Page 1 of 2 12 LastLast
Results 1 to 40 of 58
Thread: Cruise speed for a 185
    Tom3holer's Avatar
    May 2012
    Cape Cod
    417
    I am very close to getting a 73 185. I will be flying it tomorrow,prebuy has been done but due to wx could not fly it.
    What power settings, down low, should I use and what speed should a straight bird indicate at 2500 feet?
    It has standard wheels and tires.
    Tom
    Meanwhile,...
    4,622
    Quote Originally Posted by Tom3holer View Post
    Tom
    Not quite a 185 but for my '77 180 on uncovered 8.50's with an IO520 and a 3 blade 88" Mac. at 2500 and 24 squared I see the mid 130's (knots) down low (just too much fat air to go fast), take that up to 5500 and it's the mid to high 140's and at 7500-8500 (the sweet spot) I'll be in the low 150's indicated.
    Hope that helps,
    Kirby
    6,054
    Faster than most Mooneys, right? I fly a 201 and get right at 160 kts/ 10 gph. I have only maybe 50 hours in the 185, but the stock 180 won't keep up with a Mooney.
    Meanwhile,...
    4,622
    Yea, yea yea, but in a 180 at least you don't have to sit on the floor and feel like you took a road trip in a MG when you get there and you can carry a truck load of stuff.
    6,054
    Understand, I think the early 180s are the finest light planes this side of a Cub. But if you want speed, they are not the best. I can keep up with a 180 in my Decathlon.
    Some will say if you want speed, get a Maule. Our B model Mooney would keep up with the 210 HP Maule and burn six gallons/hour. Pretty sure the Maule was burning eleven,
    Oct 2015
    263
    I know you guys won't be able to carry half of moose my 160 hp tailwind does 200 miles an hour on 7 .5 gallon
    8,630
    Tom
    Who cares? Do you like it?
    Density, temp, prop, load, pitot static system, indicator... so many things can make it weird, different.
    If you like it, fly it! Who cares what Kirby's and Bob's planes speeds is. It is about YOU enjoying the flight.
    Likes ron liked this post
    Meanwhile,...
    4,622
    Please remember to pull up from that dive you use to try and pass me as I haul 4 + luggage and a big Yeti cooler for a week at the beach...
    3,394
    Tom, depending on the prop, W&B, and your definition of cruise power settings? Around 160mph. You probably remember it'll be a little faster with some weight in back.
    8,630
    Quote Originally Posted by oldcrowe View Post
    please remember to pull up from that dive you use to try and pass me as i haul 4 + luggage and a big yeti cooler for a week at the beach...
    lmao!
    SB, seems to me 160 would be a tad high, but you might be right on small tires and no stol kit or vg's.
    I remember one conversation years back a guy saying the 180 he was flying was the fastest he had flown at 145 mph. It was cut for speed, all but wheel pants. had three tailwheel tires on it appeared
    3,394
    Mine at 25/2500 easily exceeded the 160mph structural cruising speed at 1000'msl when I had small tires on. With big tires and tailwheel I average around 145mph at mid weights and 24/2400 so I'd still expect to see 160 with small tires. Full throttle and 2700 with healthy prop and engine should make 180+ mph. Mine did. That's the test I'd want to run.
    Dec 2008
    18
    1976 model, 24 square, 17gph, 172mph (just into the yellow arc) shraight wheels, 155mph Fluidyne wheel/skis (I think) and a little over 140mph on EDO 2960s.
    1,953
    Not a 185, but when it's light my 53 180 is good for about 140mph down low, at 22 squared / 11-12 gph.
    6,054
    Okay then. Faster than Mooneys!
    Meanwhile,...
    4,622
    Bob,
    Enjoy your Mooney, my dad had one when I was growing up and he always said it's a good thing she's fast because after sitting on the floor for a couple-three hours it's like taking a road trip in an MG!
    Kirby
    Aug 2002
    Talkeetna Alaska
    216
    155 on W/Skis? That was downhill, eh?
    9,855
    Quote Originally Posted by Randyk View Post
    My thoughts precisely.....there were a lot of hours I wished mine would go that fast on wheel skis.
    May 2012
    3
    Pponked 180 here. Numbers in MPH, power at 2450/22"' 14-15 GPH, low altitude.
    160 on 8.50's
    145 on wheel skis with cargo pod
    135 on Aqua 3190's
    8,630
    I got my skandic super wide track up to 80 across the swamp not long after I got it running, (purchased as project). Was happy with such a heavy tub going so fast.
    When I got home I noticed the bottom of the speedo: KPH
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,515
    Quote Originally Posted by aqua View Post
    160 on 8.50's
    135 on Aqua 3190's
    Why so far under square? Thats rather inefficient.
    Tom3holer's Avatar
    May 2012
    Cape Cod
    417
    Flew it today: 2500msl 77degF it indicated 150 at 24/2400 which is very close to what the book says so I was happy and gave him a deposit and will pick it up Friday.
    Took a year of searching and looking at 9 airplanes.
    3,394
    Which tailwheel? It looks big on the picture on the other thread. Don't underestimate how much big tailwheels will
    slow you down. At any rate, have fun with your new plane. Congrats.
    9,855
    Excellent! Good job waiting till you felt comfortable committing to "the one". Congratulations, and enjoy it.
    7,943
    160 on 8.50's
    135 on Aqua 3190's
    That fuel flow seems very high for that power setting. If you were using 2400/24" it would be more correct.
    Barnstormer's Avatar
    Sep 2013
    Sterling, Alaska
    655
    Congrats Tom3holer! You will love it.
    My '73 A185F with a Lycon IO520D, Gami's, 86" 2-blade seaplane prop, 26" Goodyears, 13" tailwheel, Sportsman STOL, WingX, VG's, Strut cuffs, no rotating beacon:
    1,500 to 3,000msl
    23 squared 145mph indicated LOP 10 gph
    25 squared 165mph indicated LOP 12 gph
    Aug 2015
    Farmersville, TX
    273
    Now that's just downright insulting to MGs!
    Just kidding, of course... I drove an MG Midget (re-badged Austin-Healey Sprite) on an 1600-mile round trip in the winter on the interstate highway system. Not exactly it's "design mission"... Butt was sore for 3 days! Arms were only sore for a couple of days from trying to keep that tiny, lightweight car in its lane as 18-wheelers passed (or vice-versa - not sure the statute of limitations has expired yet).
    Meanwhile,...
    4,622
    Quote Originally Posted by JimParker256 View Post
    Ha I know the feeling, our family stable included at one time or another 5 Bug Eye Sprites, 1 TR4, 1 GT6+, 1 Spitfire, 1MG, 2 Morris Minors, 1 Jag, and a Mini Cooper S (a real one) and lots of English car jokes and more than one set of British racing green jumper cables, me I drove Jeeps.
    Aug 2015
    Farmersville, TX
    273
    Gee, that's a lot of Lucas spares you'd have to keep on hand...
    Had my share as well: One Sprite, one Midget, two different MG-Bs, one TR-4. But when they were running, they were a LOT of fun. The "B" was my all-time favorite, partially because it was (by far) the most reliable of the bunch. Ah, memories!
    Dec 2008
    18
    OK, 152mph or maybe ???. It's been awhile so I was going on memory, hence (I think). Then again, the tach might have been 50 low so 24 might have been 2450. Maintenance jokingly claimed that's why it was faster than everyone else. Basically a stock 185 with IO-520D and 3 blades.
    Aug 2002
    Talkeetna Alaska
    216
    Stock 185 with Fluidyne 3600's @ 24/24 = 125 kts or 140 mph all day
    7,943
    IO-550 powered 185 w/3 blade hartzell 24"/2400 leaned ROP 15.6 gph = 123 knots (141 mph) IAS at 1000 feet on amphibs.
    Bill.Brine's Avatar
    Aug 2012
    Massachusetts
    348
    Tom's new plane looks fast.
    85Mike's Avatar
    Washington
    487
    Don't know about various altitudes but on cross country, I always flight planned 14 gph and ran it 24 square. Usually ran 140 kts. and a smidge under 14 gph. 27 years of back and forth to AK. Stock '67 with the 520.
    Mike
    8,630
    Edos? With the Aerocetts I don't see 120 level. Run 115 most of the time it seems, and 15/hour is about right.
    Stock 67? As in IO-470?
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    679
    73' 185, 29" mains, bush tail wheel, two blade 86" prop (MAC) 23x23 ='about 120 mph, 15 GPH.
    L18C-95's Avatar
    May 2011
    London, UK
    395
    This talk of 185 is dangerous to my financial health, something the C90-8F Super Cub is innocent of.
    I have been coveting a 185B with this set up
    1 x CONTINENTAL MOTORS CORP IO-470-F ( MCCAULEY D2A34C58-0/S-90AT-2 )
    Unmolested with Tarmac tyres - not sure what it would cruise at, but the 182 delivers 125 KIAS down low and 22 square, so am guessing a few knots more. With fuel injection and GAMIs presumably the 470-F is the most efficient of the 180/182/185 series?
    I might not get SKI on the call sign so as not to upset the kids.
    7,943
    It's a 1976 on EDO 3500s with 12" wing extensions. When it had a IO-520 it was about 118k and averaged about 14.5 gph on a long trip. When heavily loaded that dropped to about 112k, sometimes less and higher head temperatures (bad). When running the TIO-520/intercooled (310 hp) it did 120k burning 17+ gph.
    Of the three different engine models and four different props which this plane has had, I like this one absolutely the best. The prop is the Texas Skyways Hartzell Bucaneer. Can't think of the model number right now.
    Tom3holer's Avatar
    May 2012
    Cape Cod
    417
    On the way back we were seeing 147-150mph at 23 Sq. at 7500 had it leaned to about 15gph.
    Thank you all for the postings.
    T
    Tom3holer's Avatar
    May 2012
    Cape Cod
    417
    Bill.Brine,
    Ok where was that picture taken?
    And your right, I might look into replacing it with a standard wheel. It seems rather tough to turn on my sod fieels as compared to my 58 180.
    Any thought from members on this XP bush wheel greatly appreciated.
    Bill.Brine's Avatar
    Aug 2012
    Massachusetts
    348
    Bill.Brine,
    Photo was Saturday afternoon at Cape Cod.
  1. PA-12 Cruise Speed with 180 hp?
    Last Post: 07-13-2016, 05:13 PM
  2. Cruise speed
    By Yard Dart in forum Cafe Supercub
    Last Post: 02-09-2006, 04:19 PM
