Page 1 of 4 123 ... LastLast
Results 1 to 40 of 140
Thread: Earth X batteries, ok or not?
    Smith PA12's Avatar
    Oct 2015
    60
    I've ordered a new Earth X battery and now I am seeing a lot of posts about them burning up. Any new information on them, should we be putting them in our planes? is there an installation issue that needs addressing? if anyone has info on why they have burned up, I'd sure like to know.
    RCW
    Fort St John BC
    Bill Rusk's Avatar
    4,836
    I had good success with mine. No issues. Will replace it this winter (it got wet)
    Very Blessed.
    Thanks cubnut thanked for this post
    gdafoe's Avatar
    820
    I sure like mine. I use two for the EFII dual electronic ignition.
    Gerald
    Smith PA12's Avatar
    Oct 2015
    60
    bill rusk, gdofoe: any idea why the burning issues that some report?
    RCW
    Fort St John BC
    Upper Peninsula of Michigan
    335
    Quote Originally Posted by Bill Rusk View Post
    This quaint response deserves an "LOL" it did get wet didn't it? You are a trooper and an inspiration
    Smith PA12's Avatar
    Oct 2015
    60
    So I have to ask, How did it get wet?
    RCW
    Fort St John BC
    Bill Rusk's Avatar
    4,836
    I think when this technology was first introduced, there was a lot of confusion between lithium "ion" and Lithium "iron" . That one letter makes all the difference in the world. They are really two different chemical processes, and technologies, but the name is so similar that I think there were a lot of things that were misunderstood, attributed incorrectly, etc. The Li-iron technology seems to be a much safer (though somewhat less efficient) battery - and that is what the Earth -X is. I think some of the problems that the Li-ion batteries had were miss- attributed to the Li-iron batteries and thus sullied the reputation of both technologies and specifically the Li-iron batteries. I believe that most if not all the fires and runaways were in the Li-ion series of batteries ( I could be wrong, so please don't take my meager knowledge as the gospel) but you now have a couple of terms that are similar but different (Li-ion Vs Li-iron) to google search.
    Hope this helps
    ((tried (unsuccessfully) to turn a floatplane into a submarine))
    Very Blessed.
    Likes Jonnyo liked this post
    3,313
    There are some documented Earth X melt-downs on internet airplane sites. I hear there have been a couple here locally. My local instrument guy sold me an ETX900 a couple of weeks ago and told me the failures are attributed to improper charge rates. He knows my project and told me not to worry about it in mine.
    Earth X makes a nice Jump Pack. It works well, too.
    Yooper Cub rotto789's Avatar
    Mar 2009
    Mi. ( Yooper)
    194
    Ive been running my EarthX ETX36C on my experimental Super Cub for a full year now, I love it, no problems at all, the manufacture states that the service life is 3 to 8 years, if you do happen to run it down just make sure you charge it according to EarthX guidelines, 1A-5A charge rate, never exceed the max charge amp rate as displayed on top label of Battery.
    Rick
    1,716
    Never had a customer tell me about an EarthX burning or melting. I do know one aircraft that killed about three of them but it was a charging issue and no smoke/fire escaped from the batteries. The AeroVoltz batteries have had a couple of impressive fires, though.
    Although you can charge an EarthX with a standard automotive charger, the best charger for it is one of the models EarthX sells. They have the added advantage of having a special charge cycle for batteries that have been completely drained down.
    Dec 2004
    Inkom, Idaho
    1,073
    You couldn't pry mine away from me at gun point, it's not often ( make that ever) that you can lose 11 lbs for less then $400.00. AND get a much physically smaller battery also, mine's in otherwise wasted space between the rudder pedals of my kit plane. I just set it on the plywood floor right under the parking brake valve, it can't go up or down, two tiny little angle brackets keep it from moving sideways, simple). Putting it there means I also lost yards of cable runs, more weight saved, PLUS it spins the engine faster then the heavier battery. 4 years now I think, 200 hrs+ a year, winter and summer, way past the test phase, if it took a crap tomorrow I'd buy another ASAP.
    Thanks tedwaltman1 thanked for this post
    Likes Bill.Brine, kestrel liked this post
    gdafoe's Avatar
    820
    I use the one they recommend
    Gerald
    supilot's Avatar
    436
    I used a ETX36C and it developed a bad cell just outside of the warranty window. It was good up until that point though. EarthX would not replace it, but they offered 20% off if I wanted to buy again.
    Feb 2009
    67.8N,115.1W CYCO Canada
    730
    Had an ETX36D and recently, for no particular reason, replaced it with an ETX900. Both batteries worked fine and spun the O-320 faster than the Odyssey. The 900 has a fault indicator built-in as an extra precaution.
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    425
    Been running my EarthX for about a year now. Accidentally ran it down to the safety cut-off once on a road trip last November or so. Hand propped, then used the FBO's start-cart to touch the battery terminals so I could energize the alternator field, then flew home for ~2 hours and it was fully charged when I got there. I stopped watching the ammeter once we got underway, so I'm not sure how long it actually took to charge. No issues with that battery yet!
    Smith PA12's Avatar
    Oct 2015
    60
    Quote Originally Posted by CamTom12 View Post
    Am I to understand with the earth X battery,900 model, if I leave electronics on overnight and the battery drains to the point where it defaults and will not start the aircraft, that even after I hand prop to start, the battery will not charge with the aircraft running?
    RCW
    Fort St John BC
    Likes jimboflying liked this post
    1,716
    Quote Originally Posted by Smith PA12 View Post
    If the battery runs down past a certain voltage, an internal circuit will cut off any output in order to protect the battery. According to EarthX (see the copy/paste from their install manual, below) If you connect the battery to a charger that produces 12.8 volts or greater, it will recharge the battery. But note that some charger styles will not work. The chargers that EarthX sells have a sensing circuit that will automatically bring the discharged battery back on line.
    As for bringing the alternator on line with a handprop/dead battery situation, NO battery will bring the alternator on line if it's stone dead. If you are able to at least get the master to close, you can hand prop to start and simply turn 'on' the field and you should get the charging system to work. If you have a stone dead battery, it gets a bit more complicated if you don't want to fly home without electrics. The short story is that you need to prop the engine to start it and then get the alternator to come on line, with some source of external power, in order to start charging the battery.
    With a master solenoid, flip the master switch on then bypass the big contacts with something that can hold a short surge of power. If you have the old school primary/secondary master switch, just turn it on. Pull out all the breakers or fuses except for the charging system. Then you need to use a battery of some sort (even a flashlight battery or a 9V) and apply power, momentarily, to the field terminal on the alternator. As soon as the battery powers the field, the alternator will begin to charge and the master solenoid (if you have one) will close. Complicated but doable. Especially if you have leads and switch in place for just such a case.
    Problem
    Zero voltage at the terminals or un-stable voltage (voltage reading drifts slowly to zero). With a lead-acid battery, finding a very low voltage at the terminals often indicates the battery has reached the end of its life. With an ETX Lithium battery this may not be true. Possible Causes and Solutions
    The ETX series lithium battery has built-in over-discharge protection circuitry, which automatically disconnects the battery if the voltage drops below 11.5 volts (98% discharged). When the battery is “disconnected”, the voltage at the battery terminal should be zero.
    Some volt-meters may initially indicate a voltage, but it will decay to zero within ten seconds or so. For a drained battery, simply connect the battery to a charger to restore charge (charge with 2A for 20-30 minutes), and then re-check the voltage. If the voltage is 12.8V or greater, the battery should be ok and can be fully charged. Not all chargers will charge a battery that displays zero volts, so check our website for a list of compatible chargers, and specifically chargers that will work for recharging an “over-discharged” battery for which the BMS’s over-discharge protection has activated. This condition is sometimes referred to as a BMS reset.
    Likes pfm, Jonnyo liked this post
    Jan 2017
    Utah/Alaska
    24
    The earthx batteries are supposed to have a built in cell load balancer which is reported better than the aerovoltz. Tim
    3,313
    My ETX900 has a wire sticking out of the top. EarthX sent me a little LED battery status light to connect to the wire and put into the panel. If the light is on the battery is unhappy. Advance warning to pop the alt breaker and investigate the problem. Sounds simple enough. They also sold me a type-specific 110v battery charger. This isn't the same as other smart chargers I have for my AGM batteries. I don't know that I'll need it but it wasn't expensive and I figure I'll be using more EarthX batteries as my Odysseys wear out.
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    615
    If I read the instructions correctly, the newer version of the EarthX for aviation has redundant battery management systems. If the LED on the panel (there is also one in the top of the battery) is flashing, it's telling you the primary battery management system has failed and you are running on the backup management system. Yes, it's time to investigate when you see the light.
    -Cub Builder
    Jun 2008
    aviation
    27
    Hmmm.
    my EX36 will come back on line after a LVCO shut down with my self exciting EnterAv alternator. '61 PA22.
    None of that gymkhana a few have described upthread, well besides the hand propping. Somewhere around 2,000+ rpm. Don't know for sure cause my head is outside the plane where it belongs.
    It's been in my bird a couple years and I've LVCO'ed it an embaresing number of times.
    Rocket
    9,802
    Hope this helps
    Bill,
    Actually, I believe that lithium iron phosphate batteries are in fact one type of the generic group called "lithium ion" batteries.
    Techicalities, I know,
    gbflyer's Avatar
    Feb 2007
    PAGS
    663
    We got one that was a dud and a replacement that's been great. Very good customer service.
    DW's Avatar
    Dec 2002
    pacific northwest
    2,050
    I've had the ETX36C in my cub for about 2 1/2 yrs. now, it spins my 0-360 with high compression bullets better then any other battery I've had....no problems so far...
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    711
    My ETX36C also spin my 360 like there is no tomorrow, even in cold weather.
    kestrel's Avatar
    Southern NH
    250
    I have about a dozen starts now on my O-540/ETX900 combination. Some in cold weather and required a bit of cranking. It is working extremely well.
    Bearhawk, RV-4
    WhiskeyMike's Avatar
    West Boxford MA
    797
    Has anyone here or in a similar light plane had an actual fire or explosion?
    Mar 2011
    North Central AR
    615
    Quote Originally Posted by WhiskeyMike View Post
    I've not seen any fires from the batteries. I have seen the charging system damaged on a Jabiru with the damage credited to the EarthX battery charging demands. However, that is mostly due to the underdesigned wiring and connectors in the Jabiru charging system. The Jabiru is a 20 Amp dynamo type system that is not designed to carry a continuous 20 Amp load. The wiring connections are underdesigned. The problem with this charging system and the EarthX or any Lithium Iron battery is that while the battery can deliver huge amounts of amperage all at once, it also wants it back all at once once you are started and charging. If the charging system has poor quality connections, or a regulator or stator coil that will overheat at full load, then a Lithium Iron battery may not be the right choice.
    In the case of the Jabiru that failed, the dynamo charging system does not charge at idle. The new owner spent an inordinate amount of time on the run-up pad while working his way through the various menus in the Dynon SkyView system in his new plane. The battery was just about to the low voltage cutoff point when he finally pulled onto the runway for take off. Once the engine was spooled up, the charging system went full tilt trying to recharge the EarthX battery and continued to charge at 20 amps until the charging system went off line. The connectors between the stator coils and the voltage regulator had melted (common problem with the Jabiru at high charge) and the solid state voltage regulator failed (also not an uncommon problem). Shortly after the charging system went off line, the battery had discharged to the safety cut off, so the battery also went off line, as did the Dynon system (battery backup was misconfigured). This was the second time he had done this. The first time the charging system survived, but the battery management system on the EarthX battery had failed taking the battery off line. EarthX did warranty the battery.
    The lesson here is to make sure your wiring, connections, and charging system are properly configured to run at max charge as the EarthX battery will take a charge significantly faster than a lead acid battery, so can stress your charging system.
    FWIW, I have been really happy with the EarthX I have in my other plane. I'll likely switch the SC Clone over to an EarthX when the current AGM battery expires.
    -Cub Builder
    Thanks 180Marty thanked for this post
    jnorris's Avatar
    Wisconsin
    748
    Just make sure your charging system puts out at least 14 volts. If it's any lower than 13.8 it won't charge the EarthX battery. We found this out the hard way.
    Joe
    Likes FdxLou liked this post
    8,596
    Hey guys, reading up on batteries.
    It occurred to me while reading about charging that I still have a generator... yea, technology older than even SJ, but, when I had a dead battery I was able to get some power to my system once I was up flying.
    So, What can happen, or will happen, with these new batteries in a system using a generator?
    Likes Bender liked this post
    gbflyer's Avatar
    Feb 2007
    PAGS
    663
    Good question. There is a gal who works at EarthX, forget her name but she knows the products inside out. I'd suggest a call to them. My experience has been positive with them.
    9,802
    So, here’s a question: For those using the Earth X batteries in certificates Aircraft, what did you use for a basis for that installation?
    Barnstormer's Avatar
    Sep 2013
    Sterling, Alaska
    638
    Owner produced part. Used the “spec the part” side of owner produced and requested EarthX build it for me. Got lucky, they actually build a battery that matched my specs exactly.
    FdxLou's Avatar
    Apr 2004
    1,644
    Quote Originally Posted by gbflyer View Post
    Her name is Kathy. Very knowledgeable.
    Lou
    Thanks gbflyer thanked for this post
    8,596
    Just reading 41-13 on battery. There is nothing says must be certified. Just says different batteries for different uses. So- seems to me it is just a minor alteration to change from one battery to the next.
    Ok- blast away!
    Likes 39-J3 liked this post
    9,060
    Ok- blast away!
    2B (that part of 43.13) used to only be acceptable data(you could use it GET a field approval, maybe..)... before the rewrite of 43.13 in 1998? .....somehow 2B turned into approved data, much to the surprise of even my FAA inspector....
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    273
    What ever happened to Odyssey Batteries?
    That's the problem with the modern batteries, they last for so long the world's past you by when you come to change it out next.
    7,868
    Quote Originally Posted by Barnstormer View Post
    I hope that you speak in jest since that is most certainly NOT a description of "Owner produced part". If you are not making a joke, I suggest that you do a little research.
    Nov 2012
    Lake Lanier, GA
    877
    Li-ion or Li-iron. I would be very careful about putting anything lithium in an airplane without a charging system and electrical cutouts specifically designed. Lithium fed fires cannot be put out with any extinguisher you might carry. Boeing's solution to their fires on the 787 was to create a two inch thick stainless steel battery case machined out of a single billet. The design criteria was to allow the battery to burn itself out completely without fire fighting action.
    Likes yellowbird69 liked this post
    17,375
    If you read AC43.13-2B allows you to install a lead acid battery if certain criteria is met. It specifically calls out not allowing Lithium type batteries. Earth X is working on a certified version. From everything I have researched you are on your own installing an Earth X in a certified aircraft at this point, kinda like those Catto props.
  1. Garmin 296 batteries
    By supilot in forum Products, Purchases, Reviews & Prices
    Last Post: 06-01-2008, 10:53 AM
  2. batteries
    By Yard Dart in forum Member to Member
    Last Post: 12-04-2005, 11:05 AM
  3. batteries
    By Yard Dart in forum Products, Purchases, Reviews & Prices
    Last Post: 06-11-2005, 12:49 PM
