Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 241 to 280 of 370
Thread: Wildcat Cub
  1. #241
    Tony flyrite's Avatar
    Mar 2013
    Lyons,GA
    125
    AWSOME BUILD , Thanks for the journey
  2. #242
    aktango58's Avatar
    18AA
    8,630
    Wow! Just wow. She is beautiful.
    Are you going to make a set of skis special for this bird?
  3. #243
    3,394
    Ultimately it'll go onto hydraulic wheel skis. I'm not an Airglas LH fan but I may use them since they're local and easy. I may go with Rostis. Better ground clearance and about the same cost last time I checked. Not a priority at the moment.
  4. #244
    3,394
    Light it up like Christmas.
  5. #245
    Meanwhile,...
    4,622
    That ought to do it...I like ‘em both!
  6. #246
    8,985
    Yea, strobes are great till you get stuck flying next to someone who has them.
  7. #247
    Mar 2016
    Vermont USA
    394
    Great looking build Stewart, I have enjoyed watching along.
    A little of my opinion on locking nuts and washers. A locknut be it all metal or a "Nylon" when on a stud is only as good as the stud is into the base material. If the stud just releases from what it was in it does not matter what kind of nut was on it.
    Lockwashers, I have always been frustrated by the common split lockwasher, so many times it cuts into either the base material or into the nut itself. PIA when you have to do unexpected restoration work when on what should be a simple 10 min part swap. No one likes being charged an hour when it is expected to be a 10-15 min job.
    Nord-Locks, I have been working with these going on 20 years and I will gladly do so forever. There are times they overgrip and disassembly is challenging but I have not needed to do restoration due to a washer cutting a deep gouge in the material. They sure work better than wave washers that best I can tell just keep the failed nut so it can be reused again.
    Back to lock nuts, I tend to only use them on bolts, not on studs simply due to the fact the stud may come out on it's own. A lockwasher does a great job of reducing that possibility, the nut just rides with the stud.
  8. #248
    3,394
    One of the things most guys here won't understand is that in a build like this one there are so many unanticipated conditions to deal with it wears the builder out. How do you make an airbox for a fuel injection system you've never seen and fit it into the nose? How do you mount a filter? How do you make an alternate air source when there's no room for it? I asked several past builders about their alternate air solutions. You know what I got? Nada. Not a single answer or picture. That's been the most disappointing part of the build experience for me. The lack of shared information and experience among the builders of similar airplanes. I was determined to change that a little and share mine so others could get an idea of what's involved. Funny how a very crafty solution to the alternate air door on my plane has drawn so much interest over a nylock nut. A nut on a bolt that serves as a shaft to attach a looped end of a push pull cable to and will never see any tension, compression, or shear. Is it the ideal solution from an engineering standpoint? Probably not, but it's an acceptable solution given the conditions. The chance of me needing alternate air is very small. The consequence of the door opening inadvertently? None. If that nut backs off and falls out? The cable will likely stay right where it is. Much ado about nothing.
    I am very impressed with the Nordlock demonstrator and am hoping to get my hands on some of their new X series cupped washers for my exhaust studs. For airplane applications I can't think of a better product or a better place to use them. So far I can't find the cupped version and will settle on the standard Nordlocks. I'm surprised I haven't heard of these sooner.
  9. #249
    Sep 2002
    Southern NH
    399
    There are lots of different personalities on this site, and I suppose every other open forum out there. I truly believe most are sincerely trying to help, and then there are those who just enjoy stirring the pot. Just part of our on line society, for better or worse. My very first post 15 years ago was asking about STC's for putting 18 tail feathers on my J-3. The response was overwhelming- all criticism of my choice to change them, and no answers to my question. I didn't post again for quite some time. I tend to use PM's a lot now.. I'm glad your posting and hope you don't stop.
    Mark
    Likes RaisedByWolves, Scooter7779h, 5nines liked this post
  10. #250
    jrussl's Avatar
    Jul 2005
    Madison, WI
    425
    Stewart,
    Please keep posting! While I don't chime in much, I am thoroughly enjoying watching your build and all the craftsmanship that you and Mike are putting into your new cub. When I see that this thread has an update, it is one of the first I click on. Thanks for all your efforts to put this info online.
    Planning to spend the month of July +/- in Alaska this year with my SuperCub. Hoping to see your creation firsthand.
    Jeff
    Likes cubdriver2 liked this post
  11. #251
    3,394
    Mike has a philosophy that web forums have a high noise to signal ratio. He says when the noise gets deafening, be the signal. Sometimes it's easier said than done.
    Thanks for the encouragement.
    Likes mam90, Farmboy, RaisedByWolves, WanaBNACub liked this post
  12. #252
    Mar 2013
    Lyons,GA
    125
    I like Mike's advice, I , like you find it harder said than done. On the silly issue of the Nylocks......When I see a build that demonstrates the quality yours has, I just take for granted that The guy Who did it knows the "first oracle" stuff like that and figure he has contemplated the consequences as well as he didn't get to the point of completion you did without addressing the basic stuff!
    Again, Great job , Now let the fun begin and bring that thing down south and let's put it to use on some bars.
  13. #253
    9,199
    Quote Originally Posted by flyrite View Post
    I like Mike's advice, I , like you find it harder said than done. On the silly issue of the Nylocks.........
    most likely the same FAR's that say you can't have a fuel line near a wire or above it.... which EVERY cub has...
  14. #254
    3,394
    Under seat. Another cool exp aircraft product. A smart controller for electric trim joins my high point brake bleeders and fluid reservoirs. IMG_4356.JPG
  15. #255
    2,976
    Are you using trim tabs rather than moving horiz stabilizer? If a moving stabilizer, what are you using for servo? The web page says 1 amp max output. Maybe that's enough to operate a jackscrew motor???
  16. #256
    3,394
    The HD model is rated to 10a and has dual inputs/outputs so can be wired for more. No jackscrew in my plane, just a linear actuator, and the current draw and voltage drop were concerns. TCW says it won’t be a problem and provided instructions for my application.
  17. #257
    7,943
    No jackscrew in my plane, just a linear actuator.
    stewart, Does that linear actuator have a fail safe mode? Enough so that it can not move unless power is applied to it? I'm reminded of the trim screwjack failure of the Alaska DC-9 when it turned into an ocean dart in California.
  18. #258
    3,394
    I remember the accident. I knew someone on that plane. I think the lesson learned from the investigation is that all of our full trimming horizontals require inspection and proper maintenance. I was taught a long time ago to grab the horizontal's leading edge and give it a stout up and down test during pre-flight. Any play or movement is cause for staying on the ground. I'll continue that habit with my new plane. My bigger failure concern is in the little rocker switch on the stick that controls the trim. It's easy to imagine that switch getting stuck. The 3 second timer in the Safety trim along with the reversing feature manages that concern.
    http://www.supercub.org/forum/showth...Trim-Explained
    http://lessonslearned.faa.gov/ll_mai...LTypeID=2#null
  19. #259
    7,943
    Thanks, This https://www.youtube.com/watch?v=NEcG3dkZyTg explained it. You do have a jackscrew. That is as fail safe as possible.
  20. #260
    2,976
    Stewart, looks like a good arrangement.
    I have two questions -
    I don't see the model # from your photo listed on the Safety-Trim website. Do you have a link?
    Would you mind sharing what linear actuator you're using?
  21. #261
    3,394
    Safety Trim- http://www.tcwtech.com/Installation%...12v-2sp-HD.pdf
    AEI actuator- http://64.85.11.101/product/6112ch/
    For whatever reason the AEI website is down right now. This actuator is rated at 1000#. There’s a post with the data sheet in the electric actuators thread I linked above in post #258.
  22. #262
    2,976
    Yes, I saw the data sheet, but it's for a variety of models.
    Yikes, 12" travel, and 1000 lb force? I'd be interested to know why those parameters were selected. Total jackscrew travel on my 12 is about 3 1/8". And at 1000 lb, if all the fail-safe stuff fails, something is liable to break rather than just trip a breaker. Do you happen to know the answers to those questions / concerns?
    Another question, what are you using for position indication?
    Thanks!
  23. #263
    3,394
    Wildcat Cub
    I don’t know what the actual stroke is. It has limit switches but I have no idea what they’re set to. I’ll find out soon. Jeff Lefore’s yellow and black Rev 2 seems to work pretty well.
    The actuator has a string potentiometer mounted to it and it sends a position signal to the G3X. We used a similar string pot at the flap bell crank so actual flap deployment (including blow back) will also be displayed on the G3X.
  24. #264
    2,976
    Got it, thank you.
  25. #265
    3,394
    CH6106 is what's in the plane. 6" total stroke.
  26. #266
    Feb 2004
    Mt.
    1,246
    Lets all chill out and have a new discussion on DOWN WIND TURNS.... great looking plane Stewart, vans airforce is a pretty good source for E-AB ideas....I’m having fun building a RV7
    agpilot
    Likes mike mcs repair, OLDCROWE liked this post
  27. #267
    3,394
    I like Cubs because they're simple airplanes.
  28. #268
    Cub junkie's Avatar
    My Moms basement
    1,970
    I thought a full electrical system was two magneto P leads. Looks like I was mistaken. Nice work.
  29. #269
    3,394
    A G3X Touch looks elegant and simple from the front but there's an awful lot going on behind it. And a crapload of breakers and switches to support it. Not exactly what I had imagined. Not complaining, just sharing.
    Likes WanaBNACub liked this post
  30. #270
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    342
    Thank you for the linear actuator vendor & part # Stewart. I wonder why Backcountry switched from using Firgelli Automation linear actuators to DCAcuators? Big difference in both actuator total weight and force.
    Thanks OzAK thanked for this post
  31. #271
    3,394
    Can't say. AK Tahoe's old plane had a smaller actuator so the change happened between his and mine, and no Rev 2s were flying during that time.
  32. #272
    2,976
    I've noticed this elsewhere, and I'll make a guess - - The higher force actuators have a slower linear speed. That might be more desirable for trimming. My guess is that in this application operating speed is governing, rather than operating force. As long as operating force is adequate, of course. And I have no idea what the required operating force might be.
  33. #273
    3,394
    My Safety Trim has a panel switch to select high or low speed for the trim servo. They also offer an airspeed switch but I didn't choose to use that option. 2 speed electric trim is common.
  34. #274
    RVBottomly's Avatar
    Sep 2017
    Asotin County Washington
    204
    Reminds me of back in the 1980s a flight instructor at Gallatin Field told me he'd give me a nice looking red International Harvester pickup if I'd tow it away. Mice had eaten the electrical system. It had something like 60k miles and a big 308 engine.
    I took him up on the offer, took my free truck home, and wired it up with a spool of 12 gauge auto wire. No harness, just direct wiring with in-line fuses.
    I thought it would be a simple job of just powering the starter, coil, lights/signals, and heater fan. There wasn't anything else to run. But it still ended up like a rat's nest of wires. I identified the wires with plastic tape and permanent marker, which of course faded after a year or so. But that old truck lasted me years until the camshaft broke.
    But, Stewart, you've completely derailed and inspired me with what you are doing. Now, instead of holding my fingers to the grindstone for profiling tubes, I'm starting to look at Garmins etc. At first I was thinking of adding a G5 and keeping everything else basic. Now I'm sketching out autopilot servos and G3x touch. I mean, "why not?"
    Of course, it helps that my wife is asking if we can make routine trips to Seattle as well as the coast. Then there's talk about trips to Alaska to see her daughter. She says, "you'll have instruments, right?"
    Who am I to argue?
    Between watching your beauty and CharlieN's ideas, I'm afraid I'm wandering down that path of a permanent state of "something even better."
    Really, though, I very much appreciate seeing what you are doing.
    Likes mike mcs repair, jprax liked this post
  35. #275
    Mar 2016
    Vermont USA
    394
    You only want to build it once, and live with it forever.
    Even if not "everything" goes in during the build, it is nice to have considered it and make provisions for changes in the future. Granted we can not plan for "everything" since the world will always offer more in the future.
    Likes mike mcs repair, Dave Calkins liked this post
  36. #276
    3,394
    Mike had a desire to try his hand at anodizing. Holy crap, what a nice result! My custom milled brake reservoirs are now custom blue. Very cool.
  37. #277
    RVBottomly's Avatar
    Sep 2017
    204
    Very cool indeed!
    Funny how just earlier this week I was reading up on anodizing and looking for a reason to try it out.
  38. #278
    3,394
    Mike sent me youtube links about anodizing. I’m a carpenter. What do I know about anodizing? Here’s my fav video.
    https://binged.it/2HuWhFY
    Thanks Dave Calkins, RVBottomly thanked for this post
  39. #279
    3,394
    Wildcat Cub
    Superior's IO-400 crank. Beefy! With 100ci cylinders maybe that's a good thing. There's no replacement for displacement!
  40. #280
    3,394
    Wildcat Cub
    Prop's on. Progressing nicely. This prop sure has some twist in the cowl inlet area. No wonder Whirl Wind has the reputation for better cooling.
    Sent from my iPhone
