Results 1 to 40 of 40
Thread: MT Composite Prop certified but Catto not certified
    Feb 2015
    160
    I am surprised that MT has been able to get a fixed pitch composite prop certified but Catto has not been able to do the same. I called MT and they said they didn't have an STC for a PA-18 but they did say they are always working on getting more applications certified. I wonder if MT is claiming that the fiberglass covering is non-structural. It is nice that they have a bonded on nickel leading edge just like the Catto.
    https://www.mt-propeller.com/en/entw/pro_fixed.htm
    Certified application:
    http://www.mt-propellerusa.com/pdf/stcflyer/FL035US.pdf
    Thanks suntiet thanked for this post
    Apr 2009
    AK
    96
    Professional pilots (Brian Sutton) has an stc for an MT on a cub. Are the MT's solid nickel LE now? The ones I've been around are a thin stainless steel "wrap" on the LE, and very susceptible to damage...
    Aug 2014
    16
    I think the difference is MT is spending the time and money to work through the certification process and catto isnt.
    I am building a pa-22/20 with an o-320 and would love to run a catto. Catto has had a survey on his site asking what certified aircraft the public would be interested in pursuing. It's been up for a couple of years. I have submitted to the survey a couple of times and even sent him an email with no response.
    It's frustrating because I have seen that you can get Catto for lsa cubs running O-320's. So the engineering is worked, they are flying and safe, and you can order the prop now. Just no faa stc.
    Neither Catto or the faa seem interested in changing any time soon. I think he is content being a small custom shop working with Valdez, IAC, and a small volume of LSA aircraft on unique projects. I guess you can't blame him. I think he is living the parable of the fisherman. Good for him. Too bad for us.
    4,278
    Maybe the solution is for you to use the experimental category and enjoy the freedom it allows. The only thing restricting you is you.
    10,258
    Certifying a propeller requires a lot of work and expense. I certainly can't blame Mr. Catto if he's reluctant to go down that road. And, bear in mind that there are actually two approvals required.....first of all, the prop itself has to be certified as an airplane part. Then, an STC has to be issued for each and every make and model of airplane that the prop would be used on.
    In the case of MT props, MT itself has got the props approved by the FAA, but it's often users/dealers who have gotten the STCs for installation of the props.
    In any case, approving a propeller on a certified airplane is a big deal, and I suspect Mr. Catto's business with the experimental crowd may be paying the bills. It'd be pretty hard for me to visualize how long it'd take to recover the cost of certification.
    But, I'll bet if someone on this forum is willing to undertake that certification, Catto might be happy to let you spend your time and money.
    Likes 40m liked this post
    4,278
    And his shop would need a PMA in order to sell the STC'd part. Another hurdle.
    behindpropellers's Avatar
    NE Ohio
    6,650
    Quality System
    Production Approval
    Approval to install the article on the product.
    Lots of work.
    1,394
    Is it legal to install a Catto prop on a certified airplane that's parked? When does it potentially become a problem...upon installation, engine start, or when moving under it's own power (like 14 C.F.R. § 1.1.)? The reason I ask is there's more than one Catto prop installed locally, but unless the FSDO folks detect some critical phase of operation they may be limited in their ability to enforce the FAR's.
    Jun 2008
    sioux lookout
    499
    Quote Originally Posted by slowjunk View Post
    the fibreglass on an MT is only a thin layer to protect the wood
    Aug 2014
    16
    Who knows maybe someone could pull together a GoFundMe campaign and fund the process.
    Or, AOPA will have a breakthrough with the faa on simplifying the certification process.
    There is clearly an interested market. Sooner or later Catto or someone else will break into the certified market. Until then we have to wait.
    18,286
    Catto has all they can do as it is so why spend several $100K to certify on particular prop on one particular airplane. I have met Craig Catto an I think he would be bored with that. However I did ask him if someone else put up the money and ran it with some sort of compensation for him would he do it. He said he would.
    Sent from my SM-N900V using SuperCub.Org mobile app
    Likes WanaBNACub liked this post
    May 2006
    308
    The 1A2 type certificate allows 'any other wood propeller that meets following...." to be installed on O235's and 0290's. So I don't think it's too much of a stretch to use the MT prop that gas been certified with the O240. Flange bolts and pitch?
    But the TC gets more specific with the O320.
    Aerodon
    Aug 2014
    16
    Ya that was the subject of a previous discussion and it headed into a conversation of whether a prop made from wood laminate was composite and whether a catto prop with a composite outside is really a wood prop. Some folks seem
    To be running a catto on their 290s and ha
    Aug 2014
    16
    . . . Had Concluded that catto is a wood prop with a cover. Interesting interpretation but like you said that language wasn't carried forward in the 320s, which is what I have. So the philosophical debate is academic for me.
    Sep 2012
    Bettles AK & Arizona
    288
    I thought ASTM was the new standard??
    8,980
    IN other places the key words are something like: with intent of flight.
    Rochester, NY
    93
    I've had a couple of MT props on aerobatic planes with mixed results. Both CS. The two blade eventually eroded behind the SS leading edge and had to go back to MT for replacement, on me. The three blade didn't have that problem but the finish eroded in a few spots. We were always told to avoid flying them in any but the lightest of rain.
    Jim
    Aug 2014
    16
    Interesting comment to remind me that composite has drawbacks too. It reminds me of sailing where Carbon fiber/Kevlar sails are technically better than canvas, but the extra performance results much higher cost, less service life and uv degradation. There are no free lunches.
    Aug 2014
    16
    Oh and one more question/comment
    Aug 2014
    16
    I thought the rain damage issue was addressed by adding the Nickle leading edge.
    10,258
    I ran MT props on a couple of seaplanes, where they were regularly exposed to spray and water erosion. They tolerated that issue far better than metal props. There was some erosion of the paint near the tips, behind the metal LE, but purely cosmetic. Those same props were used on skis in winter, and again they tolerated snow erosion issues far better than metal props.
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    644
    I would guess that Hartzell has 1000x more pull with their decades old FAA connections and could get a prop approved made out of spruce pitch faster than Craig Catto could get a proven professionally built one.
    Pure old politics again.
    As far as when it would become illegal, the only time that would be enforceable (and hold up in court) is if they actually sighted the airplane flying, and waited for you to land, to taxi it up and as you steped out, and tapped you on the shoulder. Imho.
    Sent from my LG-K450 using Tapatalk
    sjohnson's Avatar
    Boise, ID
    615
    ....As far as when it would become illegal, the only time that would be enforceable (and hold up in court) is if they actually sighted the airplane flying, and waited for you to land, to taxi it up and as you stepped out, and tapped you on the shoulder.
    And what, at any other time, if an agent merely asks when you installed the prop, if you flew with it, checks against the airframe lots, etc.? Lying is a felony, even when there is no underlying crime (ask Martha Stewart):
    18 USC 1001
    Except as otherwise provided in this section, whoever, in any matter within the jurisdiction of the executive, legislative, or judicial branch of the Government of the United States, knowingly and willfully
    (1)falsifies, conceals, or covers up by any trick, scheme, or device a material fact;
    (2)makes any materially false, fictitious, or fraudulent statement or representation; or
    (3)makes or uses any false writing or document knowing the same to contain any materially false, fictitious, or fraudulent statement or entry;
    shall be fined under this title, imprisoned not more than 5 years or, if the offense involves international or domestic terrorism (as defined in section 2331), imprisoned not more than 8 years, or both. If the matter relates to an offense under chapter 109A, 109B, 110, or 117, or section 1591, then the term of imprisonment imposed under this section shall be not more than 8 years.
    Taking the 5th in what should be an administrative procedure will be awkward.
    Aug 2014
    16
    Yep I would like to legally put one on. But, I don't think having your plane mysteriously show up at a fly In and arguing that it's legal as it sitssitting on the field at a fly in and saying that it is legal since it's sitting still will get you too far. And a bigger concern is if you have accident could insurance deny your claim if they find out that you were flying a non certified prop installed by the operator.
    Aug 2014
    16
    Sorry message was jumbled my fat figures accidentally hit send. But I think I made my point.
    1,549
    If the feds want to make a issue of a catto prop on a certified aircraft all they have to do is tag the aircraft as non airworthy. Once that is done you can't fly it until you have a IA fix the problem and sign it off. This is not a legal action on your record just a pain in the butt. Some don't know what one looks like, some do. Best to just keep it in a hanger and stay away from large events. From what I have seen up here most insurance companies don't look too close but it would suck having them deny you 90 grand policy.
    Jun 2009
    Northern Maine
    644
    Denny,
    That sounds right, they used to run around all the time red
    Tagging folks with big tires at Hood Strip......
    Steve. I hear what your saying, but I think the issue would be WHEN does it become enforceable, bolted on? Resting
    Ontop of the cowling? Or laying on the hanger floor. Obviously bolting it on implys you MIGHT fly it, it would certainly draw attention from them, and as Denny says, they could "red tag" it and even make you produce paper
    Work to prove it has been returned to service with a legal
    prop, but weather simply having sitting on a parked aircraft is somehow commiting a federal crime is a quite a streach. I really think it would likely involve a phone call and they would simply tell you to get it the heck off there or dont get caught flying it........... But maybe I missed something as I always figured you can do ANYTHING to your parked airplane??? I do see your point though. Fly Safe. E
    8,860
    Parts Manufacturing Authorization is the approval to manufacture approved parts. For some like me it is a big deal. Not something I can wrap my head around. However with the guidelines provided by the FAA, my wife whipped out the appropriate paperwork in a weeks worth of her spare time. The FAA was happy and I started manufacturing brake parts. The FAA did come visit me on an annual basis to check up that I was following procedure. The combination of the PMA and the STC is approval to manufacture and provide approved parts for installation on someone else's airplane. The exchange of money is not a concern of the FAA.
    The STC is the approval of the item for the installation on a specific airplane.
    Thanks CamTom12 thanked for this post
    Likes BC12D-4-85, 180Marty, alaskadrifter liked this post
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    299
    Talked to my insurance company and told them I was thinking of running a Cato prop. They said that the policy would be written experimental and the premium would go up 10%, other than that they had no issue as I recall the discussion 6 months ago. My -12 is certified
    Doug
    Likes cubdriver2, pzinck, 180Marty liked this post
    Jan 2005
    Fowler, Ks
    516
    Can a field approval be approved by a DER (outside the FAA)?
    I inquired about Catto prop approval and the FSDO was receptive and the first question was "Is there a existing field approval for this prop"?
    I had been in contact with Craig Catto and he indicated after I sent him some of my correspondence from my FSDO there may be a possibility for a field approval via outside DER. Once a field approval is granted installing a Catto prop should be much easier since precedent seems essential. No inspector will sign off this improvement without previous approval....it's the climate we live in.
    It was also the opinion of one of the inspectors that the 'any other wood prop' statement on the type cert was interpreted by them as 'approved wood prop' although the wording is much broader....
    What it came down to after all my communications was the phrase my parents used "Because I SAID SO"!
    Catto said they weren't persuing STC for the fixed pitch any more.
    Likes pzinck, 180Marty liked this post
    ND
    19
    Quote Originally Posted by flynlow View Post
    I would really like one of these for my certified 0320 SC on amphibs.
    In February they said to check back in May because as of then they were still seeking approval. They also said that someone was close to a field approval.
    Dano Bardwell's Avatar
    Jan 2004
    big lake Alaska
    203
    I'm reading CAR 4a.597 , it seems plain English too me , & im told this paragraph is why the Feds are sitting on their hands on GA installations . What am I missing here ??
    Aug 2014
    16
    That would be cool if someone got this done via field approval. I have run into that mindset as well. Everyone seems fine to issue the second field approval referencing the first one but no one wants to be first. I wonder if someone gets the first one done how much flexibility the subsequent folks will allow for deviations in length, pitch, engine, airframe. I wonder if field approvals may only help a small group of folks that happen to have a very similar rig and a willing fsdo. I am also hoping that the work aopa has done regarding stcs will be another pathway.
    Jan 2005
    Fowler, Ks
    516
    I was likely the one close to a field approval....Craig offered to come to my airport and do the vibration tests with my 0-290 and prop..in the meantime I decided to upgrade to a 0-320 so....
    Since then he has accessed lycomings vibration analysis for a number of engines..
    Craig and his daughters are the nicest people....
    Craig may have also been talking about his own PA12 as far as the field approval.
    Quote Originally Posted by ncyifly View Post
    Jan 2005
    Fowler, Ks
    516
    Quote Originally Posted by Dano Bardwell View Post
    May be the last few words of the paragraph...."are satisfactory to the Administrator"....my Cub qualifies under CAR 4a.597 also and I used that very sentence in the
    paragraph but the FSDO would not agree.
    ....anyway after feeling pretty optimistic about a field approval from a couple different inspectors that were researching my request I get the call "No....you can't put a experimental prop on a certified airframe" ....'because he said so'....i hate that!! They basically disregarded all the positive history of wood props dampening vibration...of the good track record Catto props have on Carbon Cubs, Van's RV's etc etc and denied because it has no precedent. Hopefully a outside DER will provide that.
    Aug 2014
    16
    Well let's keep our fingers crossed
    Sep 2002
    Southern NH
    449
    Our FSDO, which has been very helpful with field approvals, told us not to waste our time. They suggested working with the MIDO for a one time STC which would involve a DER, experimental flight testing , etc....
    8,860
    This is the pertinent part of 4a.597. Emphasis is mine.
    CAR 4a.597 ".....except that wood propellers of a conventional type for use in light airplanes need not be certificated."
    This is a link to Part 4a. http://specialcollection.dotlibrary....y=(select+101)
    Jan 2005
    Fowler, Ks
    516
    Amen brother!! this is exactly the chapter and verse I quoted to the inspector and his reply was "you can't put a experimental prop on a certified airplane".... I am not sure what the outcome would be if push came to shove on this sentence...I simply wanted to get approval before needing forgiveness.. I actually own a Catto prop that supposedly works great on this airplane but its sitting on a shelf until I am confident it is legal. I am flying a Sensenich currently and hate it. Since I am upgrading to the 0-320 I will almost certainly need a field approval.
    The inspector also mentioned insurance coverage issues..i haven't explored that with my insurance but possibly insuring it as a experimental would suffice??? I know i had one airplane totaled by a storm and another damaged this past year and the insurance company certainly checked to make sure my ducks were lined up neatly.
    Feb 2006
    Maine
    743
    When I was trying to get my Baumann amphibs approved my insurance (Avemco) let me put the 11 in experimental for market survey while on floats, this may be an option if Craig would agree to have everyone do market survey for him. My $.02.
  1. Catto composite prop survey on Catto website: take it
    By slowjunk in forum Cafe Supercub
    Last Post: 05-09-2015, 02:00 PM
  2. Catto 78" 54 composite prop for Exp. Cub with O-320 for sale
    By David.Bingham@cubcrafters in forum Experimental Cubs
    Last Post: 07-17-2013, 06:37 PM
  3. Replies: 26
    Last Post: 06-09-2013, 03:04 PM
  4. Certified or not??
    By NimpoCub in forum Modifications
    Last Post: 11-05-2011, 09:18 AM
  5. Experimental or Certified
    By Nathan K. Hammond in forum Tips and Tricks
    Last Post: 12-10-2002, 11:33 PM
