Thanks Thanks:  0
Results 1 to 6 of 6
Thread: Piper Pacer/Tri Pacer Question
    May 2014
    11
    I'm just curious, there seems to be a lot of market support for the restoration of all Cubs in general and the building of experimental counterparts, but what do Tri Pacer/Pacer owners do if they need a new fuselage? Are there new production fuselages or blueprints available (complete sets of blueprints)? As for wings and tail feathers, I would assume that some or all parts from Cub wings work. Thanks for your response.
    V/R
    Adam
    White City, Oregon
    856
    Thee are no "new" fuselages being produced for the Pacer / Tri-Pacer line.... It simply is not as popular of an aircraft as the Cub... Only way to replace a fuselage is to find a decent used one of the same serial number range of the model you have.... For instance, the aircraft I am working on is a 59 model and I replaced the fuselage with a 57 frame that is the same as the original... Just straighter and without all the old crappy undocumented repairs... I did add one piece of hat section to the replacement frame rear door area that was part of the original... The replacement frame is a log book entry... The log will read replace airframe S/N 22-12345 with airframe 22-1234, airframe modified to comply with previously installed STC's XX and XXX....
    Replacement wing parts are available from Univair along with all of the control surfaces... The horizontal surfaces on a Pacer are slightly smaller than a cub although cub surfaces can be installed with Svenn's aviation STC.
    Brian
    8,375
    Lots of drawings. This would be useful for you.
    http://www.shortwingpiperclub.org/sh...rawings-vol-1/
    fly_cubs's Avatar
    Chapel Hill, NC
    402
    If the dimensions and fitting locations of the wing attach, gear, and motor mount are the same as a PA-16 Clipper, PM me. We have a repair jig that is no longer in use.
    17,931
    www.shortwingpipers.org for support of the Short Winged Pipers. I built a fuselage jig because there are no new replacements. Parts are plentiful from Univair and Dakota Cub. The drawing CD from the Short Wing Piper Club that Pete linked to is a must have in my opinion. I believe these airplanes are as popular as Cubs just at a lower budget. Piper built a lot of them.
    Likes DENNY liked this post
    Cubus Maximus's Avatar
    1,747
  1. Piper Tri Pacer
    By 3689A in forum Cafe Supercub
    Last Post: 05-27-2011, 08:58 AM
  2. Pacer flap question?
    By T.J. in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 05-26-2010, 12:01 PM
  3. Stretched Pacer - Fuselage Lengthening Question
    By PA18project in forum Experimental Cubs
    Last Post: 02-15-2007, 09:10 AM
