Results 1 to 6 of 6
Thread: Baffle Seal Pattern(s)
    Jun 2016
    61
    Looking for baffle seal patterns for a PA18-160. Anyone have a PDF or some measurements I might be able to follow to cut the individual seal pieces? Thanks
    9,955
    use a contour gauge and make what you need
    8,961
    Are you talking the aluminum, or the rubber?
    Rubber is easy... a drill, pop rivet gun, some rubber seal and a six pack of good root beer!
    Use industrial scissors to cut where needed!
    Aluminum... see MCS Mike's post above
    Jun 2016
    61
    The rubber seal(s) pattern is what I am looking for. Received message from one person recommending using cardboard cut outs to make templates. Thought that was a good idea. Any others??? Some great examples (pictures) on this WWW for what right looks like.
    Something that seemed puzzling in all the baffle / seal picture viewing I have been doing is the fact that some folks secure the seals to the outer perimeter of the baffle. Most secure to the inside of the baffle. Is one more correct than the other? Physics (air pressure) would point me to placing the seal inside the baffle. Thoughts...
    3,207
    Less likely to peel off the rivets that way.
    8,725
    Quote Originally Posted by elpcub View Post
    You have the answer.
  1. J-3 Bolt pattern
    By Taypay in forum Modifications
    Last Post: 06-11-2014, 03:43 PM
  2. Baffle Seal Thickness?
    By aerialimage in forum Cafe Supercub
    Last Post: 06-14-2012, 05:16 PM
  3. Inspection plate pattern
    By Glidertow in forum Tips and Tricks
    Last Post: 10-20-2006, 10:47 AM
  4. Sir...that was a right hand pattern
    By Lawn Dart in forum Lighter than Air - Flying Humor
    Last Post: 09-27-2006, 09:01 PM
