I noticed that the circuit breaker terminals in my panel are are marked "Line" and "Load.". Is it critical that they be wired that way? What will happen if the line and load are switched?
I used to be religious about keeping 'line' and 'load' connected as marked. Then I argued with some of the fine folks here and decided to verify. I emailed Potter/Brumfield (now Tyco) and was told that it just didn't matter. He stated that the only reason they marked the tabs 'line' and 'load' was to get a UL listing. Said that they work the same, hooked up either way.
