Hi guys,
So... I have removed my old bungees. I could have just cut them but I decided to remove them with the hoist to see if the technique works fine, as a first experience before I manipulate the new bungees
Well, it works fine ! Even for a woman alone (well, if you do not count the dog. The dog is the supervisor).
The ropes I used look thin but those are very strong little ropes used for sailing boats (competition stuff). And I used heavy chains and boat fittings.
It was important that I put a piece of wood between the ropes to spread them appart, and I gently applied some pressure with a screwdiver to help the bungee slide on the other side of the strut's ear.
So I opened my struts.
Obviously one of them was replaced at one time or another in the airplane's life, and the other one is probably 65 years old. You can see the old dark-green military color of the paint and some reinforcement welded that are probably an "improvement" from the French Army (as they have this tendency to always think that they absolutely have to improve things even when they do not need to be improved...).
The newest one could slide freely and still had some grease. I do not see evidence of a corrosion concern.
The old one... was like stuck, I had to force to separate the two parts (but I finally could do it by hand). I could see some rust even without removing the bolt. The bolt was a nightmare to remove, I needed penetrating oil, vice, tools, hammer... When I finally removed it, is was rusty, bent, damaged.
The female part of this old strut may be still ok. This is something I will make sure tomorrow after a night with penetrating oil to clean it and a borescope inspection.
But the male part is very rusty and will be discarded.
I could not even remove the stuff from inside the tube as it is so rusty !
I need help from the Supercub community for 2 things.
Inside, the leather bumpers are still there (well I will replace them of course).
There is a metal part that is sliding inside the tube, between both leather bumpers, in which there is a hole for the fastening bolt.
I want to order it as well but it does not appear on the parts catalog ?
My other problem is the bolt itself. I want to replace it on both struts but I could not find it on the parts catalog either. It looks like an AN4-something.
Does anyone knows ?
(Piper 18, year 1951, S/N 18-1429, no hydrasorb, used to be equipped with a 95hp engine)
Some would say that I am not lucky to discover this.
Well I consider myself as very lucky !
At least the disassembly was not useless, and today I may have saved myself from an off-airfield nightmare with prop strike and big damage
So that's cool 8)
Happy landings to all
Alexandra
