Hi,
Local seller has a fuselage for sale: it comes from a 135 but has been repaired and modified (front cross members) and reinforced(plates over a two clusters up front). While he operates his planes under restricted, I'd like to restore to standard 150 upgrade. Wings come from the same plane, so I presume adding ribs, missing are flaps and ailerons: do they differ between the 135 and 150HP?
Would that fuselage still qualify as standard? If not, Who would have to approve the modifications?Are they legal without STC under Standard/ Restricted or none?
Does adding ribs to the wing require STC?
How about adding a different engine mount (HP upgrade)?
I thought the project was overkill to be reasonably transformed into a 150 cub.
What's your opinion?
Xargos
Xargos
