Lycoming Parts Book Help?
stewartb
MEMBER
Anyone have a parts book for the 360 series engines? I need the part # for the front crank seal retainer plates and associated bolts.
Thanks. Merry Christmas!
Quick PSA: I extended the time you can edit your posts and your subjects. You have to click "go advanced" to change the subject.
Just about every Lycoming (including the 360 series) calls for the same crank seal LW-13792.
<http://www.aircraft-specialties.com/seal-crankshaft-oil-lw-13792/>
Seal Retainer SA-641361
<http://www.aircraft-specialties.com/nose-seal-retainer-sa641361/>
-Cub Builder
I just checked and the PJ-260 site is no longer up. It had free downloads for a lot of engines. Too bad, was handy for those manuals on engines I don't have or service much.
I called Aircraft specialtys 2 weeks ago for these retainers on an Lycoming IO-360 I'm building. I didn't have a part #, they looked it up and said they were $130 each. I told them never mind. This part # shows $7, If you search it on superiors site it shows it's for continental engines, not Lycomings.
