Currently it has no brakes at all so I’ll be into a fabrication project either way. I can put toe brakes on the existing rudder pedals but I believe I’ll have to move the assembly back away from the firewall. I found pictures of the narrow geometry heel brakes I was thinking of, but it looks like its from a company that supports ultralight type aircraft http://www.hegar4.com/zc150/index.p...id=189&zenid=a2ba54724cab6d21181362244616ead7 . I’m leaning toward adapting toe brakes to the existing rudder bar. This looks like the simplest way without a lot of wheel reinventing http://www.macsmachine.com/images/controllinkages/full/sidcyl.gif…Adding…heel brakes would take time...
EXACTLY…a picture of the airplane full of lumber, generator etc. Just enough room for the pilot to sit on the left and looking like he wanted to build that cabin in one trip. That made me a fan of the "big" cub type airplane...
I'll accept the sleep deprivation thought. Are all of your available 8' pieces of building materiel exactly 8' long? Or is some of it 8'-1/8"? How thick is your scuff plate on the firewall? Is there any structural tubing behind the firewall? It sounds to me as though you will need a shoe horn to load your cargo and perhaps a saw to get it out.I took a tape measure last night when I finally got everything home and in the hangar and although I may have been suffering from sleep deprivation (Over 40 hours between getting up Friday morning and laying my head back on a pillow Saturday night), the "Cabin - Now cargo area" measures just over 8' from the firewall to the aft baggage wall. So that answers that question, at least for me, that full length 8' long building material will fit inside the cabin area. I'll add scuff plates to the area behind the firewall, the aft baggage aft wall and against the R/H cabin wall so 8' items can be loaded in without damaging the surrounding structure.
Are you a long legged person like me? I find toe brakes on a Clipper/Pacer to take up too much space pushing the pedals back cutting into my leg room. This in turn will cut into cargo space behind the seat. Give some thought to placing the master cylinders under the floor with the heel pedals sticking straight up through the floor. The standard Scott Cub master cylinders or any of the high pressure versions can be turned 90 degrees with the pedal straight up. Tie these to a remote reservoir for convenience. I did this in a cabin Waco. Worked just fine.I'm also a dyed in the wool heel brake guy. Heel brakes just seem the natural way to go and I'm most at home with them, but again, the airplane is already set up with a rudder pedal system and I can just add toe brake pedals to the existing rudder bar and add mount tabs for the master cylinders and call it good. I'll probably have to move the assembly back a little to clear the M/C's from the firewall, but by using the original rudder pedal bar, I can retain the rudder cable routing as well. The pedals are too close to run the traditional Scott M/C's or any of the piston type retrofits that copy the geometry. That being said, I could swear I've seen a picture of a dual heel brake assembly somewhere that is actually fairly narrow. Two non-reservoir M/C's side by side laying down with 2 heel brake pedals very close to each other.....
I have the Blanton plans and my suggestion would be that, while extremely interesting, they might not be the best way to go about building one of these planes. I don't want to offend anyone and I have seen some of the Planes and they are nice planes but some of what Blanton proposes, doesn't appear to comply with the current regs for experimental amateur built.
Unfortunately I don't think there are any plans out there for these planes other than Blanton's though.
..................And why there aren't any plans out there for the Producer.FWIW there was a homebuilt design called the V6 STOL which was basically a stretched Pacer. Might be worthwhile to get a set of those plans & builder's manual to see how they went about it. I think a buddy of mine has a set I could probably get photocopied.
I’m know I was tired, but there’s actually MORE than 8’ of space. I measured from about 8” or 10” above the floor, the same level as the internal hydrasorb structure all the way back to the rear baggage rear bulkhead. In fact, the rear bulkhead is sloping up and rearward as it goes upward so you get even more room the further up you go.…Are all of your available 8' pieces of building materiel exactly 8' long? Or is some of it 8'-1/8”
The sheet metal firewall is actually removed currently, I was measuring from behind the firewall tubing.…How thick is your scuff plate on the firewall? Is there any structural tubing behind the firewall?...
No, as I said earlier in this thread, I want to create a door further aft behind the baggage area to load the full length material through. Once I get it in the cabin I can then position it up against the scuff plates and secure it down.…It sounds to me as though you will need a shoe horn to load your cargo and perhaps a saw to get it out...
That’s what I had in mind at first and I may end up doing just that, thanks.Give some thought to placing the master cylinders under the floor with the heel pedals sticking straight up through the floor...
Come on man – Chill out a little;-). I’ll throw a 2X4X8 in there and take a picture, but I’m tell’n ‘ya, it’ll fit easy. AND, a lot of the load is in the cabin rather than piled in the baggage area and aft.I'll accept the sleep deprivation thought...
Good looking work my friend.Here is my version...
Thanks Steve....D.A. Go with the Cub wings. Add another baggage door...Toe brakes are an easy install but you do lose some leg room. - Steve
Buddy, don't worry about that at all. This is a great place to post ideas and get input for all of us....I do not want to hi-jack this thread...
Just bought it off of Ebay. I remember that plane too, it ran the prop off a huge Gates belt like the Gershwender (Spl) prop reductions. If I remember correctly, wasn't that airplane involved in some kind of claim to be running off of tap water rather than gasoline?I have an old (jan 1996) issue of "Sport Pilot" magazine...
