Already bought the wire. At this stage, it is too much work to change it. That also would give me about 10 feet of heavy ga unfused wire that is hot with the master on.
My setup will use a 30 amp breaker in the feed line. It wiil be about three inches from the master solenoid. A short in it trips the breaker.
A short in your setup fries till you turn off the master unless I am missing something.
All right. Since 'some people' won't pick up a phone, I'm reduced to scribling on paper in an attempt to impart some knowledge. I've attempted to attach a pic with two diagrams. The top is the stock SuperCub system. The red lines represent the heavy cable from the start solenoid/battery location, through the firewall, to the starter. The blue lines are the control circuit for the start solenoid. The green lines represent the bus power circuit, from the two glass fuses, to the three position master switch, to the bus The big downfall of this system is that the bus power lines are ALWAYS hot from the battery to the master switch. That's why they have those leads fused.
To make this a 'real' bus power system, look at the lower drawing. Replace the original start solenoid with a master solenoid. Move up to the firewall and cut the heavy starter cable, install ring terminals and the ends to a new start solenoid. Using the original control wire for the start solenoid (the blue wire from the top drawing), connect one end to the new master solenoid and the other to a new master switch (the brown wires from the lower drawing). Your master solenoid now works and you didn't install much new wire. Now, using the original start button and fuse, run a wire to your new start solenoid at the firewall. At the same time install a new bus feed wire from the 'upstream' terminal on the start solenoid (the large terminal that's always hot when the master is on), to the bus bar.
The only thing left to do is drag out the bus feed wires (green from top drawing), the fuse block by the battery, and the original master switch.
This way allows you to reuse some of the existing wiring, if they are in good shape, and bring your electrical system up to modern standards.
One other note; NEVER fuse a bus power feed. These are always the heaviest wires and are controlled with the master switch & solenoid in emergencies. Remember that the only reason the originals were fused is that the could not be turned 'off'.
