Hi all. Not a Super Cub owner, but a recent owner of a Piper Pa25-150 Pawnee. I've been a lurker here for a quite a while so I know that alot of knowledge is shared here. Any advice at all here would be greatly appreciated. The Pawnee i recently purchased was stored in a barn for about 15 years, new fabric on fuse and wings at time of storage. Fuse was completed through Poly-Tone, but wings were only through Poly-Brush. Fabric on wings tested good by break test at Poly-Fiber in California. Sprayed two cross-coats of Poly-Spray on the wings and the silver really made the imperfections in the leading edges of the wings stand out. The wings were stored in the barn, hanging trailing edges up, and "grit" or some type of small particle got wedged between the fabric and leading edge skin, leaving tiny bumps on the leading edge under the fabric. I cut several small slits in the fabric to ensure it wasn't corrosion, but the aluminum leading edge skins are bright and shiny (minus the Poly-Brush) so no corrosion. What is the best way to remove the "grit" from under the fabric and still have an airworthy yet decent looking leading edge? Appreciate any ideas.
Kyle
Kyle
