sj
Staff member
Northwest Arkansas
May 3, 2017
Aurora, Oregon - Performance STOL, LLC. is pleased to announce receipt of FAA STC certification of the “Double Slotted” flap system for the PA-18 “Super Cub”. Performance STOL, LLC. is currently working towards FAA Parts Manufacturing Approval (PMA) by the end of July 2017, when certified production will commence.
The Certified Double Slotted Flap System is a bolt-on flap replacement system for the OEM flaps. It also extends the flaps inboard to the fuselage and has the optional provision to shorten the flap handle if desired. It is easy to modify the wing root fairings on aircraft not currently equipped with flaps extended inboard to the fuselage.
FAA approved flight testing has demonstrated a 3 MPH stall speed reduction at a considerable lower angle of attack. The stall speed reduction and reduced stall angle of attack make this modification ideal for “Bush” or off-airport operations and increases the safey margin of the aircraft.
Perfomance STOL, LLC. will accept orders for the STC flap system starting May 6th at 10:00 am. Pacific Time, and will be attending the 2017 Alaskan Airman’s Show and will be accepting orders at the show. Those not attending can refer to www.performancestol.com for ordering instructions. The sales price for the Certified Double Slotted flap system is $8,450.00 plus crating of $150.00. Shipping is F.O.B. Aurora, Oregon. A deposit of $1,000.00 is required to place an order, full payment prior to shipment. Deliveries will be first come first serve, and we will not be able to start until Performance STOL, LLC. receives PMA certification.
