skywagon8a
SE Mass MA6
The Icon reminds me of this airplane, an Osprey II. A very easy and nice airplane to fly, although a bit heavier with a max gross of 1560 lbs. I demonstrated one at Greenville Maine one year.
The Brazillian SeaMax is the pick of the litter, it's already possible to build a very nice LSA amphib if you don't try to load it down with things only an ADD American consumer thinks they need.
I haven't flown any amphibs, but from years of reading articles and classifieds it seems the SeaRey is slow and heavy, the Rotax 914 turbo is just enough power, some are going to the Viking engine(Honda Fit) for more power. The SeaMax does fine with the std lsa engine, the 912 100hp.
The published empty weight is 200 lbs more than a SeaMax. The stall is 42 vs 36 for the SeaMax. The Max is sorta new, the Rey is an ancient ultralight-derived craft. The Rey hauls 158sgft around but stalls higher than the 130sqft Max.
Thread drift.
So say you make a mistake and turn into the box canyon. Too narrow to stand on a wingtip and pull it around.
What's the option?
With enough energy pull up and do a wingover, hope you manage it well enough to pull out before ground zero?
No one ever makes the call to crash land intentionally straight ahead although it may be the smartest choice?
Sent from my imitation glass cockpit using SuperCub.Org mobile app
I don't recomend it but if one ever does get into such a predicament pick a soft spot, it worked for me but your mileage may differ.It must be really hard to do mentally to commit to a crash landing but done properly...
We should practice 180's and learn what it safely takes for airspeed, bank angle, power, and wing configuration/flap deflection if equipped. Sometimes it takes turning one way then back the other (270* or less depending on terrain) to make use of the available airspace. Better to know something by experience than having to get it right the first time.
