From my link above by the previous owner of my engine...before two subsequent overhauls. The thread goes on for 5 pages after:
"Hi,
I have a Taylorcraft, with a Continental C-85-12F that is overheating. It has an enclosed cowling, with tight fitting engine baffling. I was wondering if anyone has any suggestions as to what it might be. The motor was overhauled by B.J. Custom Aircraft in Palmer, AK in 1995 it has 450 SMOH. The lowest compression is 69/80. It is making no metal. The engine is running smooth, it has correct timing for the mags, 28 degrees on one mag and 30 degrees on the other. It has a Sensenich 76AK-2-42 Prop, brand new Marvel Schebler 10-4240-1 Carb, New Baffling, with inter cylinder baffling, Brand new accurate Oil Temp Gauge, lower lip on the bottom cowling that extends downward approx. 2". During test flights the temperature rose as high as 250 degrees on a 55 degree Alaskan Day, and the airplane only went to 2150-2200 RPM static on the ground and only went to 2200 RPM on the takeoff roll. As a byproduct of this the oil pressure dropped as low as 20 pounds. I have tried running different types of oil thinking that it could play some role in this problem, only to find that it makes no difference. I am completely lost as to the what the problem might be. It seems as if it should have plenty of cooling getting to the engine, but it is not he case. I am up for any ideas before I split the case to see if it is something inside the motor."
