Results 1 to 8 of 8
Thread: PA 12 seat sling lacing
    Feb 2010
    Idaho
    231
    I have searched the forum, no luck. Help me out on PA12 seat sling lacing. I'm starting to have a helmet fire. I have the cord, I just am not sure how to lace it correctly.
    Sep 2006
    corvallis,or
    402
    I think you need to flip it around so the grommets in the middle are on the outside of seat. Then you fold top row of grommets over top tube and lace down to the second row of grommets. The row of grommets at the front of seat gets laced under seat to the row next to them. I hope I don't confuse you. Don't have a picture of mine to share
    9,808
    rarely have seen one that still has a sling seat not already replaced by plywood or aluminum
    Jun 2018
    England
    237
    Hi Mike, I’m just about to replace my rear seat slings with plywood, what thickness of sheet should it be?
    Cheers
    Phil
    9,808
    Quote Originally Posted by Philly5G View Post
    Cheers
    Phil
    I use aluminum with couple angle stiffeners. With lightning holes cut out. Probably .032 2024 T3 back and .040 floor
    Jun 2018
    England
    237
    Thanks Mike! How do you attach these to the tubes and front wooden cross member and could you post any pics please?
    I was thinking of just hinging the panels (if plywood) together and just using clips on the tubes and letting the front of the seat rest on the wooden member. If plywood, what thickness would you say?
    9,808
    normally you also add an underseat storage box under rear seat from stoddard(Landes or maybe carbon concepts makes one?)
    you hinge rear of bottom to/on top of rear baggage floor, assuming you have that?? a picture of what state your plane looks like with sling removed would help....
    this video not really applicable to your installation had some issues to over come because of doors on both sides... but gives an idea of the metal work seats.. also thin is a lowered floor version on the longerons I did, with extended baggage....
    Jun 2018
    England
    237
    This is how the (pretty much original I guess) rear seat frame looks without the slings Mike
ID:	41427Click image for larger version.
ID:	41428Click image for larger version.
  1. Rear Sling Seat question.
    By ak-flyer in forum Cafe Supercub
    Last Post: 01-21-2013, 10:47 PM
  2. Taylorcraft Sling-seat installation???
    By dreamer in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 03-26-2009, 09:09 AM
  3. Lacing the vert fin ?
    By jon in forum Tips and Tricks
    Last Post: 11-04-2005, 09:40 PM
