power cord
The Drifter
I want to put a different receptacle from a 4 prong generator (4 wires) to an rv 30 amp 3 prong. 120 volts for rv. How do I connect the 4 wires to the 3 prongs. :roll:
We have lots of gensets. Any one I ever saw with 4 wires was more than 120 v
if your rv is 120 you should have a hot leg, a neutral and a ground
first thing is to get a multimeter and check output of the genset
an electrician holding it is a good idea as well if you aren't comfortable Once the
smoke comes out it's really tough to get back in. I have an employee who put 240 volts across
the 120 leg during an icestorm outage and smoked his freezer tv and all his lights
jim
https://en.wikipedia.org/wiki/NEMA_connector#NEMA_nomenclature
Figure out what type of receptacle you currently have on the generator and what kind of plug you have on the RV. 4 prong or 3 prong isn't enough information.
Speaking generally, it's never a bad idea to find a friendly local professional that can lay eyes on your contraption and offer guidance for few bucks. I'm not a professional electrician, or a professional anything, but I've seen enough botched wiring jobs to know that you shouldn't trust anything. That wire that looks white at the receptacle might magically turn into a black wire at the other end of the conduit. And it might be hot all the time.
I'm just getting past someone joining SC.org.. and then making a first post about wiring a genny ! As noted a 4 prong plug suggests 240 Volts + a neutral + a ground. You can grab 120v from either hot phase + the neutral (and the ground) to convert to 3 prong plug. Just cap the one hot phase.
A 30 amp RV has a three prong plug. One 120V hot, neutral, and ground
A 50 amp RV has a four wire plug. Two 120v legs, a neutral, and ground. The RV does not typically use the 240V available but uses the two 120v legs for a total of 100 amps available.
