Results 1 to 10 of 10
Thread: Picture posts 90 degrees counter clock wise
    Nov 2002
    Fargo
    630
    Every time I post a picture or make an ad from my iPad the picture is 90 degrees cc from what it should look like. Anyone know how to fix the problem or change a setting?
    chuck
    Feb 2012
    3
    Just a wild guess, but the automatic rotation setting on the iPad might be set to "locked".
    This might prevent your camera from detecting the orientation of the iPad (Horizontal or Vertical).
    With my iPad, when using the camera app and I rotate from vertical to horizontal, the camera icon rotates as well.
    Sometimes, if the iPad is close to level (with respect to a table or the ground), with camera pointing down, the iPad sensor will not detect moving from horizontal to vertical.
    Not sure if this addresses the issue you are seeing. Hope it helps.
    9,905
    the iPad is "Smart" enough to display it correctly.... even though you took picture 90 deg off......
    this web site, well.... it just shows it the way ya took it
    Nov 2002
    Fargo
    630
    I don't know, I looked in settings but can't find anything. The pictures we're take straight and I am able to post them normal on barnstormer, so I thought it was something with the website I have seen other post here 90 degrees off so I don't think it's just me. Even when I tried to rotate the pictures in my add they showed up 90 degrees off until you clicked on them to in large then they are normal.
    Nov 2002
    Fargo
    630
    That's weird the small picture is 90 off but enlarged it's right
    9,905
    Quote Originally Posted by PA-22/20-160 View Post
    nope still shows 90 off on computer.. at least for me... you looking on the iPad still?
    Ursa Major's Avatar
    Oct 2002
    Coeur d'Alene, Idaho
    1,062
    On my computer it rotates 90 degrees when enlarged too.
    Mike
    Nov 2002
    Fargo
    630
    I don't think supercub.org likes iPads, must not be apple fans.
    180Marty's Avatar
    May 2004
    Paullina, Ia
    1,990
    Whenever my sister sends a pic from her phone to my email it is 90 degrees off too. I've wondered what's going on.
    Aug 2012
    Portland, OR area
    47
    I don't know about Ipads but some cameras display a pix correctly but actually store the file the way you took it. Maybe something like this is what you are up against.
    DRL
  1. counter balance spring
    By Kevin Owings in forum Cafe Supercub
    Last Post: 03-09-2008, 09:35 PM
  2. Picture in a post - A Picture Tutorial - Part Two
    By Lawn Dart in forum Website Q & A
    Last Post: 03-26-2005, 12:53 AM
  3. Picture in a post - A Picture Tutorial - Part One
    Last Post: 03-12-2005, 02:34 PM
