BENEFACTOR
Have not heard anything about the FAA's Unapproved Parts Notification against Dan's Aircraft for using unapproved fabric in the covering of certified aircraft.
http://www.faa.gov/aircraft/safety/programs/sups/upn/media/2016/UPN_2016_20150609004.pdf
An owner caught up in this contacted me quite some time ago about this issue and recently I found out that even after his airplane was recovered the FAA revoked the airworthiness certificate supposedly because through the investigation they discovered that the airplane was built new around paperwork with all new parts.
If all is true I can't imagine someone using uncertified fabric, not that big a price difference and the uncertified fabric I have played with did not glue or shrink near as well as certified. I can't understand the FAA revoking airworthiness certificate either, I thought I could replace every part on a certified airplane if the part is approved. Seems there is way more to this story than meets the eye.
