The hang glider guys have some neat hard plastic type "donuts" that they use inside the thimble to accomplish the same thing. I've always been under the impression that a deformed thimble is a good heads up as to the loads involved, as in normal usage they won't. I should load test some 1/8" cable with the cranes load indicator to see where it the thimble deforms relative to where it snaps. It's fairly accurate, within 200 pounds anyway. My aft cables go to a under the fuselage bushing that holds a AN-4 bolt, (so shear loaded) and I used doubled up old hang glider stainless tangs I had in the junk pile, their original purpose being cable termination. They will also deform a bit way before failure, they look fine. For my light bird I'll probably stay with the 1/8" and "continue to monitor".
