Results 1 to 12 of 12
Thread: What size safety wire is needed for working on a PA-18-150?
    Feb 2015
    160
    What safety wire sizes are used on a PA-18-150? I would like to have the proper sizes available for maintenance and for any work that needs to be done on it at the hangar (annual, repairs, etc...)
    0.02"
    0.021"
    0.025"
    0.032"
    0.041"
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,681
    I typically use .025 for most everything except turnbuckles and prop bolts which require .041
    Feb 2015
    160
    I was guessing that .032" would have been common on a Cub.
    jnorris's Avatar
    Wisconsin
    786
    I use .032 for most applications, except as noted by PerryB. .041 for prop bolts and primary control system turnbuckles.
    Joe
    "Fortes Fortuna Adiuvat"
    Joe
    9,811
    .041 is most common I need.... I have the others, but rarely needed (like I still own the original other size rolls decades later, never used up..)
    2,116
    Use the thickest wire that will easily fit in the hole. Usually .032" and .041" Smaller sizes such as .025" are typically used on small screws and electrical connectors.
    PerryB's Avatar
    Aug 2007
    Northern Calif.
    1,681
    Quote Originally Posted by slowjunk View Post
    I'll have to go back and look, maybe .032 is my small wire.
    Feb 2015
    160
    Thanks a lot for the input. I look forward to what PerryB finds.
    RaisedByWolves's Avatar
    Feb 2005
    3,616
    I use mostly .032
    .041 for turnbuckles
    18,001
    Yep .041" on prop bolts and turn buckles and .032" on everything else. I use .020" to hold Adel clamps together while I get the fastener in if I can't get my clamping tool in there.
    WhiskeyMike's Avatar
    West Boxford MA
    834
    Try AC43:13 for legal technical info as well, though 032 except prop is right.
    6,347
    I agree, except that, if you think about it, any bolt that backs out with enough rotational force to shear .032 is going to shear .041 as well. You know that battleship-sized cotter key that holds the wheel nut? Imagine what it would take to shear that thing, and then think: would you rather the axle nut come off, or that seized bearing to melt your axle?
  1. What size wire do I use for L E D nav lights?
    By Marty57 in forum Experimental Cubs
    Last Post: 08-28-2014, 02:49 PM
  2. Low Flying And Wire Safety Video
    By Patrol Guy in forum Cafe Supercub
    Last Post: 05-21-2010, 04:41 PM
  3. Wire size for landing lights?
    By palhal in forum Tips and Tricks
    Last Post: 01-14-2004, 01:13 PM
