Page 1 of 2 12 LastLast
Results 1 to 40 of 70
Thread: Challenger Reusable Spin On Oil Filter
    16,282
    Has anyone used the Challenger spin on oil filter. I see it has a magnet installed in it, is easy to disassemble, inspect and clean. Looks like retail from Aircraft Spruce is about $250 which would pay for itself in 12.5 oil changes not counting labor to cut and inspect. I just ordered one and will see how it works but was curious if anyone had any experience with them?
    http://www.challengeraviation.com/newproducts.html
    https://www.aircraftspruce.com/catal...erLifetime.php
    txpacer's Avatar
    Jun 2011
    Iowa Park, TX
    357
    Airwolf has tried something like that a couple of times. Never seemed to work out.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    1,867
    I have a Capehart spin on on my O 470 that I've used since 1995. It has a fine screen and magnets inside and sounds like the same idea.
    nd
    2,536
    The magnet idea sounds good, you will have to let us know if the filter looks like much more or able to be better than the original lycoming screen.
    nanook's Avatar
    Aug 2002
    northern alaska
    1,462
    Remember the old CFO-100? Or whatever # it was. You would never safety the filter housing until you ran it up and checked it for leaks.
    skysigns's Avatar
    Jul 2002
    seattle wa 98053
    266
    Steve let e know how they work i go 12 filters a year
    Aug 2003
    1,238
    Ummm, Steve, your caption for the string calls it a "sin" on oil filter. Is there something else we need to know?
    Thanks. cubscout
    16,282
    I fixed it Kurt.
    Jun 2005
    Austin TX Ya'll
    659
    Challenger aviation is just the folks who stc'd it. The parent company is. http://kandpengineering.com/ great product used them in cars and motorcycles they have
    information on their website including videos how to clean. Kind of pricey but does what it says on the tin so to speak. Still a well engineered quality American made product. Steve please let us know what you think after you use it and clean it a few times. I'm interested to see what a person of your maintenance knowledge thinks of it.
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    294
    I have been using one for the past 280 hours. Easy to clean. Magnet picks up traces. Seems excellent.
    16,282
    Interesting.
    supilot's Avatar
    428
    I've been using one for about 300 hrs now. No issues at all.
    16,282
    Got the filter today. Here is it next to a Tempest AA4108. Weighs 6.5 ounces less than the throw away Tempest filter. It is a bit smaller.
    Push the screen part in and turn slightly and it comes out like the Steve's gascolator.
    There is a magnet on the top as well.
    7,848
    Steve that might fit under the cowl of a J3?
    68Papa's Avatar
    Chugiak, Alaska
    260
    That looks pretty slick. Does it matter how it mounts; up - down - sideways? Does it safety wire??
    16,282
    Looks like it might. I will see when we get the cowl on this Clipped Wing.
    16,282
    Quote Originally Posted by 68Papa View Post
    Doesn't matter, mounts just like a throw away filter and has 6 safety wire holes.
    2,579
    Doesn't look like there's any way of venting it so that it can drain prior to removal, if mounted gasket side down. Is that a problem, or will drain just fine without venting? I'm thinking about the B&C arrangement, and their recommendation to punch a vent hole in the top of disposable filter housings to aid draining.
    16,282
    My Dad and I were pondering that. ECI makes an adapter just like the B&C and the Casper Labs and it has a quick drain boss in the bottom of the adapter. We were discussing a pipe threaded hole in the top of the filter and a quick drain screwed in to allow air in so it would drain. I make a mess no matter what I do so I just throw a few rags under it and let er rip.
    Jul 2011
    Denver, CO
    294
    When I change mine, of course first I let the oil drain out of the sump. By the time I'm organized and take off the oil filter, there is never any oil in it...just a few drops that one or two shop towels wrapped around the bottom pick up as I lift the filter off of the housing. To be clear, the filter is top-down, so I lift the filter up after unscrewing it.
    2,579
    A little bit of drift here, but related - - What are your experiences / thoughts re oil filter adapters? I'm trying to compare Casper Labs vs B&C adapters, but not finding much online except that the Casper Labs unit is $100 or so less costly.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,213
    Gordon, FWIW I wondered about the Casper because it was notably less expensive but figured I'd give it a shot. The machining quality is excellent and I can't fault it in any way.
    16,282
    I have installed a lot of Casper Labs filter adapters simply because of the price difference. I have a B&C on my own airplane only because it was given to me by a friend. I have seen no difference in quality or operation.
    7,080
    I was taking off (in the air) at KBOS once in a new (70TT) PA-28-180 when both my passenger and I saw the oil pressure drop to zero. All of the oil had been pumped out between the adapter and the accessory case. That was repaired followed by a second incident with another pilot followed by a new engine all before the plane had 100 hours on it. I'll use the oil screen thank you since I do not operate in dusty environments.
    That Challenger filter does look very nice.
    16,282
    What was the cause of the leaks? I have installed more of these adatpters than I can count with no issues. I install the filter adapter more of an ease of maintenance issue than anything. Messing with the oil temperature bourdon tube, especially on a Super Cub with it so close to the firewall is always risky and I have found a pile of cracked oil screen housings. I just find it way easier to unscrew a filter than remove 4 bolts, clean off the old gasket, reinstall and torque with new lock washer.
    7,080
    No question Steve, it is certainly easier from a mechanics point of view to unscrew the old one and screw on the new one. Less $$$ for the customer. And there certainly is less room on a -18 than a -28.
    As I recall (it was in 1966) it was a defective adapter surface which did not seat correctly on the accessory case. I think that they (the maintenance people where I was working) should have done more than change the oil and filter putting the plane back on the line. I saw the filter and adapter after the second incident. It was jammed full of metal which no doubt was caused by my loss of oil pressure.
    7,848
    I lap everything before installing. Seen too many flat surfaces that weren't.
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    352
    That looks pretty nice, Steve. Hopefully your oil-change review goes well. I've been wanting to remote mount my filter and if I do that I'll probably get one of these.
    2,579
    Thanks for the info, folks. That helps.
    2,306
    It looks like a spin-on screen to me. I never enjoyed cleaning a screen and found a disposable filter much more convenient. Does that housing have a pressure bypass built in?
    brown bear's Avatar
    Feb 2004
    emporia ks
    488
    Steve
    With your Dads back ground I would be interrested in his take on this filter ?
    Doug
    16,282
    Here is the screen material.
    Here is the bypass.
    nd
    2,536
    Pierce, to give us a size comparison could you take a picture of the filter screen along side of a original lycoming screen? And what does it weigh?
    behindpropellers's Avatar
    NE Ohio
    6,532
    nd
    2,536
    Was this meant for my post? If it was i would like to see screen comparisons, the housings dont filter much oil. With the gear tooth type screen there is a lot of area there, if its needed?
    2,306
    For me and other guys like me the best way to get rid of the icky stuff in oil is to change the oil. My comment about preferring disposable filters comes from 100% of my oil changes happening outdoors in the weather. My facilities are limited to a bag of tools and a tailgate on the pickup. Dust, rain, snow, wind, bugs... let alone the years bobbing on floats. Wham, bam, thank you ma'am. Good old Champions fill the bill. Take it home and cut it open in the garage with a cold one going. To each their own. Its all good. What I wish is that somebody would come up with a safety wire eliminator. That's something I'd buy!
    16,282
    1,536
    Thread drift.
    http://www.dmctools.com/Products/safe-t-cable.html
    I've used these cable kits in the past and definitely recommend them if you don't want to twist wire. Spendy, but they do their job very well.
    16,282
    Thread drift.
    There are some places I would gladly spend the $400 plus dollars. Last time I looked they were sever thousand $.
    2,579
    Web, the link fails for me -
    Edit: Well, now it works - -
  1. R22 spin oil filter
    By Binty in forum Modifications
    Last Post: 09-12-2015, 09:01 AM
  2. spin on oil filter
    By JMBreitinger in forum Cafe Supercub
    Last Post: 08-13-2008, 06:40 AM
  3. spin-on oil filter
    By JimC in forum Modifications
    Last Post: 05-11-2003, 12:56 AM
