I can't find the thread but I recall reporting after weighing my Gallet and DC w/headsets that the Gallet was lighter. How heavy is a Gentex?
I am not an expert.
My experience from over 20 years building helmets for a living tells me I know what I don't know about aircrew helmets.
A well designed helmet can reduce the risk of catastrophic injury and death in sport. The wrong helmet can be worse than no helmet.
I have not found a helmet standard that is written to specifically address the mechanism of injury in a cub like crash.
Some things to think about:
Keeping your head from hitting things is good, with or without a helmet.
Don't crash; easily said by a guy who flies for fun.
Use your head, train with the best instructor you can find, practice and setting limits are good steps to reducing your exposure to crashing.
Aircraft choice. I will say it. Not all planes are created equal and not all pilots are the same size. Big pilot/small plane may not be a good combination. Distance between your head and hard objects with or without a helmet is your friend in a crash.
Using well made shoulder, lap and center straps that are attached to something strong like the airframe is another defense from keeping you from hitting your head.
If you use a helmet be aware of a few things:
Heat fatigue is real danger in the summer.
Just because it looks like a helmet does not make it a helmet.
Watch out for the "gladiator effect". The gladiator effect theory is when one becomes emboldened by safety equipment. Skiing is a good example. Ski helmet usage goes up, minor head injury goes down but catastrophic injury and death rates go up. Why?
The Peltor helmet mentioned by Glenn above meets some interesting standards that include a roll cage impact and are tested with the headset installed. But the Peltor looks hot as hell. The 275 g standard used on the Peltor will nock most of us out cold and kill a few of use. Better than the K10 but what is better?
I am not an expert.
Sold my Gentex, heavy and hot most times of the year.
Get what is comfortable so you wear it. Cost is not a factor for something that will last 10 plus years and thousands of hours.
(I don't always head south with a cub, but when I do, I make sure it is freezing a$$ cold!)
There's a groove in the padding in the Comtronics that allows the headband to fit into it. The headband on my DC noise canceling is a little wider than the groove but it works anyway. I plan to snip a little plastic off the front and rear of the headband soon to insure a better fit. I've only used it a few hours but like it so far. I see no way to fasten the headset into the helmet without some jury rigging. I just remove the helmet and put the headset into it and hang it from the v brace when parked. Got it from Spruce. You have a choice of d-rings or plastic snaps for the chin strap. Visor is included. They're cheap so......how much impact they will take is something I wonder about.
Which model did you purchase?Im new to helmets. But this thread and others plus flying with some guys that all had helmets this summer got me to wondering. So I bought a Comtronics helmet direct. They say it'll fit the Zulu headset and I tried it out today. With the headset on first the helmet slips right over it and as mentioned above there is a groove in the padding that fits around the top band. Ill get get some more hours on it before I'm convinced but so far I like it.
Without testing we cannot tell.I'd assume a hard shell and a half inch of liner foam would be better than nothing.
Go whack your head on you plane's tubes during moderate or greater turbulence. That's a test many of us have conducted and a bump helmet beats the crap out of nothing.
The advice to wear a motorcycke helmet that's designed to absorb energy from contact with the ground isn't applicable to airplane helmet requirements but it would be better than nothing. Same same.
agreed. A bump helmet is good at bumps.
To reduce the chance of catastrophic injury or death something more may or may not be needed.
I am no expert.
I bought an old hockey helmet... Threw it in the CNC and cut out the earholes for my headset. A ratchet strap and the headset isn't going anywhere?
Do you think this will be ok, even though you are not an expert?
