Results 1 to 7 of 7
Thread: Super Cub Spaghetti Factory
    5,472
    Putting a new GNR-200 in an amphib - only other equipment is the xpdr/encoder and the Lake&Air gear warning module.
    Looks like crap in there - three giant black connectors, wires going everywhere, ends of wires clipped off and left hanging - yuk! Is this normal for older Super Cubs? Given that I am doing this as a favor, I am wondering if the effort to straighten this out is worth it? Putting the Garmin in is trivial - all I have to do is find power and put a BNC on the antenna coax.
    But egad! What a mess!
    1,415
    Pics? The three connectors go to what, exactly?
    Sounds like the result of poor planning on the initial install. I've cleaned out a lot of this type of mess over the years. I comes down to how much time you want to spend on it. Is it a safety issue? Does the owner even care?
    8,066
    it's those chopped off and still hot wires that get my attention when i pull one apart for rebuild... seen many!
    1,415
    Lol. The ones you see aren't as bad as the ones you smell.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    1,993
    Here is what mine looked like.
    Eddie Foy
    "Put out my hand and touched the face of God"
    5,472
    Yep. Ours looks like that. The Lake and Air gear indicator is part of the problem - the installer just coiled up the excess cable. So far, only one hot lead, but a lot of snipped ground leads. I am going to leave that, but I am surprised - putting these floats on was not cheap.
    The connectors are huge, round, black deals, and one of them is part of the gear indicator. Tomorrow I am just going to clean up a bit more, ans do the installation.
    Think a Super Cub needs a static system? The tubes are there, along with all the plastic barbs.
    1,415
    Most don't use a static system. Hard to justify the cost of plumbing in an airplane that leaks so much air that it knocks your hat off. I usually put some type of foam over the barbs to at least keep dust out. If you install transponder/encoder or similar equipment, plumb all of the static ports together to make testing easier.
  1. Factory-stock Super Cub?
    By CubCruiser in forum Cafe Supercub
    Last Post: 11-16-2015, 06:33 AM
  2. Factory Tour: Backcountry Super Cub, Revision 2
    By Aktahoe in forum In The News
    Last Post: 10-14-2015, 06:44 AM
