Results 1 to 8 of 8
Thread: Steps for Floats
    snowyriver
    Jul 2008
    Alaska
    159
    Steps for Floats
    Hello all,
    Im building a set of Murphy floats and would like to incorporate a step in the outside floats to make climbing up easier. Montana floats uses them and I think I've seen another manufacturer as well. Any ideas on what I could use or how to make something? It's something I'd build into the side skin. Not getting any response from the Montana guys so I thought I'd check with the other experts. Thanks, Craig
    Apr 2009
    AK
    36
    Whipline amphibs have them- I'd bet you could order the step piece from them. Cut a hole in your side skin, rivet it in and be done. Or save some $$$ on whip parts and just build your own- it'd be easy enough to just copy theirs...
    6,645
    I have seen a thick piece of aluminum attached to the outside for this purpose. I do not recommend this method as it would be easy to damage yourself hitting it with your leg or catching it on something in the water. I should be easy to just cut a hole and build a box to step into in the side skin.
    Vermont
    80
    I've seen them used for climbing up the sides of motorhomes, and in pools. "recessed pool steps"
    What's a go-around?
    irishfield's Avatar
    2,852
    Come on Craig... you can lift your leg higher than that!!!
    You know, even on Bob's Elite with the Clamars I put on it not once did I ever use the built in step to get up on it. I find it more awkward than just making the leap... and you can't safely use it coming down, that's for sure!
    7,428
    This would come in handy getting out of the water also
    snowyriver
    Jul 2008
    Alaska
    159
    Glenn, That's awesome! Maybe I should go for a rope ladder! Wayne, I just like to complicate things. It just seems like an easy install at this point. Anyway, I ended up buying a kit of two from Keith at Montana. Comes with fiberglass step, two doublers and an internal cross brace for strength. $300. Easy. The only problem is the place I'd want the step is where I just put the hatch! #***%##! Anyhow, thanks to all who chimed in...even the smart Asses!
    Mar 2015
    36
    Atlee Dodge steps should work fine for floats or wheels.
    John
  1. How To Get A Trophy Hog In 3 Easy Steps
    By flagold in forum Sportsman's Den
    Last Post: 02-13-2010, 02:06 PM
  2. handles and steps for fueling
    By doc in forum Modifications
    Last Post: 07-18-2005, 09:07 PM
  3. my first baby steps..
    By Korb in forum Cafe Supercub
    Last Post: 03-10-2004, 09:20 PM
