mike mcs repair
Update: So I did just that... Using the heavy weight fabric we sewed the three strips together and using the old methods of attachments at the trailing edge. The difference in scalloping between the blanket method and this was amazing!
The photos below is of a cub covered with the heavy fabric in the blanket method (glued span size to the leading edge.) The scallops are 5/8 or more between ribs depending on the rib spacing.
With the "envelope type" method on the wing that I just finished in silver, the scallops are 3/32 to 1/8 inch deep as measured with a strait edge over the cap strip reinforcing tapes.
The Red wing is my 180 cub with the 12 inch L.E. extension.
I am no aeronautical engineer but IMO when you allow the vertical cross section of the airfoil to be reduced this way; that there has to be some difference in the lift component.
I would bet that if you did one wing with the blanket method and the other in the envelope; that it would be wing heavy as hell.
no...
It all has to do with the order of which direction you shrink it.....
