Page 2 of 2 FirstFirst 12
Results 41 to 63 of 63
Thread: Introducing a J-4 project
  1. #41
    Cub junkie's Avatar
    My Moms basement
    1,899
    Very nice. Is that some type of power window motor?
  2. #42
    Mar 2016
    Vermont USA
    159
    Yes exactly what it is.
    Regards, Charlie
  3. #43
    Mar 2016
    Vermont USA
    159
    Control sticks,
    Here is another part, My Control sticks differ from the original J4 a fair bit. The goal here as with all my control system is weight and friction. I seem to have not had my camera in the shop much as these parts were made so I have not captured allot of detail.
    Starting with the torque tube, I used my older Bridgeport table as a jig, this worked well. I will let the pictures talk.
    The roughed out stick assembly sitting on it's mounts as well as next to the original J4 part.
    In comparison my new assembly weighs 3½Lbs, the original is just under 10Lbs
    Regards, Charlie
  4. #44
    7,792
    Your work is beautiful Charlie, I often wondered why Piper made such a complicated stick setup when a single one in the middle would have worked just fine?
    Likes C-FIJK liked this post
  5. #45
    Mar 2016
    Vermont USA
    159
    The original controls had me baffled for years, I expect it was simply the technology and materials of the time. I quickly realized I did not want to cannibalize any of my original J4 so it remains as complete as it can be allowing me to simplifying my controls. Originally I was keeping them forward of the bulkhead although I am running the aileron cables up the front of the doors rather than aft of the cabin with all the associated buts needed. Another difference I am doing is running the and
    A few months ago after selecting the Carlson HD strut I realized the aileron aileron cable can run up through the lift strut with the bellcrank on the aft face of the front spar. This has moved the controls aft of the bulkhead simplifying many aspects of the system. This being why I have not formed the control sticks, they will wait till the fuselage is welded up and I can properly mock up the cabin.
    Another change is the push-pull rod for the elevator will be run under the floor all the way aft of the extended baggage. This offers a full flat floor quite a way back.
    I have also recently realized in my plane the center to center of the sticks will be wider than original, these sticks are 19" C-C where the original are 18". More recently from working with a mockup with the actual seats I am using I find the controls will be about 23" C-C so any further work on this system is on hold till I have the fuselage to work/ sit in.
    Regards, Charlie
  6. #46
    7,792
    Don't forget to do the Island Bob STC on the seat. Taking 3.5 - 4" out front to back makes a huge difference getting in and out of the plane
  7. #47
    Mar 2016
    Vermont USA
    159
    I should have looked at that better when up at Basin. My cabin area is a little different with standing the aft door uprights parallel to the front tubes. This reshapes the rear of the cabin and may well offer more access for entry. The seating and control layout truly will wait till the new fuselage is roughed out before many decisions are made. I will be utilizing a fixed bench seat although the rear of the seat will be split folding and probably offer a small amount of adjustment in lean angle.
    My right leg does not work well so the foot room upon entry does matter for me.
    Regards, Charlie
  8. #48
    Mar 2016
    Vermont USA
    159
    I have done the first actual welding on a fuselage part. I have made the spar carrythrough tubes. I was expecting to have made the full top of the birdcage over the 4th holiday but that was not to be. But it feels good to have started on the welded structure of the plane.
    Turns out I am lacking some of the material I need to connect these two tubes together so it will be awhile till I get much further. I do have some small parts to machine such as flap latch mounting, flap handle mounts and the sockets for the lifting eyes. I am going to utilize an X structure in this assembly and that will have some bent tube so I need to form those parts as well.
    Regards, Charlie
    Likes SpainCub, Tim, stknrddr liked this post
  9. #49
    Mar 2016
    Vermont USA
    159
    Last night I ran the printer so I now have a full scale print of the lower fuselage structure. This will be nice to have laid out on the build table. The line part of this drawing is a development of the tubing laid flat on the table. This will allow the initial layout and welding followed by the lower structure being jigged as it will actually be built.
    I also printed the firewall structure and outline.
    And a currently important view of the top of the birdcage, image here with the carrythrough tubes set in place. Also another image of a rearspar end fitting.
    Regards, Charlie
  10. #50
    7,014
    That is an interesting layout of the cross tubes. Are they curved in the original J-4 like this? I'm admiring your abilities with the computer drafting.
  11. #51
    Mar 2016
    Vermont USA
    159
    No, the original J4 ran a front Vee from the upper engine mounts to the center of the spar tube and continued the Vee back to the rear spar mounts.
    My structure will have 5 engine mount bolts and has the front Vee going from the top center mount up to the forward spar mounts. I have been through many design variations and I am settling on the flap handle being top center. That in some ways complicates things in that I still want the trim indicator top center as well. The center of this structure is tight to outer Lexan skin which is roughly 2½" above the carrythrough tubes.
    So I chose to build the structure with a little space for the indicator cable to pass through while maintaining generous structure for the mounting of the flap handle.
    This cross structure will be plated with a sheet metal structure as well as a center rib channel supporting the upper skin.
    This design may vary if I have trouble bending the ¾-.035 tube without distortion.
    Regards, Charlie
  12. #52
    Cub junkie's Avatar
    My Moms basement
    1,899
    I like it. Those spar carry throughs are going to be much more accurate than building a structure and attaching four wing attach fittings like the original Piper way.
  13. #53
    Mar 2016
    Vermont USA
    159
    That is for sure, these tubes setup in a jig with no fuss and allow all 4 bolts to be in the same plane. The holes are reamed to size while mounted in the milling machine with little chance of distortion as further welding is performed.
    Regards, Charlie
  14. #54
    7,014
    The load paths should be centered in a joint for maximum strength and minimum stresses. This drawing shows an eccentric load path which needs to be taken into consideration.
  15. #55
    Mar 2016
    Vermont USA
    159
    Yes, true. But there is other structure that is not seen in this print that reduces the twisting not to mention the only time the loads could get high enough to distort this area is in a crash. And in a crash, something has to give.
    Part of the unseen structure is the 0.100" Lexan top skin spreading the loads.
    If time allows this coming week I will see if I can pull a test bend, I might just scrap a section of tube and being I own the best bending equipment around here and not willing to travel 8+ Hrs for another bender this may all be for naught.
    FWIW I have this assembly already drawn in 4 other structure designs. With a few button clicks and a little updating the build is changed. The only parts locked down are what are photographed already.
    Regards, Charlie
  16. #56
    7,792
    It's a pretty tough little airplane just the way it is. Came with a great manual with foldouts in detail
    Likes skywagon8a, Jim Hann liked this post
  17. #57
    Mar 2016
    Vermont USA
    159
    A bit late to mention, someone on eBay has some J4 drawing available that appear to be real engineering drawings. Not truly knowing what they are I do not find the need to spring the funds for them.
    A decade ago I used the drawings Glenn shows here and drew the fuselage in ACAD. I expect my accuracy is no better than I could derive from the 3 versions of manuals I own. That print in Glenn's copy is pretty clean, easy to read.
    The plane I am building started from those drawings but has evolved from there as we will see over the next few years as I build this version.
    Regards, Charlie
  18. #58
    Mar 2016
    Vermont USA
    159
    A bit more work done, The top of the cabin structure is off the jig now. The X structure is different that the previously poster drawings showed for reasons stated later.
    This is a broad view of the structure,
    This structure included sockets for the lift eyes to thread into,
    I have a stainless threaded socket the eye screws into. this will be capped off for normal operations.
    In the center of the structure is the pivot for the flap handle, the notch behind these tabs is a passage for a trim indicator cable to pass, the original X that was shown had a space between the tubes for this cable as well as the flap release cable to pass through.
    As with most all controls the flap handle pivots on ball bearings.
    Regards, Charlie
  19. #59
    Mar 2016
    Vermont USA
    159
    Aft of the rear spar will be two 3/4 Sq tubes that are formed into a gentle S curve conforming to the airfoil. In these tubes are hardpoints for the flap torque tube pivots. In the center of the rear spar tube is a pivot for the flap latch mechanism. It is located overhead here for numerous reasons one being it is accessible in flight should there be any issues that need to be tended too.
    And could this be about the extent of true Piper influence here.
    Well not really.
    Regards, Charlie
  20. #60
    Nov 2016
    43
    Thanks for the inspiration, I have 3 planes in pieces, 2 my fathers and 1 that he inherited from my late grandfather in 2010. Dad has had a couple strokes since his father died and its been hard to deal with the changes in Dad from the strokes.. I need to get something started so I can get one of them flying while he is still around. Thank you for the spark of inspiration!
  21. #61
    Mar 2016
    Vermont USA
    159
    That is a worthy goal, I had hoped to get a plane back together before my dads passing 12 years ago, personally you got to make a try. Even if you do not fully achieve the goal you have a more comfortable life than the hollow feeling of not trying. My personal thoughts anyway. One for me was to see if I could have gotten my dad back up in a B-25 one more time. The one semi local B-25 to me was out west through all the years and my Dad had 99 missions in Air Recon way back in time so I was hoping for a 100th flight. Never happened but was well beyond my resources to have made it happen.
    Regards, Charlie
  22. #62
    Mar 2016
    Vermont USA
    159
    This part to me is a very thought provoking part. First image is a screenshot of the tube cluster where the lift strut and composite leaf spring mount. Nothing complex but as I machine the actual parts that once ready will be welded into these sub-assemblies.
    Even though the brackets have a 10:1 overbuild my mind keeps going, "all the lift loads are through here". It is kind of interesting how many stressed parts I have made in my life but for now these have my attention.
    Regards, Charlie
  23. #63
    Mar 2016
    Vermont USA
    159
    A little bit more done to the lift strut carrythrough but not ready for welding yet. Here is the bracket now with lugs to support the tubes.
    And same part with the doublers added, the aft tube is perpendicular so it got welded into place, the small tube passing through the doubler is where the aileron cable passes through and into the lift strut. The front doubler needs to be clocked which I am not ready to do, more parts to make such as the firewall structure to guarantee proper alignment.
    And the carrythrough roughed together, a bit more tube fitting before this is ready to weld.
    Regards, Charlie
  1. Our Cub Project
    By tcraft128 in forum Member Projects in Progress
    Last Post: 05-03-2016, 05:29 PM
  2. I need a new project
    Last Post: 09-03-2013, 09:10 PM
  3. PA-12 project
