction and hardly any on the other. It does not pull evenly.
    IMHO either use medium wt fabric or change your install methods to avoid the scalloped look. After seeing how tight and flat this turned out; I am no longer seeing as much desire for the extended leading edge.
    Ed
    17,923
    It also depends on which generation of fabric you have. I have seen a lot of differences in the shrinking characteristics with the runs of fabric over the years.
    cubpilot2's Avatar
    May 2003
    Anchorage Alaska
    699
    I went back and re-read this old post.
    Check out the testing that was done. It explains it very well and my results were exactly what he achieved.
    Ed
    cruiser's Avatar
    South Glens Falls, NY
    1,390
    The 1991 Stits manual states the thread count at that time was equal in both directions. I would guess that would have a big influence on how the fabric reacts to heat.
    8,372
    That is correct, but if you start shrinking in the bay between the ribs the chordwise fabric will pull down between the leading and trailing edges before the spanwise threads holding them down creating the scallop.
    Nov 2002
    Fargo
    611
    Medium-5 is 63x75 thread count and heavy-4 is 144x57 these are the current products. Just messured the scallop on my plane with medium-5 covered in the blanket meathod and shrunk over the ribs 1st and it's 1/4" to 5/16" max and this is one of the best flying Cubs I've build or flown. Also messured a factory original 1976 cub I've got in the shop that has the original heavy ceconite 101 installed by the sock meathod and it's identical at 1/4" to 5/16".
    Attachment 32716
    Feb 2008
    STL
    245
    I'm getting close to placing my wing order from Javron and Jay is admandtley against the wing leading edge extension but I'm getting mixed reviews. Have you guys who have done it totally happy with it? Worth the weight?
    Blue Skies,
    Denny
    If you get lost while flying, don't try hail a cop. Pick up the first railroad you find and hug it until you get somewhere.
  1. landing recover
    By skysigns in forum Cafe Supercub
    Last Post: 03-16-2016, 05:38 AM
  2. Hrs to recover?
    By larrym in forum Super Cub Sick Bay
    Last Post: 08-24-2012, 10:18 PM
  3. Repaint or recover
    By chilecubdriver in forum Cafe Supercub
    Last Post: 03-22-2011, 10:22 AM
  4. Recover and Repairs
    By supercubc37 in forum Modifications
    Last Post: 06-13-2002, 04:12 PM
