Actually there are bearing in the bellcrank. Cessna does not list them but there are a few dealers on ebay that have them.
Has anyone had experience in replacing them?
Tom
have not replaced that exact one, but usually 2 sockets and a bolt & nut get the job done in general...
In this case there is a structural gear box nearby. Use caution when cutting holes for structural reasons...Might be the best idea in the end. Does not take much to put an inspection/access hole and place a new cover over it.
....The throttle, although gets the most use, seems worn with numerous scratches on the knob.
The other two are covered in a colored sheath while the throttles spiral rap is exposed so it may be original....
Do all three and be done with it. Is there any reason to believe that these are not the originals?
