Not sure why it's copying in bold.
But, if in normal operation, with the mag switch in the 'ON' position, the path between the wire from the primary coil, near the points to the mag switch, returning to the mag case is OPEN, how would the pulse travel along the P lead wire?
Wouldn't current only flow along the P lead if the mag switch was 'OFF'?
Thanks for the post Skywagon8a and wireweinie. I'm just trying to get it straight in my head. I've had that annoying tick before but was lead to believe it was an alternator noise not being suppressed. I'd love a separate thread on that please. :smile:
Due to age, alcohol and or jet lag, the electrical currents in my head are not the sharpest. Could someone explain Mike's comments a little more? Is it if the engine earth straps are failed there will be significant current from the alternator looking for a pathway? One possible pathway is from the engine, mag case, P lead shield and an arch on the mag switch to the P lead?? This still would not complete the alternator circuit would it. I'm missing something.
Also regarding the contecting of the P lead shield to the airframe. How would that complete the circuit of the P lead. That is from the Primary coil, out to the switch via the P lead core wire and back to the case via the mag case via the P lead wire shield. Wouldn't that circuit always be open, and therefore the mag 'HOT'??
Electricity!!! What fun.
