Results 1 to 39 of 39
Thread: The makings of the perfect Cub rifle!
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    After all the mountain hunts I have been a part of over the last 10 years I decided it was time to work on a new lightweight project rifle to strap on to the cub wing. I picked up a severely beat up old .270 Rem 700 village rifle from a trooper auction in McGrath and got with Derrick Moffitt from Last Frontier Custom Guns, LLC. I had been trying to decide on a good medium to long range caliber that packed a punch. There are hundreds of choices so it was pretty difficult, but I went with the .280 Ackley improved. The goal of this rifle wasn't necessarily to be the lightest rifle ever made, but to be a perfect balance of very light weight, accuracy, durability and functionality. I will update this thread as the build progresses.
    This old rifle was beat! Every part was rusted, the stock was cracked and the barrel had been chopped off with a hacksaw. It was the perfect donor for the action and the price was right!
    The weight of the rifle to start with was 6.5 lbs as is with no scope, rings or sling. I am hoping to get it to 6.5 lbs with the scope and sling but retain the #2 barrel contour for durability and accuracy. We will see how close we can get it.
    The barrel is a Bartlein #2 contour and will be fluted.
    The stock is a McMillan ultralight and will be modified slightly and dipped in a camo pattern of some sort when its finished.
    We stripped the original rifle right away and this is the only part that will be used in the new build. It weighed in at 14 1/4 oz before any machining.
    We started with a little lightening right away! Sure looks different than the beat up broken piece I dropped off!
    New ultralight fluted Gre-tan fluted firing pin along side the old one.
    And the new fluted ultralight bolt with some further lightening work done.
    The barrel was cut down to 23" and then ported, for 22" of useable barrel length.
    And then Fluted to shave off a little more weight.
    We also shaved down bolt shroud for a tad bit more weight savings and a custom look.
    And both sides of the receiver were ported and shaved as much as safely possible. There isn't an oz we could lighten it up any further without going to a #1 contour barrel and sacrificing a little too much in my opinion...
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,080
    Absolutely beautiful
    I have not desired a rifle like this since about ten years ago seeing a custom Rem owned by a friend
    Your project rifle has me thinking!! Thanks
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,213
    Looks good. If it were mine I'd cut and recrown right behind the ports. Porting is a ruptured ear drum waiting to happen.
    Jul 2002
    Anchorage, Alaska
    5,080
    .......Porting is a ruptured ear drum waiting to happen.
    porting can also provide a quick followup shot or seeing the bullet impact on the first shot....so I hear
    nd
    2,536
    Jewell trigger? I go to walmart and buy brand new 243 or 308 700s and take the actions out of them for 300 and some bucks and go from there. Ive got 2 of those McMillian lightweight stocks but there a little spendy so with the walmart stock from the rifle and a dremel and a little glass bedding there in my opinion just as good for basically free. And i bet just about if not as light as the McMillian. But please dont tell me you have all these machines in your garage to do this. Your action looks awesome. Did you weigh it after the machining.
    Thanks PowerAttitudeTrim thanked for this post
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,213
    Porting is certainly a subjective issue and shooters either love it or hate it. Personally I fall into the second category. Although it does attenuate muzzle rise during the recoil event it doesn't reduce actual rearward kick, and I have no tolerance for the painful screeching ears I'm left with after firing such a rifle. In my opinion a .280 is going to rise enough to preclude witnessing bullet impact whether equipped with porting or not. I've owned (past tense) ported rifles and shotguns and wouldn't have another if it were given to me. Shotguns are even worse offenders because you get all the noise penalty with no benefit because they don't generate enough pressure to make it work.
    I'm sure someone's going to mention ear muffs/plugs, but in a hunting or practical shooting situation I have neither the time nor inclination to put them on. With that I'll conclude my opinionated rant.
    Beautiful rifle in any case. I really like the flat-fluted bolt. The #2 is my favorite contour and the Gre-Tan striker is the first thing I put in a 700. I must say your original striker has a remarkably straight spring. Most of them look like a slinky that got stepped on.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    I have 3 rifles that are ported/breaked and several that are not. When it is all said and done they all will be. I don't mind the extra noise and found personally that it is not as bad as most claim, but for followup shots and when my wife and daughter are shooting it, they are worth their weight in gold. I can actually get my wife and daughter out shooting since I put a break or ports on my larger caliber rifles. My daughter drew a Unimak Island Brown Bear tag for May this year and will be shooting my .375. She shot it once prior to the break instal and hated it. She was pretty worried about the hunt, but now she is pretty confident after shooting it a few times after the break.
    Jewell trigger? I go to wallmart and buy brand new 243 or 308 700s and take the actions out of them for 300 and some bucks and go from there. Ive got 2 of those McMillian lightweight stocks but there a little spendy so with the walmart stock from the rifle and a dremel and a little glass bedding there in my opinion just as good for basically free. And i bet just about if not as light as the McMillian.
    We went with a Timney. My gunsmith has had several issues with the quality control of Jewel's he's installed lately. I am going to do the same thing with my next rifle. The price was right for this one and with all the machine work we were planing to do it was perfect. I agree with the McMillan stock vs the newer factory stocks. Probably not the quality difference for the price point, but they do have a reputation for a bulletproof stock. So for this particular build I decided to pay price...
    gregory's Avatar
    Jul 2005
    AK
    173
    Man thats going to be a nice sheep killing machine! I really like all the porting and shaving work. What optics are you going with? Did the trooper (Gibbons?)in McGrath give you any history of that rifle? The hacksawed barrel looks like I should recognize it, and no it wasn't mine.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    No, unfortunately I didn't get the story behind it. I am sure it was probably an interesting one! I am going with a Swarovski Z3 to top it off.
    Meanwhile,...
    4,257
    Sweet!
    "Don't feed the hipsters"
    Valdez, Alaska
    581
    In 1966 my dad purchased a Rem .270 identical to the one you started with, and ultimately handed it down to me. It by far is the best riffle I have, and best I have ever shot. Still use it over several new guns. It is old and accurate, and needs little attention...look like you have created a nice riffle.
    1,391
    Years ago I had a Winchester model 70 short-action carbine modified for the 250-3000 Ackley,
    and discovered that due to the sharp shoulder angle that it didn't feed very smoothly--
    if you threw the bolt in a hurry quite often the top round out of a full magazine would bind.
    Also discovered that due to the fatter shoulder it would only fit four in the magazine, vs five with the standard 250.
    Not sure about the 280, but the 250-3000 Ackley only gives you about an extra 100 fps --
    I like my little rifle but sometimes wish I'd just had it chambered for the standard 250-3000.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    Quote Originally Posted by J5Ron View Post
    I have an old Ruger 77 Mark II that I have had for 26 years. I have taken a tremendous amount of game with that rifle and it has been extremely accurate, but its heavy. My last hunt with it was my sheep that I took at 431 yards and my daughter shot her caribou with it and had a perfect shot at 179 yards. I am hoping to pass that down to my daughter one day if she keeps up her love for hunting.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    Took the already lightweight Talley rings down another half oz. Should be mounting the scope by the end of the week.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    Paul Reed of Alaska Hydrographics worked his magic on the stock today. He started off by prepping and sanding the stock.
    The base coat applied
    Prepping the tank with the film
    And dipping the stock
    And here is the finished product drying
    8,342
    Quote Originally Posted by WanaBNACub View Post
    adaptor for? silencer?? oil filter?
    Meanwhile,...
    4,257
    Nice pattern for rocks and vegitation, is that a gel decelerator pad on the butt?
    nd
    2,536
    https://mcmillanusa.com/mcmillan-rif...-hunters-edge/ A stock is like a fuselage, options, options, and more options and then you still have to make it the way you want it. But to build one and put a hole into another hole is as good as a 100 ft landing.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    13,337
    Very nice!
    7,849
    I love it. I live 10 miles from the home of Remington in Ilion NY and am not a Remington fan. Well the old 870s are the exception of course. You threw away 90% of what my neighbors built so you should have a winner when your done. Looks like your having fun with the build
    nd
    2,536
    Remember Glenn those factory remington 700s are as good as they come or ever well. Except for off a bench with all the goodies its not humanly possible to shoot better than the rifle, unless its been used as a crowbar. But still its cool to have something just the way you want it.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    Yes, it is a 1" decelerator
    7,849
    Only thing important is that you trust what your shooting and can place your shot where you want it. Who ever made it.
    Meanwhile,...
    4,257
    Excellent, that will help your daughter and as we say around my house "that ought to be worth a few diaper changes when the time comes!"
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    Timney Calvin Elite trigger adjustable from 8oz to 2.5lbs
    And the finished rifle ready for scope mounting
    This thing is a work of art as well as a precision tool!
    And finally the finished product heading to the range to break the barrel in and see how she groups before we tear her back down and send it out to be melonited prior to final assembly and her first hunting trip in Apr!
    don
    583
    Nice rifle And fun project ! Just bought a Savage 111 with Nikon scope, 270 left hand, brand new for $390. 7.5 lbs with sling. Pretty nice rifle for the $$.
    55-PA18A's Avatar
    Dillingham, Alaska
    497
    What's the final weight?
    What load/bullet are you planning to use?
    Loud ?
    What's your thoughts on accuracy?
    You're really going to strap that out on the strut?
    Hope you don't set it down on the tundra and turn around. It might disappear on you !!
    Jim
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    Quote Originally Posted by 55-PA18A View Post
    Loud ?
    Jim
    Final weight is 6lbs 13oz complete. I am going to work up a load for now based on Nosler 140gr Accubonds. This is the accuracy with off the shelf ammo of the last 7mm Derrick built.
    I would be happy with anything even close to that!
    Yes, I am sure it will be known to ride on the strut from time to time, and then on my shoulder or pack frame as soon as we touch down!
    Ill let you know on the loud part.
    Eddie Foy's Avatar
    Dec 2014
    South Florida
    2,171
    What was the final price tag?
    Eddie Foy
    "Put out my hand and touched the face of God"
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    $2700 total minus the scope
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    508
    Very nice, I'm wanting a lighter rifle for the mountains, my old 375 is way too heavy. Again very nice rig.
    nd
    2,536
    A very stick puppy's Avatar
    Nov 2014
    Norwood NY
    85
    Tempdoug - if you get a chance check your inbox. Thanks.
    Feb 2006
    Maine
    701
    Nice looking project hope it shoots as good as it looks, I am like don d bought a savage 110 30-06 a few years ago put a leupold 3x9 scope shooting 125 grain ballistic tips through it. have fired 5 shots through it, 1 nice buck and 3 deer killers two in the last five days all 200 yards + needed a follow up yesterday as the dog was facing me on first shot. Eagle is on dog from six days ago.Click image for larger version.
ID:	24883Click image for larger version.
    gbflyer's Avatar
    Feb 2007
    PAGS
    612
    Been following you on AOD. That's cool! I wish I had those machining skills.
    Interested in reading what you think about the Timney. I ordered a Borden Alpine for a project and had him include the Calvin Elite. I have 3 Jewells and have never had any problems, I just don't see the advantage for a hunting gun set in pounds as opposed to a bench gun set in ounces.
    Really like the McMillan and will use the same for my Borden build. Probably paint it myself though. I've been using Axalta Mastertint Vinyl. Like it.
    My finished Winter Whelen project:
    7,849
    Quote Originally Posted by gbflyer View Post
    I had a 35 Imp Whelen 98 action on a lite sporterized stock and solid butt plate.That darn thing kicked harder then 2 mules
    gbflyer's Avatar
    Feb 2007
    PAGS
    612
    Hahahahahaha...yeah this one bites a bit too. It's a little over 8 lbs.
    WanaBNACub's Avatar
    Aug 2012
    Eagle River, Alaska
    428
    That looks great! So far I love the trigger! I think you will like it!
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    364
    Nice looking outfit, hope it is a shooter! Wasn't many years ago to really get dailed in ,you just had to blueprint
    The receiver, square up the barrel true to frame, install custom triggers etc , to get into the big league.
    Not so much nowadays, here is a Tikka T3 in 6.5 x55 we have put
    Together for long range stuff. Back in its factory camouflage stock and factory mts and a Leupold 3x9 VX3 CD'S, it weighed 6lbs 15.5oz....
    Only mods we did is trigger tuned to 24 oz,bolt handle, and Boyd's stock.This gun shoots quart Soda bottles at 400yds, milk jugs at 750yds, and 128oz Tide Containers at 1000yds.
    The target is a 2 Shot group from a cold barrel at 300yds.
    50gr RL26 , Berger 140 VLDs at 2825 fps. Factory right outta the box........
ID:	30295   Click image for larger version.
ID:	30296   Click image for larger version.
ID:	30297   Click image for larger version.
ID:	30298   Click image for larger version.
  1. A perfect fit.
    By 16-bravo in forum Cafe Supercub
    Last Post: 11-06-2009, 05:04 PM
  2. Better than perfect. What if....
    By oldbaldguy in forum The Art and Science of Flying
    Last Post: 10-21-2007, 02:23 AM
